Old 07-05-2007, 02:10 PM   #1
Default Protoform Wings Screws
Racers how do you all hold down your protoform wings other than using those cheap screws included with the Lexan ?
jelayne is offline   Reply With Quote
Old 07-05-2007, 02:24 PM   #2
CurveTracer's Avatar
Default Wing screws
I use #6 screws, washers and self locking (nyloc) nuts that I purchase from Ace or Sears hardware stores. I also cut a strip of modelers plastic to place between the wind and the body mount to add strength. If you have a wind that can be raised and still meed ROAR specs I add the nylon posts for that purpose.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 07-05-2007, 02:55 PM   #3
I made the mistake once to use them and the wing came off!
deceiver is offline   Reply With Quote
Old 07-05-2007, 04:20 PM   #4
nitrodude's Avatar
I've never had a problem with them. And I tend to carwheel the car a lot.
nitrodude is offline   Reply With Quote
Old 07-05-2007, 04:24 PM   #5
GHETTOTEACHER's Avatar
I use the Protoform molded wing with the cheap screw kit and Shoe Goo. I never had a problem. When the body is done, unscrew the wing and pop it off.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 07-05-2007, 09:04 PM   #6
Thanks guys, my major issue with sedan screws are that they easily strip when putting them on, but especially when you are removing them to reposition the wing.
Old 07-05-2007, 09:19 PM   #7
JMGarrett's Avatar
Send a message via Yahoo to JMGarrett
Default screws
what i do is thread the plastic nuts with my 440 tap before i put them on and i have never had a problem. but i just hold the bolt with the wrench and turn the nut with a driver after i thread it.
JMGarrett is offline   Reply With Quote
Old 07-06-2007, 06:45 AM   #8
SlamMan's Avatar
Those little aluminum screws are a joke. It's impossible to screw them in without stripping the head.
I found that if you hold the screw in place with a pair of pliers and screw in the nut with a socket it works fine and won't come out.
SlamMan is offline   Reply With Quote
Old 07-06-2007, 08:53 AM   #9
32819toon's Avatar
I find the screws too long and have to cut them.
32819toon is offline   Reply With Quote
Old 07-06-2007, 09:21 AM   #10
dnitro's Avatar
The screws are standard size 5/32". Most of us use metric 2.0mm and strip the head. They do strip very easily but if you use the standard size, it will still work. I've done it a few times.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 07-06-2007, 09:25 AM   #11
SlamMan's Avatar
I've got a standard hex set and they still strip every time. The hex fits tight at first but it lets go as soon as the tension builds up. I usually start with the hex key and turn till the head strips, then grab it with a wrench and finish from there.
Old 07-06-2007, 10:29 AM   #12
Loveless's Avatar
Default stripped screws.
What i found out that works for me is to open the nuts supplied with the body with a drill bit just a tadd bit bigger than the screw and they wont strip out anymore, and oh yeah make sure your using the right size allen wrench that makes a huge difference it should have no slop in it at all, those screws are very soft, well good luck.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 07-06-2007, 11:25 AM   #13
JayL's Avatar
I bought a brp once and it came with stainless screws plastic nuts and little spacers to move the nut down low enough to grip..I use that for all my wings now.
Just bought the plastic setup from rp may try that next:
http://nexusracing.net/product_info....4270a5e421bc92
JayL is offline   Reply With Quote
who wants some hot wings?? roadrashracing Chat Lounge 7 06-30-2008 05:44 PM
Protoform molded wings. Buck Nasty Electric On-Road 25 09-22-2006 05:45 PM
Titanium screws / Aluminum screws ? rcnewb2004 Electric On-Road 26 05-22-2006 09:45 AM
Is the Xray T1R screws Ti or standard screws FUK_WRX Australian Racing 4 03-30-2004 06:18 PM
Protoform Molded Wings TurnNBurn Electric On-Road 6 08-29-2003 01:48 PM
