Old 07-15-2007, 01:15 PM   #1
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
Default Dented Pipe??
So I just got home from the races and realized that i have 2 pretty big dents in my pipe. Do you think this will ruin performance?? i will have pics up in a little bit. thanks.
NitroMaxx3.3 is offline   Reply With Quote
Old 07-15-2007, 01:28 PM   #2
u should try the freezer trick
gatermaxx is offline   Reply With Quote
Old 07-15-2007, 01:33 PM   #3
would it shange the way it ran before if i use the freezer trick? with the metal be softer in any way?
Here are the pics
Old 07-15-2007, 01:42 PM   #4
No idea, I have never had to do the freezer trick, but it should not change much on the pipe, here is more info
http://www.rctech.net/forum/showthread.php?p=944555
Old 07-15-2007, 02:06 PM   #5
gashuffer's Avatar
Trader Rating: 48 (100%+)
Freezer trick works, does not soften the metal, It worked for me
T-Sal
gashuffer is offline   Reply With Quote
Old 07-15-2007, 05:01 PM   #6
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The freezer trick is a roll of the dice. Sometimes the pipe runs just like it did before, and sometimes it doesn't. If the engine performance is being compromised right now, you have nothing to lose.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-15-2007, 05:57 PM   #7
kidsid99's Avatar
Trader Rating: 53 (100%+)
The freezer trick worked great for me on an RD Logics pipe with the stinger stiffener. Only thing if the dents are big like the one looks nearest the stinger you might have to do it twice. I put mine in at bedtime and took it out the next morning before work and did it again to get it real straight.
kidsid99 is offline   Reply With Quote
Old 07-16-2007, 04:34 PM   #8
Here are the pics
RYAN the freezer trick will do it or you could just run it dented
PNP HOBBIES is offline   Reply With Quote
Old 07-16-2007, 08:23 PM   #9
Thanks guys. Had fun racing this past weekend Pete.
Old 07-17-2007, 10:16 AM   #10
Loveless's Avatar
Default Dented pipe.
Yo Gatermaxx, i have the pressure nipple and the stinger plugged, but dont know what use for the hole for the header part of the pipe, and if so how do i contain these ports so that the milk , or water doesnt push them out once freezing process starts to work, was thinking about zipp ties...
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 07-17-2007, 12:00 PM   #11
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
how does the freezing expand the pipe?
it doesnt make sense. heat makes things expand, cold contracts
so what makes this prosses work?
and does it make the pipe look like new if done right?
BlackedOutREVO is offline   Reply With Quote
Old 07-17-2007, 12:41 PM   #12
Roger's Avatar
You ever see what happens when you put that water bottle filled with water into the freezer ? It expands by about 10-15% larger than its original size. I put afew bottles of water to use them as ice packs for my ice chest filled with drinks. If you want to read about the explination and science of why water expands, do a google search for " ice expansion ".
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 07-17-2007, 12:50 PM   #13
Team Kamikaze's Avatar
Hey Pete whats up? I though you would recommend a new pipe instead of fixing it.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-17-2007, 01:31 PM   #14
no, i havent ever seen it does that.....
hmmmm, so thats strong enuff to un dent the pipe? thats sweet!
do the dent go away like they werent there, or just help?
Old 07-17-2007, 01:45 PM   #15
Roger's Avatar
Depending on the dent, if your lucky, it'll look like the dent wasn't even there. There are times when the dent comes out with a few blimishes. And, sometimes, there are times when the dent doesn't even un-dent itself just because of the location of the dent. Here's a dent that may be beyond repair. This is Andrew Ellis' car back at the 2004 1/8th scale nationals.
HPI R40 nitro touring car, OS12TZ & OS 1040 pipe, Mugen Mielke pipe wyl03 R/C Items: For Sale/Trade 5 07-01-2007 08:59 PM
Dented Carb..Help jetbill007 Onroad Nitro Engine Zone 3 01-18-2007 01:03 PM
how to fix a dented pipe uniquexme Nitro On-Road 12 08-30-2006 08:31 PM
Dented maskedrider Nitro On-Road 16 02-05-2006 07:27 AM
Reforming dented dual-chamber pipes? chachi Nitro On-Road 10 05-15-2003 12:32 AM
