Impluse Pro is here
#91
no such thing as a foam only car, some of the initial setup may lend to foams.. but rubber will work grab some rubber setups from serpents web page.....
#92
question about batteries
Hey guys does the Impulse Pro come with batteries? Also I noticed that there's a new "compact" battery set for the Impulse Pro with the carbon fiber radio tray. Is the carbon fiber radio tray standard or a hop up on the Impulse Pro?
Does anyone own the Serpent Starter box? Any opinions on it? Someone wants to sell one to me for $60 used and it has those banana clips and batteries too.
#93
the pro does not come with the battery kit, you need to get it from serp or build your own, well i guess either way you are going to nuid your own, it is built around a plate....
#94
Nem...Ammdrew... I'm having a hard time adjusting the lowend needle on the RB X12T on my Impulse....the slid is too close to the fuel tank....what did you guys do to correct this?? turn the carb a little maybe???
#95
you got it , Arnold. Turn the carb....so we won't have a hard time getting into that bottem needle.
#96
Has anyone converted an Impact to 200mm???
#97
just buy a impulse much cheaper..
and turn the carb but not much, you can also melt the edge of the tank, very carefull mod not recommended, alot of .15 guys use too
#98
ammdrew...I think i would have to fashion a special tool...there really is'nt much room to move it so i'll just leave it alone...
A good guage gi sheet bent to shape should do the trick....
#99
true...........
#100
Originally posted by ammdrew
true...........
true...........
#101
WOOHOO! 100 replies
Hey got_speed? Where'd you find that polished 50221 pipe in the MTX-2 thread? That pipe looks soooooo good. The one I have is black, but I NEED the polished pipe. MUST HAVE! Oh, I'll hopefully post pics of my next Impulse project today. I won't say what engine it will have, but it's bigger than a big block .15. Hehehehe. Good racing.
#102
Hey Nemesis.....what are you up to now.... bigger than a big block .15 ....you better install a sturdy rear wing on that puppy..... I'm sure the drivetrain will take the punishment....
BTW here is the link for the site you were asking for:
Novarossi Pipe
Novarossi Pipe
#103
Aluminum Pulley's for Serpent Cars....
From RB Site:
From RB Site:
#104
only alum pully i would get is the one that handles the rear belt and brake, the plasic ones seem to bend the inside of the gear.
#105
Nemesis....how is that project comming along????
