Old 04-21-2003, 11:20 AM   #1
Default AE start box
Will the AE start box start the stock NTC3 rtr engine? Or do I need to change the fly wheel or lose the pull start thing?
nitrosaurus is offline   Reply With Quote
Old 04-21-2003, 01:57 PM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
No it will not. The RTR motor is a pullstart and has a much larger flywheel. You would have to change the flywheel to the non pullstart flywheel and remove the pullstart. Really quite a pain. I would just leave it as a pullstart or get a non pullstart motor. That would be the easiest.
Later
CRASH is offline   Reply With Quote
Old 04-21-2003, 05:22 PM   #3
che
che's Avatar
Yu will also have to change to motor mountsto the lowered ones in order to use the bump box properly.
che is offline   Reply With Quote
Old 04-21-2003, 05:50 PM   #4
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the flywheel diameters are different because of the hgt of the motor mounts...short mounts,small flywheel...tall mounts(to allow clearance of the pull starter) large flywheel.....either one can be started with teh box.they both stick out oof the chassis teh same amount...the only thing you want to be carefull of that you don't want to spin the motor the wrong way..you'll break the pullstarter..(cause of the one way bearing)
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-21-2003, 06:01 PM   #5
GP40X's Avatar
Quote 1
Quote 2
Nitrosaurus
Don't worry about the nay-sayers. I HAVE a Nitro TC3 RTR with the Associated .12 Pull-start SG Crankshaft engine & I use an Associated Starter Box to start it on race day. The pull-start is still attached & it still has the pull-start flywheel & pull-start engine mounts. I will eventually convert it over to a non-pull-start engine as soon as my backordered Associated conversion backplate kit comes in (eliminates a possible souce for an air leak). I MAY go ahead & buy the non-pull-start mounts & flywheel at that time but it is NOT necessary to convert it to the non-pull-start mounts & flywheel to use a starter box. Those parts will just allow the engine to sit lower in the chassis (lowering the engine does give a slight advantage due to a lower CG) The AE starter box works just fine with the RTR pull-start engine.
BTW, converting the motor is not a pain. Just get the non-pull-start backplate kit, cut the pull-start pin on the crank & slap the new plate on (this will require disassembling the engine & removing the crank. It will also require a Dremel tool to do it right). When I pull the engine down to cut the pin on the crank, I also plan on doing a little "Sleeve & Crank work" along with installing a AE/O'Donnell's Team head & an O.S. slide carb as a little experiment (hey the motor was basically free with the car so it gives me a chance for a little "Port & Polish" practice). Can ya say "Sleeper?" Sure ya can.
Hehehehehe
Bill (Nitro TC3 RTR Racer )
GP40X is offline   Reply With Quote
Old 04-21-2003, 06:04 PM   #6
fastharry™'s Avatar
all right GPX!!!!..a man that does a little research......
Old 04-21-2003, 08:58 PM   #7
I used to start my rtr with my starter box and i never changed anything... then i removed the pullstart and oneway bearing just to reduce weight and it ran like that... then i used my lower mounts and smaller flywheel and all it did was make it start a bit easier because of the differents in wheel ratios... bigger flywheel fewer engine rotations for each starter rotations so the smaller the wheel the higher the box will rev it...
ImportRacer1187 is offline   Reply With Quote
Old 04-22-2003, 06:44 AM   #8
che
che's Avatar
Arrow
I am not 'naysaying', I was just referring to CRASH's post about changing to the smaller flywheel.
My response was that if he changed to the smaller non-pull start flywheel, he should also change to the lower motor mounts at the same time.
I never did say the pull start setup would not work ...
I should have used 'gooder' wording.
Old 04-22-2003, 07:44 AM   #9
RedScorp's Avatar
Send a message via ICQ to RedScorp Send a message via AIM to RedScorp Send a message via Yahoo to RedScorp
I hate to tell you this but "polishing" only hurts performance of an engine. As they found out back in the 60's when it became popular and people didn't realize the drawbacks, it significantly reduces the turbulance within the motor. When you smooth something out like that, you take away the turbulance essentially reducing the air/fuel mixture causing the motor to run worse than if you had left it alone.
