Old 01-07-2002, 10:52 AM   #31
got_speed?'s Avatar
Ah10...I think the ratio in this Impulse is so close.....I could hardly feel it shift.....
got_speed? is offline   Reply With Quote
Old 01-07-2002, 10:56 AM   #32
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Make sure your second speed is set up correctly! I am running Kawahara clutch type 2nd speed, similar design as Serpent Impluse and I could definitely see, hear it shifts!
Ah10 is offline   Reply With Quote
Old 01-10-2002, 06:03 PM   #33
SpeedTech's Avatar
Hi Guys,
Just want to make a quick announcement. We will be stocking Serpent parts in the near future, starting off with the new Impulse Pro. We will also be looking into stocking the 1/8th and 1/10th scale on-road car from Serpent.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 01-11-2002, 09:36 AM   #34
got_speed?'s Avatar
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Steve let me know when you get that Centax for the Impulse!!! You know my email address...
Old 01-11-2002, 08:33 PM   #35
Manticore's Avatar
the shoes type 2speed definitely "sounds" awesome but I do believe the finger type 2speed work awesome too. I might get the shoes type 2speed but the downside is the wear on the housing.
Manticore is offline   Reply With Quote
Old 01-15-2002, 12:33 PM   #36
got_speed?'s Avatar
Default Floating Rear Body mounts...
Does anyone know what Serpent Part #'s I need to install a VDS mount to the Impulse Pro??
Old 01-15-2002, 01:22 PM   #37
The part number you want is 808150.
It is the complete rear mount set for Impact M2. This will fit regular Impulse. You might not be able to use new upright spacers on impulse pro with the floating mount. Keep checking with mytsn.com as they may release a new part if the GTP craze catches on. Hope this helps some. http://mytsn.com
Nemesis is offline   Reply With Quote
Old 01-15-2002, 05:20 PM   #38
got_speed?'s Avatar
thanks Nemesis!!! Have you done such a mod??
Old 01-16-2002, 07:40 AM   #39
got_speed?: No I have not done the conversion yet (waiting on parts.) Theoretically it should bolt up no problem. Most of the impact parts can be used on impulse, with the exception of some chassis and drivetrain parts. Not sure what we'll have to do about the centering device. Possibly some sort of panhard rod. Although the kit may include something for this. Here are a few more helpful links.
Hope these work.
picture of parts included in 808150
http://www.mytsn.com/products/product.asp?prid=343
picture of floating mount installed on impact (scroll down)
http://www.mytsn.com/products/desc.asp?prid=320
exploded view of floating mount on Veteq
http://www.mytsn.com/products/parts.asp?prid=1039
Good luck. Serpent Rules!!!!!!!!!!!
Old 01-16-2002, 09:58 AM   #40
got_speed?'s Avatar
Hey Nemesis, I picked up 808150 yesterday...you are right I would need to take the upper arm spacer....I also need a new rear shock mount....I'll go to my lhs and look at an impact owners manual.....Thanks....
Old 01-20-2002, 05:33 PM   #41
got_speed?'s Avatar
Default Small bearing Conversion....
Does anyone know where I can pickup the small bearing conversion for the Impulse I know I have seen it somewhere...just can remember where
Old 01-22-2002, 06:51 PM   #42
GregH's Avatar
Send a message via AIM to GregH
So what exactly is included in the Pro kit that isn't included in the stock 2 speed kit? Like aluminum parts and other stuff. I know about the graphite parts and the front 1 way. Do they come with or make a CVD type axle for the front and/or rear???
GregH is offline   Reply With Quote
Old 01-23-2002, 12:21 AM   #43
got_speed?'s Avatar
No CVD's...graphite upper deck, one way front, gear diff rear, 26mm front foams, 32mm rear foams, low cg battery mount, graphite front and rear shock towers, handshake type front stabilizer bar, rear stabilizer bar, aluminum brace with belt tensioner.....that's it as far as i can remember... I'm changing my rear body mounts to floating ones'...it's going to be my OUTLAW car
Old 01-23-2002, 06:29 AM   #44
GregH's Avatar
Cool, thanks. The left side stiffener is the only aluminum brace then??
Old 01-23-2002, 10:25 AM   #45
got_speed?'s Avatar
That's right!!...or I should say that's correct (to avoid confusion
Serpent 705 for sale 710 Impluse!!! EvoMushi R/C Items: For Sale/Trade 2 01-26-2004 05:02 PM
Serpent Impluse 705 for SALE!!! EvoMushi R/C Items: For Sale/Trade 0 01-21-2004 03:52 AM
has anyone owned a Impluse PRO AND MTX PRO implusepro Nitro On-Road 22 07-07-2002 09:38 PM
Serpent Impluse/ Kyosho V1R Jack R/C Items: For Sale/Trade 1 07-07-2002 02:02 AM
Serpent Impluse/ Kyosho V1R Jack R/C Items: For Sale/Trade 3 05-29-2002 09:26 AM
