Old 04-25-2003, 01:33 PM   #16
o
DanielSon is offline   Reply With Quote
Old 04-25-2003, 01:44 PM   #17
Corse-R's Avatar
Originally posted by DanielSon
Con-rods fail. They are designed that on purpose, They gotta make money somehow. You only speak of basic alloys that are well known to the public, there are way better alloys that are not widely used that exceed 7075 and other aluminum based alloys, and what condition of 7075 do you speak of?
Danielson:
I not negate that conrods fail, but there's a such high probability that you should change it due to bushing wear than a snapped unit. Engine manufacturers refrain on putting weak elements on their engines, are the faulty use that makes it break (heard some quite big freerevs on the boxes and on my internals said, blow it please, blow it please) some people thinks that doing such manouvers will show how 'powerful' and how noisy are their engines.
Changed my last conrod on an engine with more than 7 gallons thru it (a Sirio .21 AAC) who uses a 'weak conrod' said by some people who broke one.
Well, if you plan to dig on 'exotic Aluminium alloys' like 7450 and such similar, go yourself and put a quote for a billet/rod of those type of alloys (probably they force you to order a minimum weight and probably excessive for you.
The problem with blowing conrods is fixed putting a larger 2nd gear that lowers a little the rpms as told time ago popsracer not a harder conrod that probably break the crank nipple.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 04-25-2003, 02:02 PM   #18
Old 04-25-2003, 02:17 PM   #19
Jonathan's Avatar
Corse-R
Quit being a condescending know it all man! You are making yourself look silly. BTW... I don't think anyone is really impressed by your credentials....except yourself.
Pops.. you're right about gearing up to preserve a rod, but the downside of course is losing some aceleration. What's more important...I guess....or built a stronger rod.
Jonathan is offline   Reply With Quote
Old 04-25-2003, 03:59 PM   #20
kickass's Avatar
corse-r RELAX this thread was created to spread knowledge and to provide people with another option.
As far as gearing is concerned ive been racing for over 12 years have won 5 Australian titles, am a team sponsored driver.
7 of those twelve years have been at the same track, what im trying to say is that we think we have worked out what gearing to run but thanks all the same.
I dont know if its in your nature but try to be constructive not destructive oterwise theres plenty of other threads out there.
Danielson thanks for your reply, i am very interested, i will PM you my email, if you can email me some details thanks.
PS im off to another major meeting interstate, so ill be off air for a couple of days cheers.
kickass is offline   Reply With Quote
Old 04-25-2003, 04:03 PM   #21
taco bell
Old 04-25-2003, 04:45 PM   #22
Francis M.'s Avatar
most rod failure is when the brass bushing
wears out. The problem with using a harder
material for the bushing would be wearing
out the crank pin. if you are snapping rods
then maybe the ti rods would be a good
idea, from my own experience most of my
rods wear out from the bushing. I usually
change the rod once after that you might
want to check out the tolarance on the
crank pin also.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-25-2003, 04:48 PM   #23
soft taco no cheese
Old 04-25-2003, 05:22 PM   #24
AMGRacer's Avatar
9/10 rod failures (excepting the picco ones) are due to the brass bushing not getting enough oil or the brass bushing to pin gap becoming too large.
Titanium rods will not prevent the bushing detonating and showering your piston/sleeve with brass shards. Also most titanium will stretch more than aluminium under higher loads reducing head/piston crown clearance.
To answer the question from kickass I have tested a MT12 aftermarket rod from Carlsen Tuning and it was great. However I have never done a rod in a Nova anyways.
AMGRacer is offline   Reply With Quote
Old 04-25-2003, 06:45 PM   #25
rrgt_kid's Avatar
with novarossi 12 engiens the conrod it self doesnt stretch at all its only the bushing that lets go. 21 size engiens are a different story thought but if a 12 size if racing once a fortnight the rod should be replaced once every 6 months or before a major race event!
if your local hobby shops tell you it should be replaced every couple of race meets ,that bull and they want to make money out of you all, unless if you abuse the motor!
ive never ever done a rod but ive worn out a jp crank on the big end journal.
jeremy
rrgt_kid is offline   Reply With Quote
Old 04-25-2003, 08:53 PM   #26
Manticore's Avatar
R/C Tech Charter Subscriber
Ti rod? i wanna laugh !! it if does "work", it only degrade the performance of your engine. what is the density of Ti alloy compare to Al alloy? Not to mentioned about the heat characteristic of Ti. If Ti is the right material, you would not be the first person to name it for this purpose. Brass is used for the bushing because brass is soft enough to protect the crank pin from wearing. high grade brass is expensive. do you really understand engine design?
many ideas were bought up such as ball race bushing but the engine manfactorers always go back to alloy rod with brass bushing. Piston ring design but no one use it now. boost bottle and who wants it anymore? Those are "constructive" but not practical. Race engine is high wear engine.
I remember there are aftermarket rods from paris racing as well as Asso R&D (long times ago) and they do use alloy rod with brass busing but with beefed design.
Manticore is offline   Reply With Quote
Old 04-25-2003, 10:05 PM   #27
AMGRacer's Avatar
jeremy
Trust me the do stretch if you rev them hard enough.
Old 04-25-2003, 10:15 PM   #28
Old Skool's Avatar
Who said that the rod end itself doesn't go?
Old Skool is offline   Reply With Quote
Old 04-25-2003, 10:24 PM   #29
AMGRacer's Avatar
Thats the exception to the rule for sure. I assume you had a runaway?
Old 04-25-2003, 10:50 PM   #30
rrgt_kid's Avatar
well that pic doesent look like you ran your motor at normal temp and under normal running coditions. or it was a runaway! by the way is that from a 3.5 motor???
jeremy
(WTA)3PKS PCM RX brand new market price in market now. sangyi41 Malaysian R/C Racers 0 03-20-2007 12:13 PM
WTB Collari rods Darrell Skelton R/C Items: Wanted to Buy 1 04-02-2006 10:49 PM
TT-01 Tie Rods browncolin Electric On-Road 2 01-05-2006 08:43 AM
Connecting rods EdwardN R/C Items: For Sale/Trade 8 10-29-2004 10:39 AM
Tie rods karter Electric Off-Road 0 08-28-2004 12:56 AM
