Old 01-24-2005, 09:51 PM   #12151
jihernandez's Avatar
Warning to all who are looking at extreme lightening options.
I was an avid weight reduction so to speak for a time. I have a V1R using a Sirio S12-TUP Engine.
I got those 3Racing Hardened Aluminum Shafts (middle and rear). I was under the impression that this will lighten the drivetrain and resultingly will make the car faster.
It was indeed faster but the middle aluminum shaft broke!!!
Replaced it back with the stock shaft. Then I raced.
Got Top Qualifyer and was 1st in both 1st and 2nd final heat (We din't have enough people to be pit crew). In the last heat, I had it bagged! I was a lap ahead. However, silly me, trying to still beat my best time, I pushed really hard.
to my surprise, in the straight-away, the rear aluminim Shaft broke and of course DNF the last finals heat. Landed 2nd.
Realized that stock shafts are heavier but stronger - able to withstand the revs and rpm of a strong Sirio motor.
jihernandez is offline   Reply With Quote
Old 01-25-2005, 11:10 AM   #12152
dct147's Avatar
Thanks once again TRAJ
Just one last question,
I have 2 offers from 2 different shops for the FW05S.
Which , in your opinion would be more of a bargain?
i`ll quote in AUD$ to make it easier for you.
1) About AUD$545.00 which includes :1 controller ( engine`s non- pull start )
2) About AUD$480.00 which includes : 1 controller
: 1 Fuel ( engine`s pull start)
Which model of engine, i`m not sure at all.
Which would be a better choice? or should i find out the model of engine before i make my decision?
Thanks for your help again.
Cheers!!
dct147 is offline   Reply With Quote
Old 01-26-2005, 06:01 PM   #12153
tenderfoot57's Avatar
Send a message via AIM to tenderfoot57 Send a message via Yahoo to tenderfoot57
Hey try and get the K Factory shafts I ran both front and rear shafts in RR very light and barely any ware after 25-30 race days.
tenderfoot57 is offline   Reply With Quote
Old 02-07-2005, 10:51 AM   #12154
Im buying a o.s. 12tr for my voner but dont know which manifold to get. any reccomendations for a low cost one and where to find it.
Nitromatt is offline   Reply With Quote
Old 02-07-2005, 06:49 PM   #12155
drfritz's Avatar
they may be light,but they are not the best thing to run up front, little on the weak side if you ask me, good to go in the rear but I'll think you might want something with a little more meat on them up front.
drfritz is offline   Reply With Quote
Old 03-04-2005, 01:59 PM   #12156
WAZ
Default did you remove diffs
also which belts do you run
WAZ is offline   Reply With Quote
Old 03-14-2005, 11:15 AM   #12157
jhigga15's Avatar
What is the difference between the V-one rr and the V-one r? I am giong to trade my pro 4 for a V-one rr...Is it worth getting?
jhigga15 is offline   Reply With Quote
Old 03-14-2005, 08:21 PM   #12158
TRAJ's Avatar
The main difference between a V one R and a V one RR is that the V one RR has the rear floating body mounts similar to 1/8 scale cars and also has the 3D clutch system which is better than the V one R body mounts and clutch
As to is it worth trading it depends on what the car has
The pro 4 is a nice car
TRAJ is offline   Reply With Quote
Old 03-21-2005, 06:40 PM   #12159
Will have to differ in opinion. I tried both in the spirit of trying to lighten up the drivetrain...guess what...I broke both rear and front shafts...I use a Sirio .12 5 ports engine. Went back to stock.
Old 03-22-2005, 09:02 AM   #12160
tazman34685's Avatar
Default Ebay Auction of Kyosho Evo & RR
Kyosho V-one RR (not TC3,Serpent,Mugen, nor Ofna)
Buy it NOW price is $238 plus S/h $32
Kyosho V-one RR EVO (not TC3,Serpent,Mugen, nor Ofna)
tazman34685 is offline   Reply With Quote
Old 03-22-2005, 12:46 PM   #12161
jhigga15's Avatar
Where is the best place to get extra parts for my car...I just got a used Evo
What Tips do you guys have for the car?
Old 03-24-2005, 01:23 PM   #12162
Default Help unstanding what there item do
First is the motor mount question:
Stock motor mount vs 3Racing Engine Mount 3mm Screw Hole or 3Racing Engine Mount 4mm Screw Hole {What is the difference of the screw holes?
Next is the offset:
3Racing Front Swing Shaft (0mm Offset) vs 3Racing Rear Swing Shaft (+2mm Offset)
Does the offset affect how wide the wheel base is?
Last is the 3Racing Fast Gear Convention Kit
Including
1 x KV-027 Pulley Spacer
2 x KV029 Aluminum Pulley 24T
1 x KV-033 M3 384 Belt (128T) and
1 x KV-034 M3 198 Belt (66T)
What are the pros vs the Cons of this convention kit? Will is inprove the speed of the EVO for big tracks Likethis track Which we have here is FL[IMG]SUNSHINE BANDITS[/IMG]
Old 03-24-2005, 10:46 PM   #12163
InitialD's Avatar
Default Re: Help unstanding what there item do
If I'm not mistaken, the 4 mm screw hole allows you to use a bigger M4 screw for engine mounting. The M3 screws are easier to strip.
Including
Top speed will increase when you use the belt conversion kit. It changes the internal ratio from 2.52 (48/19) to 2 (48/24). But the bottom end will suffer a little becasue of this. On a big track, you may want to use this conversion if you're required to use small tires like 57 or 58 mm.
Old 03-25-2005, 04:29 AM   #12164
Default Re: Re: Help unstanding what there item do
Top speed will increase when you use the belt conversion kit. It changes the internal ratio from 2.52 (48/19) to 2 (48/24). [/B][/QUOTE]
What will it do to the gear ratio on a EVO with the 0.8 gear spacing? I'm use 21/61 for 1st and 27/55 for 2nd.
Old 03-25-2005, 05:37 AM   #12165
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
better stick with the regular steel shafts that came with the kit...it's more durable especially when you are using a very powerful engine like sirio. as for my experience with the regular steel shats, i bent one while i was running my v-one r with a rbx12 5 ports turbo tuned by rody engine....had to replace it since the gears were misaligned...
doki_doki is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
