Old 07-10-2007, 09:12 PM   #31
thamjk's Avatar
I must say I like the porting.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 07-10-2007, 09:19 PM   #32
gansei's Avatar
crank shaft coating(Swiss Nano) is available in GR
no wear out shaft pin.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 07-10-2007, 11:48 PM   #33
O2
gansei,
You went to Femca 2007 in Indonesia? Which car your driving if I may ask. How much is the 3 port OS engine from you. Thanks
O2 is offline   Reply With Quote
Old 07-11-2007, 12:06 AM   #34
thamjk's Avatar
the crankshaft looks very clean, smooth and nicely done.
whats the white color you used to create the turbo scope.
Is that any where we can order that crankshaft from you.
Serpent 710
Nova MAX
3PK
Old 07-11-2007, 12:18 AM   #35
gansei's Avatar
Originally Posted by O2 View Post
gansei,
yes, i went to Femca 2007 in Indonesia.
my car is G4S. i ranked 16th in Heat, 21th in Final.
But it was very difficult race for me.. it was my first oversea race
and i could not find proper car setup..
and. i am not GR engine dealer.. only GR driver..
you can buy it in E-bay (start price is 199.99 USD)
MY SPONSORS:
Old 07-11-2007, 12:23 AM   #36
gansei's Avatar
it is transparent silicon.
for buy it... pls contact handpiece by PM
i am not GR employee.. only GR Driver..
GR homepage (english version) is under construction..
http://www.grracing.co.kr (Korea version) is available..
MY SPONSORS:
Old 07-11-2007, 12:48 AM   #37
gansei's Avatar
this is GR TOP TS12 engine's Driving Movie in last year
http://flvs.daum.net/flvPlayer.swf?vid=cVTDtrRmK7A$
yellow car is GR engine car.
But GR engine have more power in Team Version
MY SPONSORS:
Old 07-11-2007, 01:19 AM   #38
CIMRI's Avatar
handpiece,
you got pm
CIMRI is offline   Reply With Quote
Old 07-11-2007, 02:30 PM   #39
bozla's Avatar
Do the engines normally go for $200?
bozla is offline   Reply With Quote
Old 07-11-2007, 10:06 PM   #40
gansei's Avatar
yes.. But GRracing discount OS TZ for public relations.
MY SPONSORS:
Old 07-13-2007, 11:08 PM   #41
Send a message via MSN to handpiece
Default 12TZ-5(P) Team MOD + Hard black coated crankshaft
handpiece is offline   Reply With Quote
Old 07-16-2007, 05:10 AM   #42
CIMRI's Avatar
Default Team vers.
Hi ,
I have recevied my engine. Great service. This engine looks like master of piece. What for a break-in did you prefer. Pls let me now? Is this engine % 25 nitro ready ? Should I shim the head?
thnx
Old 07-16-2007, 06:54 AM   #43
Break in and Driving fuel => 25% OK!
Head shim
Break in => 0.3mm
More than 30% => 0.3mm
25%~30% => 0.2~0.25mm
20%~25% => 0.1~0.2mm
16%~20% => 0.1mm
Thanks.
Old 07-16-2007, 11:54 AM   #44
CIMRI's Avatar
Head shim
Break in => 0.3mm
16%~20% => 0.1mm
Thanks.
@handpiece .Ok. How about break-in. What is the break-in methode for this engine?
@gansei : what for a break in did you prefer
Old 07-16-2007, 12:34 PM   #45
gansei's Avatar
1 when starting a new engine follow the set up instructions first! Start the engine and let idle at a moderate speed for two or three minutes. Then shut it
down and let it cool for a few minutes. Be sure the piston is not at the top. Repeat this procedure three or four times.
2 Now run the engine on the track, making sure the engine is rich. You should hear a “four cycle” sound. Be sure to let off the throttle going down the
straightaway once or twice so the engine is not straining in its rich condition. Repeat this procedure for three or four tanks of fuel, letting the engine
cool several minutes between tanks. Also, check the glow plug often. It should look new (shiny wire that is not distorted).
3 You can now start leaning [turn clockwise] the maximum needle a little at a time in one hour increments [imagine the needle like the hour
hand of a clock] checking the glow plug often. [I use a glow igniter with a meter on it] I recommend running a few more tanks a little on
the rich side before “Race tuning” When tuning for maximum performance [Race tune] adjust until engine will reach Good RPM then open
needle 1/8 to 1/4 turn.
4 set the low end or idle:
4.1 After getting top end set close, bring model in, listen to the idle. If it is idling fast then it slows down in a few seconds, it is probably
too RICH on the bottom (minimum spray bar). In that case, make it more lean (turn clockwise ¼ turn), then run another lap and
bring the car in again.
4.2 Repeat this procedure until the idle stays high for at least 10 to 20 seconds; at this point readjust the aircrew so the idle is at a
moderate speed. The wheels should not turn, and the clutch should be fully disengaged.
4.3 If you had to turn the minimum spray bar in more than two or three more turns recheck the slide adjustment! [Picco Torque
carburetor only]
5 you may need to repeat steps 3 and 4 several times to achieve the “perfect tune”
Be patient. Tuning is the hardest part of gas racing, and is the first secret to race winning results. If you are a beginner, it is highly
recommended that you ask your hobby shop or an experienced modeler for help.
Three last tips
1 Be sure engine is warmed up before tuning
2 always tune from rich to lean. When in doubt, richen up the maximum needle (top end)
3 If you have to turn minimum spray bar (low end) in more than three to four turns from flush, it is a indication the slide adjustment is too loose and
needs resetting (Picco Torque carburetor only).
MY SPONSORS:
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
GO Tech 21R/PRO BUGGY GRracing Ver. Team Modified Engine handpiece Nitro Off-Road 7 07-27-2007 08:15 AM
35+21 modified engine chicky03 R/C Items: For Sale/Trade 6 08-22-2006 01:42 PM
35+21 modified engine chicky03 R/C Items: For Sale/Trade 4 08-17-2006 12:33 PM
Best non modified engine Jye Onroad Nitro Engine Zone 27 07-25-2005 01:42 PM
