Old 04-24-2003, 08:34 AM   #1
Default Tyres??
Halo need some help from u guys.I juz bought a V-one-s and I want to change the orginal stock slicks tyres to sponge tyres. I need to find out wat tyre numbers should i use, how much for 2 pairs, does it comes together wif rims and where to get??
FlyinMozart is offline   Reply With Quote
Old 04-24-2003, 09:29 AM   #2
Send a message via AIM to AndrewtheRCman
Jaco makes premounted foams. this might be your best bet for easy foam tires
AndrewtheRCman is offline   Reply With Quote
Old 04-24-2003, 09:34 AM   #3
Corse-R's Avatar
Default Re: Tyres??
All depends on which surface you may run with your car.
Foams have advantages and such disadvantages.
Advantages:
- Consistent grip and handling all the life of the tyre.
- Longer duration and grip than a comparable rubber.
- Comes premounted and glued (so much less mess and glued fingers, sheeesh!).
- Cheaper than a comparable rubber set and less voodo with the rim and inserts stiffness.
Disadvantages:
- May score and chunk if you brush boards.
- If you're racing seriously, you may need a tyre truer to cut the wheels (if not, you can start as they come from the box and start to use it).
Regarding hardness is what I said, depends on your surface, but I bet for a set of 37/37 or 40/40 (front and rears).
I don't know (check on the appropiate thread) if your rear uprights can accept 30mm rear foams.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 04-26-2003, 12:38 AM   #4
Send a message via ICQ to V-One S
I will say this:
The V-one S cannot accept 30mm rear foams with out some modification
if u r going to race, c if the surface is prepped or not.
if it isnt, do not run foams
most people that i know, run their S on Rubber.
the best tyres for the S are Takeoff 27's, and 32's or a combination of both.
But pop on over to the V-One S thread
others there r even more helpful and enlightening.
and if u r just mucking around on the street, USE RUBBERS.
V-One S is offline   Reply With Quote
Old 04-26-2003, 01:03 AM   #5
squizzytaylor's Avatar
Default Re: Tyres??
Most common combination regardless of whether its prepped or not are generally 45 front and 40 rear, its a good all round combo and Im yet to see a track that it doesnt run well on.
gt
squizzytaylor is offline   Reply With Quote
Old 04-26-2003, 01:05 AM   #6
xax
I want to use larger rear tyres like those on serpent so how to do it?
xax is offline   Reply With Quote
Old 04-26-2003, 01:08 AM   #7
xax, it is written in the V-One S forum if u bother to search thru it.
u have been told a couple of times in the V-One S thread it is back a couple of pages.
Old 04-26-2003, 06:32 AM   #8
sausage_link's Avatar
Send a message via ICQ to sausage_link
Yep
sausage_link is offline   Reply With Quote
1/10 Foam Tyres - Twister Tyres LogiK Australia For Sale/Trade 4 08-13-2008 05:25 PM
Help with tyres tim fry Electric On-Road 3 04-03-2006 07:57 AM
FAST TYRES & ELLEGI TYRES 4 SALE Thunder racer Australia For Sale/Trade 2 03-02-2006 07:43 AM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 11:02 AM
New Tyres Durge Australian Racing 15 05-30-2003 08:14 AM
