Old 06-16-2007, 05:22 PM   #1
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
Default Glo-Plug
I am putting together a box that will step down the 12v from my power supply to about 1.5v to ignite my glo-plug. I should just have to hook a wire up to the top of the glo plug and then to ground on the car to ignite the plug correct? Any reason not to do this?
[email protected] <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 06-16-2007, 08:00 PM   #2
kcrunchone's Avatar
Reason not to do it :
HOT SHOT GLO PLUG IGNITOR ! ! ! !
I keep 2 on hand and they last for ever........
On the other hand if this is something you want to do and have invested in the project go for it....
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 06-16-2007, 08:32 PM   #3
Moderator
pc9840's Avatar
Default Project.
Yeah, I'm mostly just wanting to do this little project.
Old 06-16-2007, 09:10 PM   #4
Trader Rating: 18 (100%+)
Default Glo -Plug
You can buy pre made panels that already step down the voltage to 1.5, but almost everyone I know does not use them because even the factory pre -made panels burn up glo-plugs like crazy.
Shops like Hobby People sell these pre-made panels, and you cut cut them into your starter box.
Also if you are thinking using your chassis as a ground, you may cause a bad glitch in your radio/receiver.
But I quess you never know until you try
brc358 is offline   Reply With Quote
Old 06-16-2007, 09:25 PM   #5
kcrunchone's Avatar
I dont suggest the chassis ground use a dubro ignitor and make your circuitry separate. Or just take 6 3800 and hook them in parallel and avoid circuitry altogether the voltage will remain a 1.2 and you have no damage to the electronics.
Rick Hill
Old 06-17-2007, 07:14 AM   #6
keavze's Avatar
sorry might be off-topic but just wana chk how long (hours) can a glo plug lasts?
keavze is offline   Reply With Quote
Losi/GRP Non-Tuned (Standard Plug) .21 vs the Tuned (Turbo Plug) .21 jsmax Nitro Off-Road 0 07-07-2008 08:17 PM
which plug chrisw Nitro Off-Road 2 08-26-2007 08:35 PM
What plug for JLR RED DOT .12? BIGTACO Nitro Off-Road 3 08-02-2007 02:42 PM
Turbo plug Vs Standard plug mrhenning11 Electric Off-Road 1 04-16-2007 09:20 AM
Turbo plug vs standard plug shortygy Onroad Nitro Engine Zone 5 08-13-2004 04:10 AM
