Old 06-14-2007, 07:12 PM   #1
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default G4S clutch upgrade?
Hi just got a new team magic G4S anyone got any suggestions on the best upgrades for this car I see that Kfactory do a few any suggestion?
aussies1129 is offline   Reply With Quote
Old 06-14-2007, 09:27 PM   #2
rcrevolution's Avatar
Send a message via AIM to rcrevolution
ummm if you have the g4s, you have the ufo clutch which is arguably the best clutch on the market, so I dont know why you want to upgrade
rcrevolution is offline   Reply With Quote
Old 06-14-2007, 10:33 PM   #3
I added the speedshot front end to give more adjustability with roll centre and the diff is much easier to access.
If you don't have the ED transmission then that is another great upgrade.
Johnny9s is offline   Reply With Quote
Old 06-15-2007, 12:13 AM   #4
razzor's Avatar
Bud id suggest getting out with teh car and getting stick time under your belt before making hop ups.
If anything on the G4S is needed id suggest starting with getting 18t pinion for the first gear and spare spur gears to play around with gearing.
It would be also good to get the 20t brake and side pulley with 26t front side pulley this makes the cars bottom end more responsive.
as for the clutch just a hard clutch spring is needed like the 1.8mm black Kfactory clutch spring or a Mugen super hard.For the rest of info you need check out or ask questions on teh G4S thread ,the guys will help you get sorted
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-15-2007, 07:13 AM   #5
very helpful info guys (razzor)anymore suggestions would be great!
sorry but I have only been doing offroad and am a bit inexperience in onroad thanks!!!
Old 06-15-2007, 07:29 AM   #6
i had ordered the mugen super hard spring for my mongoose should I take it off and put that on the g4s? does it make that much of a difference?
Old 06-15-2007, 07:45 AM   #7
dnitro's Avatar
rcrev,
Take your time practicing with the kit first. Play around with the clutch settings such as gap, end play, clutch weights, spring adjustment and find out how all this come into play. Just because the next guy got the Mugen spring doesn't mean you have to. The Mugen spring is well suited for high traction tracks. If you put in your the Mugen spring and your track (or parking lot) is slippery, you'll likely do a bunch of donuts. If your track does high grip, you will see a more punchy response, and the car will take off like a rocket. (given that you set your clutch correctly). I've been using the stock yellow spring myself. I do have the Mugen hard spring, but the yellow seems to work for me.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 06-15-2007, 08:02 AM   #8
razzor's Avatar
Bud just as Dnitro said and i said initially ,get out and run the car and be prepared to play with settings to learn and see what the differences do.
Other suggestions i made is if you get sorted and are looking for a bit more performance they would work but as D said its dependant on the type of track you run on.
Casterracing ZX1.5R
Old 06-16-2007, 12:31 AM   #9
hey guys I was looking through the exploded parts diagrahm for my g4s and the clutch system is a 3 shoe teflon not a ufo like some one said! anyone got any suggestions?
Old 06-16-2007, 07:13 AM   #10
Pattojnr's Avatar
Trader Rating: 19 (100%+)
you must have the RTR G4S. you may want to get the UFO clutch for sure. or you can try to play with finding harder springs for the clutch you have. some times you can find the 1.2 springs or try to lighten the 3 shoes. like drill small holes in the teflon shoesto lighten them. this will make the engagement later.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-16-2007, 12:55 PM   #11
razzor's Avatar
If its a normal 3 shoe clutch then get some 1.1mm springs and some ally shoes.Put one ally shoe in the clutch with replacing all springs to 1.1mm ones.
Casterracing ZX1.5R
Old 06-16-2007, 05:10 PM   #12
got it thanks razzor I will give the existing clutch a few runs then change it over what run in time is suggested for that engine as it dosent say anything anywhere?
cheers!
Old 06-17-2007, 03:57 AM   #13
razzor's Avatar
Let the engine high idle a full tank and then run 4/5 tanks at half throttle and graually bring it up to temp/performance.You could also do the Cyrul wide open throttle method ,it is worth the extra effort.
Casterracing ZX1.5R
Old 06-18-2007, 06:39 AM   #14
hey razzor you mentioned about alloy clutch shoes and 1.1mm springs I have tried to find them but cant, do you know who sells them?
Thanks heaps!
Old 06-18-2007, 07:00 AM   #15
razzor's Avatar
dont see why it should be hard to find as most 1/10 and 1/8 buggies use them ,even the gas trucks.They are not car specific so most hobby shops should have in stock.
Id suggest trying 1mm springs first and then 1.1mm.
Casterracing ZX1.5R
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 10:24 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 03:54 AM
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 01:34 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 09:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
