Old 03-25-2005, 05:41 AM   #12166
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by drfritz
they may be light,but they are not the best thing to run up front, little on the weak side if you ask me, good to go in the rear but I'll think you might want something with a little more meat on them up front.
i agree with you...better stick with steel shafts that came with the kit...it's more durable... your car may not be light (duh!!! just a few grams off) but you are able to finish the race without problems...
doki_doki is offline   Reply With Quote
Old 03-25-2005, 05:44 AM   #12167
doki_doki's Avatar
Originally posted by jhigga15
What is the difference between the V-one rr and the V-one r? I am giong to trade my pro 4 for a V-one rr...Is it worth getting?
as for my experience...it's worth getting the v-one rr than the r. the rr comes with a centax clutch which is easier to tune compared to the regular clutch. also, the rr has floating body mounts similar to 1/8 on road kits as mentioned earlier TRAJ. but be careful not to be hit hard on the rear ends since the floating mounts break....
Old 03-25-2005, 08:08 AM   #12168
InitialD's Avatar
Default Re: Re: Re: Help unstanding what there item do
Originally posted by tazman34685
What will it do to the gear ratio on a EVO with the 0.8 gear spacing? I'm use 21/61 for 1st and 27/55 for 2nd.
With the stock internal pulleys (2.52 internal ratio), your FDR is 7.32 for 21/61 and 5.13 for 27/55.
Changing to the 3 Racing fast gear conversion kit, your FDR will change to 5.81 for 21/61 and 4.07 for 27/55 ! That will surely gear you to the moon and give you pretty lowsy acceleration.
Changing to 20/61 will give you 6.1. Still low and would make your bottom end sluggish I think. I believe this fast gear conversion pulley set was made for the older 1.0 gearing. I believe Kyosho made a 15T pinion somewhere and pairing it with 49T 1st gear spur, you get 6.53 for the 1st gear. Pretty decent. For the 2nd gear, you can use 20/44 combo which will give you 4.4 FDR and that should already take you to the biggest of tracks.
Old 04-02-2005, 01:27 AM   #12169
Default Evo upgrade kit
I've still got a standard V1RR, and thinking of upgrading with the Evo kit from rcmart.com for about $135US.
Don't really want to spend more to get the V1RRR or MTX3.
Would anyone think i'm crazy or that it ain't a bad idea considering i'm on a budget.
Glenn is offline   Reply With Quote
Old 04-02-2005, 02:14 AM   #12170
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Send a message via AIM to kyoshoBOY
Default Re: Evo upgrade kit
its ok if you are in a budget crisis ryt now,v1rr evo is great upgade for ur regular RR,i had this car b4 and i really like it and it makes a huge diff over the RR.
i would say go for it if your on a budget ryt now,but if can or save some more money and wait to get the RRR u cant go wrong on this car,for the mean time just use your regular RR if your goin to upgrade to RRR..(its worth it to wait and get the great car)..
hope that it helps ur problem....
kyoshoBOY is offline   Reply With Quote
Old 04-03-2005, 01:35 AM   #12171
::TEAM SRGS::'s Avatar
Glenn you have a pm
Nikon D300
Olyumps E20
nikon lens
28mm
185mm
300mm
::TEAM SRGS:: is offline   Reply With Quote
Old 04-04-2005, 01:28 PM   #12172
tazman34685's Avatar
Default An Idea who time may have come
Try the front knuckle off the RRR woke on the RR Evo to help make the car steer better.
For the rear use the hubs from the RRR on the Evo to help in stabling the car in the corners.
Just a idea I came up with.
tazman34685 is offline   Reply With Quote
Old 07-01-2005, 09:50 AM   #12173
jhigga15's Avatar
I am wondering where you guys put your personal transponders on the Evo?
Thanks,
jhigga15 is offline   Reply With Quote
Old 07-02-2005, 09:20 AM   #12174
kewdawg's Avatar
Originally Posted by tazman34685
First is the motor mount question:
Stock motor mount vs 3Racing Engine Mount 3mm Screw Hole or 3Racing Engine Mount 4mm Screw Hole {What is the difference of the screw holes?
Next is the offset:
3Racing Front Swing Shaft (0mm Offset) vs 3Racing Rear Swing Shaft (+2mm Offset)
Does the offset affect how wide the wheel base is?
Last is the 3Racing Fast Gear Convention Kit
Including
1 x KV-027 Pulley Spacer
2 x KV029 Aluminum Pulley 24T
1 x KV-033 M3 384 Belt (128T) and
1 x KV-034 M3 198 Belt (66T)
What are the pros vs the Cons of this convention kit? Will is inprove the speed of the EVO for big tracks Likethis track Which we have here is FL[IMG]SUNSHINE BANDITS[/IMG]
tazman,
Where exactly is this tracK? It looks sick!!! What major city is it near? Is there a web site for this track?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-02-2005, 10:34 AM   #12175
JustRace's Avatar
Originally Posted by kewdawg
tazman,
Kewdawg....That track is located in Lakeland Florida. It's part of our State Series. Go here http://www.forgass.com/ to look at our other tracks and web site info. Click on "Tracks".
JustRace is offline   Reply With Quote
Old 07-02-2005, 11:38 PM   #12176
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default V1rr upgrade
HEY GUYS.. HAVE U SEEN THE LAYDOWN SERVO CONVERSION FOR THE RR? IT'S FROM ING RACING.. CHECK OUT THE SITE AT www.ingracing.com
ianhobbies is offline   Reply With Quote
Old 07-04-2005, 09:38 AM   #12177
Hello guys!
Someone know if the centax clutch for nitro tc3 is compatible with v-one r?
Thanks.
SpeedSerpico is offline   Reply With Quote
Old 07-04-2005, 04:37 PM   #12178
edseb's Avatar
O kay, I'm looking for a decent set up for a V-one RR, not evo. I didn't like the way the back felt with the floating body (Mazda 6), so I removed the links and locked the float so the body and affect the traction. The car still feels squirly. I've been trying to find somee downloadable set ups, but I haven't had much luck. Help, doesn't need to be downloadable. I'm looking for medium traction, asphalt, outdoor, tight layout.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 07-04-2005, 07:46 PM   #12179
ianhobbies's Avatar
Default MY RR SET-UP
ok..
front camber 2 deg.
front toe out 1.5deg
on a tight technical track use a front diff.. 50k oil
at the rear end...
toe-in 1.5 deg
rear camber 3deg
for the rear diff, clean the inside part of the diff.. remove the silicon oil.. i use an ordinary automotive grease (a full amount inside the diff) and works well!
for the front and rear springs, use hard springs(gold) if your asphalt track is mirror smooth hehe.. but if it's kinda bumpy, use silver (soft)
for the tires.. i use foams.. kind of shores depends on the track and temp. play with 40 to 42 shores...
Old 07-05-2005, 10:13 AM   #12180
edseb's Avatar
Thanks, that helps. My car has a one-way, but I'd like the option to run dif or spool, does anyone know where I can get them or if the new ones work too? Also, any links to the pros set ups for this car, I know they are probably old?
Carl Hyndman
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