RedScorp is offline   Reply With Quote
Old 04-22-2003, 05:01 PM   #10
GP40X's Avatar
RedScorp,
"Port & Polish" is a generic term that I picked up back in the days when I was still building Hot Rods & 1:1 racing engines (yes, that does date me). I have port matched the intake ports and pocket ported many a Chevy small block head valve pocket in my day & you are right. You dont want the intake runners too smooth because the lack of turbulance in the intake ports would actually allow the atomized fuel to form larger droplets & "drop-out" of the airflow stream. I did find that polishing the exhaust some helped get the spent air-fuel mixture out better but you also have to take the header design into consideration.
When I cut the sleeve & the case for the intakes, it will be more of a port match & trying to direct the flow into the cylinder, Any "Polish" work will be mainly deburing & softening edges. The only serious polishing will be to the exhaust manifold to help get the hot gasses out (That's also the cheapest part to replace if I screw up. ) Now back to the starter box discussion.
Bill (Nitro TC3 RTR Racer)
Old 04-22-2003, 05:19 PM   #11
fastharry™'s Avatar
RedScorp,
still wish you had your Tri- Power GTO,don't ya.....
Old 04-22-2003, 07:25 PM   #12
GP40X's Avatar
No, I actually want my "Harem" back:
70 Pontiac GTO "Judge" Ram-Air 4 & a 4 speed (blown up late one night in a little demonstration of speed, OUCH that hurt) Fell in love, got married & never fixed it (sold to someone that it made their eyes light up when they first saw it so it went to a good home).
70 Buick GranSport 455 Stage 1 (with all the Kenny-Bell goodies I added including the switch-pitch stater torque converter for the Turbo 400). I sent her to car heaven in 1984 after she made a HARD left turn at the 180 foot mark when the left rear axle snapped & that one let me spend some time in the hospital & the guy in the left lane wet his pants when I took the front end off his car too (I was in the lead by a fender & about half a door when the axle let go & wound up puting us both in the guardrail. She rolled 5 & 3/4 times. We tore up about 140 feet of very stout guardrail). Wife kind of put her foot down after that one (I still have back problems from this one & the hospital bill was a little steep at the time)
78 Chevrolet Z-28 with lots of Gustard & Herb Adams suspension parts. (had to sell it for marital bliss & I quote my better half here "It starts too fast, it stops too fast, the exhaust is too loud, it rides so rough every time I hit a bump, I have to go pee"
Oh to be 21 & single with LOTS of free money again. Insurance was cheap & I could keep three cars & a pickup (to haul my tools when I changed jobs turning wrenches) happy.
My last real project car was a 85 Monte Carlo SS (sold after I became a GrandFather )
Now my need for speed is satisfied by a Nitro TC3. Not a poor second but just different. I also don't have to spend time in the hospital when I roll it DOH
Bill (NItro TC3 RTR Racer)
Old 04-22-2003, 07:33 PM   #13
fastharry™'s Avatar
you don't have to take it to a chassis fabricator every time you want to change running gear either...
Old 04-28-2003, 11:28 PM   #14
Donn's Avatar
You can use it on the NTC3 RTR and it will work with out changing anything, but you will have a small narrow contact point with the Pull Start flywheel. And do keep and I on the wear of the flywheel.
Hey Harry, did you make that race yet.....Guess who this is...
Donn is offline   Reply With Quote
Old 04-29-2003, 05:12 AM   #15
fastharry™'s Avatar
big don..this weekend...welcome aboard....
make sure you hit the TC3 nitro forum also...
***Traxxas EZ Start 2 handheld starter and 4 ez start systems*** MattP R/C Items: For Sale/Trade 6 08-18-2007 07:49 PM
TRX 2.5 w/ pipe, header, Roto Start backplate, Complete EZ Start system milt R/C Items: For Sale/Trade 4 06-29-2006 04:29 PM
Wanted Pull start/roto start for collari .30 seajj2 R/C Items: Wanted to Buy 5 08-31-2005 05:51 PM
Exactly how do you start a pull-start motor? <Don't flame me because I'm dumb!> Vyrus Track Locator Forum 1 08-20-2004 06:39 PM
wheels start spinning right after engine start ( on idle ) slavka Nitro On-Road 2 06-24-2002 12:48 PM
