Old 06-28-2007, 10:14 AM   #1
Loveless's Avatar
Default MRX4R REAR UPPER SHOCK POSITION
CAN SOMEONE TELL ME WHICH HOLE DOES THE REAR UPPER SHOCKS NEED TO BE IN, I INSTALLED THEM WHERE THE SET UP SHEET SAID TO, AND I RUN AT CRYSTAL AND SOMEONE TOLD ME FOR THAT TRACK INSTALL THEM IN THE SECOND HOLE DOWN FROM THE TOP...
hOW U LIVING...
Loveless is offline   Reply With Quote
Old 06-28-2007, 12:32 PM   #2
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Just leave them in the 2nd to bottom hole. Front in the middle hole.
The stock setup should get you around fine. There are plenty of drivers there running Mugen cars, if any help is needed im sure someone will be there to give you a hand!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 06-28-2007, 01:33 PM   #3
Loveless's Avatar
Thanks dogg, good looking out.
How u living...
*** JACO 1/8th rear foam tires *** MRX4R EVOLA evostyle R/C Items: For Sale/Trade 17 02-26-2009 08:16 AM
MRX4R REAR ADJUSTABLE SWAYBAR Loveless Nitro On-Road 1 03-02-2008 08:35 PM
Rear Wing Position..... Skiddins Electric On-Road 2 04-30-2006 09:25 AM
Urgent, Need Rear MBX5 rear shock body Izze-Racing R/C Items: Wanted to Buy 0 04-16-2006 03:48 PM
Shock Position settings ???? speed6 Electric On-Road 5 11-02-2005 12:09 PM
