Old 11-07-2004, 06:52 PM   #12106
adamkerrnz's Avatar
hey, im just new to RCTech, just thought id show some pics of my v-one-rr evolution
adamkerrnz is offline   Reply With Quote
Old 11-07-2004, 10:05 PM   #12107
thefuzzclub's Avatar
Default centax clutch assembly
unfortunately lhs that supplies kyosho has no stock. is there any other brand i can use that is compatible for my v1r?
thefuzzclub is offline   Reply With Quote
Old 11-07-2004, 10:06 PM   #12108
Default Re: centax clutch assembly
Originally posted by thefuzzclub
unfortunately lhs that supplies kyosho parts has no stock. is there any other brand i can use that is compatible for my v1r?
Old 11-07-2004, 10:21 PM   #12109
Default Centax Clutch
Thefuzzclub, don't know where you reside, if in the US or close have a look at Tower Hobbies they have both parts in stock and will have the centax clutch for the RRR mid month part # VZ235 you may need to use engine mounts # VS030 with the later however the notes say part # VS035 is Ok on a V-one R. Good luck and
Regards from DownUnder
DownUnder is offline   Reply With Quote
Old 11-07-2004, 10:25 PM   #12110
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The Mugen clutch works. You have to get the engine mounts as well since the flywheel is smaller. If you think about it, it's an upgrade since this significantly lowers the engine for a lower CG. You will also have to dremel the flywheel opening for clutchbell clearance. I assure the benefit in handling and grip is well worth the cost.
Racing4Evo is offline   Reply With Quote
Old 11-07-2004, 10:31 PM   #12111
perfect!!! our lhs has it for the mtx3. that means the diameter size for the pinion gears are the same with the kyosho?
Old 11-07-2004, 10:39 PM   #12112
Default Re: Centax Clutch
You cant use the VZ235 unless you change the clutch bell to the V1RR/EVO/FW bell. VZ235 and VS035 use the same flywheel so you will need the lower mounts. Not sure if VS030 will work. I'll look for the number.
3434 is offline   Reply With Quote
Old 11-07-2004, 10:48 PM   #12113
Racing4Evo's Avatar
I know for certain that the .08 pitch gears are the same and I am pretty sure the .1 pitch gears are as well. If you use a mugen clutch bell you must use mugen pinions. The same goes for Kyosho pinions and clutchbell. They will not drop in without modification so do not mix and match brand pinions and bells.
Old 11-07-2004, 11:10 PM   #12114
Racing4Evo - you've been so helpful, please check if i got you right.
mugen clutch bell = mugen pinions = (what spurs?)
kyosho clutch bell - kyosho pinions = (what spurs?)
since you mentioned not to mix brands, i assumed that if i use mugen cb and mugen pinions, i will use mugen spur gears as well. and that goes the same set using the kyosho brand.
Old 11-08-2004, 07:17 AM   #12115
tazman34685's Avatar
Talking Re: centax clutch
plan to upgrade my v1r to centax clutch, what will i buy?
I would try the mugan 3d centax clutch or tower hobbies has the fw05's centax clutch setup (which has a lower profile compaired to the v1rr's)..
tazman34685 is offline   Reply With Quote
Old 11-08-2004, 05:09 PM   #12116
ralliartlanevov's Avatar
Send a message via AIM to ralliartlanevov
i just got a v1r and i upgraded my clutch to centax clutch. i recently purchased a project zen sts d5 engine. i was wondering if this engine fits the v 1r. im a newbe in centax clutch so can anyone give me advice about this
ralliartlanevov is offline   Reply With Quote
Old 11-08-2004, 05:09 PM   #12117
Old 11-08-2004, 07:35 PM   #12118
adamkerrnz's Avatar
YAY, just fixed up my V-one-RR Evo for racing , i put on a failsafe (bad past experiences ) and also a servo saver . now its running perfectly, i just need to set up my mixture at the track and im ready to roll...
how hot is too hot for an OS .12TR? it seems that my engine gets rather hot after about 7 minutes.
Old 11-08-2004, 08:09 PM   #12119
Racing4Evo's Avatar
For spur gears there are no problems with the kyosho ones. At any rate, I don't think you could use other spur gears.
Old 11-08-2004, 09:40 PM   #12120
ok, thanks again for your great help
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
