Old 04-28-2003, 01:00 PM   #1
alucard13's Avatar
Default NTC3 Kit. help with suspension arm
If any of you are familiar with the Team Associated NTC3 kit maybe you can help. I am at the point where i am putting the left from arm onto the car. Now I screwed in the arm to the transmission case like it says and the bottom of the lower arm. but when i turn my drive shaft the suspension arm will move to the right. it wont just stand still. now if i turn it to the left or right (the suspension arm, like if i was turning the car while driving) and i turn the drive shaft it will force itself straight or back to the right. i stopped working on it at about 10:30pm last night and havent touched it since them so when i get home i might take the suspension arm and re do cause maybe i meesed up with putting in a bearing or washer or the pivot balls. but if anyone has a suggestion, let me know. Its kind of hard to describe, but just picture in your mind if the car was being driven that the arm would want to snap to any direction when the drive shaft starts to turn.
alucard13 is offline   Reply With Quote
Old 04-28-2003, 09:36 PM   #2
alucard13's Avatar
i beleive i found the problem. i needed a little more grease where the dogbone and axel connect together with the roll pin.
Old 04-29-2003, 04:17 AM   #3
Send a message via ICQ to V-One S
So u have fixed it then?
V-One S is offline   Reply With Quote
Old 04-29-2003, 07:14 AM   #4
alucard13's Avatar
yes, so far it seems to be working. i'm almost done with the kit. all i have left are the shocks and the servos and engine and then the little touch ups and stuff and i should be burning asphalt
Old 04-29-2003, 05:08 PM   #5
alucard13's Avatar
Default servos
Got another question. When installing the servos (the steering servo for example) it says to put the horn on 1/8th of an inch from straight. that gives it a slight angle. But is this position from the nuetral on the servo? because when i took the screw of to mount the horn the servo moved a bit so i dont know from which point they want me to do it.
Old 04-29-2003, 06:04 PM   #6
You should have your battery and receiver connected turn it on and set your remote in neutral position...
saka is offline   Reply With Quote
Old 04-29-2003, 08:14 PM   #7
alucard13's Avatar
awesome, thanx for the help
Old 04-29-2003, 09:10 PM   #8
alucard13's Avatar
Default battery case
Is thier a case that i can get to enclose the battery case that goes in the car on the NTC3? Right now it exposed and i dont really want to use a ballon.
Old 05-01-2003, 08:32 AM   #9
You don't need to cover the reciever battery, it will be just fine exposed......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
WTB: C-Hub Suspension iamjeff6 R/C Items: Wanted to Buy 1 12-01-2004 06:58 AM
Tamiya lightweight suspension - trade for 415 suspension letitroll R/C Items: For Sale/Trade 3 10-19-2004 10:45 PM
WTB: Centax for NTC3 and FT-NTC3 Roller FFR3582 R/C Items: Wanted to Buy 5 08-09-2004 05:39 PM
Building my NTC3 and bought a MUGEN MT.12 motor for my NTC3..good choice? need advise JDMboy Nitro On-Road 8 08-09-2004 09:31 AM
NTC3 version 2 rear suspension - BUNDLE Canuck R/C Items: For Sale/Trade 3 06-05-2004 07:27 PM
