Old 04-26-2003, 04:30 PM   #1
Default MT12 leaking
I bought MT12 used and when I put after run oil inside it some oil is leaking on the front bearings. Is it suppose to be like that? The guy whom I bought it from told me that it wasnt leaking when he shippped it and I should run it and see if the leak is still there. If that doesnt solve the problem I have to buy front bearings for it.
penggoy is offline   Reply With Quote
Old 04-26-2003, 05:44 PM   #2
chippy's Avatar
Default Re: MT12 leaking
Sounds like your up for a new bearing but thats the problem with buying second hand usually works out better just to buy new in the long run.
chippy is offline   Reply With Quote
Old 04-26-2003, 07:34 PM   #3
rrgt_kid's Avatar
the after run oil coming out from the front bearing is normal mate so dont worry at all ive had new motors do this ! All it is the after run is over flown in your motor.just remember before you start it take the glow plug out then give it a few turns over with you starter box! and watch out for your eyes! then put the plug in fill ya tank then prime put the glow on then you should be away and going. Besides its a good thing any way atleast you know the after run is doing its job properly!
Jeremy.
rrgt_kid is offline   Reply With Quote
Old 04-26-2003, 11:14 PM   #4
this is normal? coz Im thinking if after run oil is coming out then fuel will come out too and also this will be a source of air leak.
BTW whats the starting point of its needles when breaking it in? I saw in another thread that I should not touch the midrange adj ustment needle, right?
Old 04-27-2003, 01:38 AM   #5
rrgt_kid's Avatar
set the bottom end 1 1/2 turns out the top set at flush then another full turn out, mid should be set flush with carby barrel. only touch mid if know what you are doing. i only touch the mid to fine tune to the tracks i run at.
jeremy
Old 04-27-2003, 02:30 AM   #6
me43's Avatar
acctually if FUEL is coming out of the bearing then you might need a new piston and sleeve because that is a symtom(spelling?) of a lloss of compression because when the piston trys to compress the fuel and air then some preasure leaks to the crankshaft, pushing oil and fuel out of the bearing
me43 is offline   Reply With Quote
carb leaking? keavze Onroad Nitro Engine Zone 0 06-23-2008 07:18 AM
Leaking nb16 vitor Singapore R/C Racers 21 10-08-2006 12:45 AM
OS cv-rx .12 leaking oil profusely(HELP) BUDRACER1 Nitro On-Road 6 10-22-2003 05:52 PM
STS MT12 vs NOVA/MUGEN MT12 jscamry Nitro On-Road 17 04-03-2003 05:47 PM
MT12 and MT12 turbo on ebay (cheep)!!!! carpet_killa Nitro On-Road 0 02-23-2002 07:44 AM
