Old 07-12-2007, 09:00 AM   #16
guys don't bother with anti freeze and all these crazy hazardous stuff. just chrome the pipe, and it cleans all of very easily after each race day with detergent and warrm to hot water i payed $40 australian to chrome my nova pipe.
here is the beast with the chromed out dubs,...i mean pipe
TomB is offline   Reply With Quote
Old 07-12-2007, 09:05 AM   #17
Wild Tiger's Avatar
Thanks to all for your reply's.
You've been very helpful
Wild Tiger is offline   Reply With Quote
Old 07-12-2007, 09:09 AM   #18
Ice_nl's Avatar
Send a message via MSN to Ice_nl
I use an air compressor to clean the most dirt off and then i strip down the car and use serpent cleaning putty.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 07-12-2007, 09:12 AM   #19
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
All i do is put some fuel on a rag and scrub it off you'd be surprised how good nitro fuel is at removing nitro residue plus it puts a little coat of oil to stop any surface rust or oxidization i go over most of the car, you'd be shocked how long a wet fuel rag last too once it starts getting dirty just turn it in side out its still wet with fuel on the other side u just go through rags quick cause of how good of a job it dose it just's messes up the rag you wouldn't even use 50ml and you'll get most of the hard parts off then just go over with a clean rag to get every last bit off.
But this method don't compare to striping the car down and cleaning it properly but thats a huge job then for it to go straight back to how it was after one run
BUT ALL THIS IS AFTER 5-10min of blowing the crap out of it with a compressor which gets 75% off
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-12-2007, 09:20 AM   #20
wouldn't recommend this but when I'm feeling lazy i just give it a light spray with degreaser and wash the degreaser off with WD40 no water involved but heavily coat it with WD40 and blow it all off for at least 10-20Min making sure i blow every last drop out then i go over it with a dry clean rag this makes the car come up like new but once again i don't recommended this I'm just willing to deal with the consequences if something goes wrong
Futaba
Mugen
Novarossi
Byron's
Old 07-12-2007, 09:41 AM   #21
mugendude's Avatar
holly sh** what motor is that it looks awsome but the antifreez works really well
murnan modified rb xenon R ballistic missle i love the smell of nitro in the morning
www.rc-racing.org
mugendude is offline   Reply With Quote
Old 07-12-2007, 10:19 AM   #22
Chemical X's Avatar
Trader Rating: 16 (100%+)
The anti freeze method sounds interesting so I'll give it a try.
I've been using an ultrasonic cleaner like the one in the link below to clean my exhaust pipe and header. I fill it with Simple Green drop in the pipe and turn it on to its maximum time which is eight minutes. It's been working great at removing all the gunk from the pipe. I then polish it up with a little Mothers polish afterwards.
http://www.harborfreight.com/cpi/cta...emnumber=93035
The ultrasonic cleaner also works well when tearing down the car for a complete cleaning and rebuild. The downside is the cost of the cleaner and the time required.
Just like everyone else has said, always start by blowing off the car with compressed air for a good 10 minutes. That helps remove 75% of the dirt before you start other cleaning.
Chemical X is offline   Reply With Quote
Old 07-12-2007, 10:23 AM   #23
Loveless's Avatar
Default Tom B
Yo, TomB whats that on your ur pipes exuast, looks like its fastweld or something to strenghthen it up in case of a side fender bender,,,
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 07-12-2007, 11:20 AM   #24
Rapid Roy's Avatar
For the pipes, I have seen some people using a product called carbon off. I've seen it at seen it at smart and final. Comes in an aerosol can. Looks like it does a great job.
Rapid Roy is offline   Reply With Quote
Old 07-12-2007, 04:05 PM   #25
driftkingz's Avatar
the best thing to do it get a spray bottle and fill it with water spray you car but not the electrics and the get a compressor and just blow it all away
driftkingz is offline   Reply With Quote
Old 07-12-2007, 04:48 PM   #26
mugendude's Avatar
you go ahead and pray water but me i dont care if your clint eastwood if your spray isnt accurate then your electronics are gone i will stck with the cleaning pudy
www.rc-racing.org
Old 07-12-2007, 06:32 PM   #27
Loveless's Avatar
Default Cleaning...
I second the motion, cleaning puddy....
Old 07-12-2007, 08:39 PM   #28
its a product which is sold in australia called "selleys Knead it" it is a two part compound that comes in a sausage roll type thing. you cut a peice of and it has the two compounds seperate, one in the centre the other on the outside layer, you mix it up by squishing it together, and then mold it around the stinger.
to get a neater look i mask out the pipe and leave only exposed where i want the putty to go, then i put it on, shaping it with a blade and my fingers. then as it is setting, it gets harder (only takes a few minutes) then i cut it to the desired style and then neaten it up, then leave it. Works well.
it is a more like playdoh, and not as runny as some other products so it is easy to work with.
we have a compressor at the track, so it is simple to keep the car clean, blow it of after each race, then power putty it. i give a light spray of metho over the top deck and plastics just to take the grease of, then i spray the car with silicone spray.
Old 07-12-2007, 08:42 PM   #29
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I use denatured alcohol and it doesn't damage my servos!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 07-12-2007, 09:57 PM   #30
thamjk's Avatar
how do you guys clean engine crankcase especially thoes black spot in between the fins. It hard to access those area.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
I AM CLEANING OUT EVERYTHING!!!! OneBadFirstGen R/C Items: For Sale/Trade 34 02-24-2011 09:16 PM
cleaning out mizeracing R/C Items: For Sale/Trade 11 04-30-2008 05:46 AM
cleaning up? rdx_arthur R/C Items: Wanted to Buy 3 09-22-2005 06:31 AM
Cleaning out the Pit.... Mr. Shookie R/C Items: For Sale/Trade 30 07-25-2005 10:03 AM
Cleaning up........Look!!! racer_RR R/C Items: For Sale/Trade 9 08-12-2004 01:56 AM
