Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 09-16-2004, 08:19 PM
  #12016
pau_kacang's Avatar
I got 3R but can't run coz brake pully out. now i'm use mtx3. mtx3 is nice car, good performance buttttttttttttttttttttt always got problem with 2nd speed. i already used mtx3 in 2 race, each race got same problem. dun know how to solved. i'm already ask to professional driver, they said try using new 2nd speed for every race. wowwwwww, every race i must spend RM100.00 for 2nd speed. tension. i'm still waiting my option brake pulley for 3r n i will sell my mtx3.
pau_kacang is offline
Old 09-17-2004, 09:26 AM
  #12017
dameetz's Avatar
I m temted to get the 3racing one piece engine mount for the RRR. Anybody here has tried one? Will it fit Nova Engine?
dameetz is offline
Old 09-17-2004, 06:59 PM
  #12018
Taylor-Racing's Avatar
Originally posted by pau_kacang
. . . buttttttttttttttttttttt always got problem with 2nd speed. i already used mtx3 in 2 race, each race got same problem. . . . . .
I presume the 2 speed is locking itself in 2nd. gear, yeah?
What happens is that without sufficient gap between the shoes, the adaptor over rotates and immediately strips the grub screw threads.
Here's the fix as told to me by one of the local fast guys (rjl).
Using some new shoes (don't even bother with the old ones), tap the grub screw holes nearly all the way through so that there is a proper thread formed.
Install the grub screws and set the gap between the shoes to approx. 0.5mm each side.
Lightly lubricate the 3mm balls where they sit on the adaptor.
Use a little CA to lock the grub screws in position and don't touch them again.
Install the adjusting cap screws, springs etc. and adjust for proper engagement of 2nd. gear at the track.
We haven't had a problem since adopting this method. Good luck.
Taylor-Racing is offline
Old 09-17-2004, 07:23 PM
  #12019
pau_kacang's Avatar
tq friend
Old 09-18-2004, 08:10 AM
  #12020
dameetz's Avatar
Default 3R 1st pinion
How do you guys tighten the first pinion gear onto the bell? I have Kyosho 0.8 pinion tightener but its way too big for the 3R 1st gear.
dameetz is offline
Old 09-18-2004, 06:11 PM
  #12021
kidDynomite's Avatar
D, try using a rubber dishwashing glove to hold the end bell and a rag to turn the gear.
If you want an inexpensive tool to put-on or take-off gears, try HPI's pinion tool set. It's only $8 and universal for all centax type clutches.
kidDynomite is offline
Old 09-18-2004, 08:27 PM
  #12022
vones's Avatar
Did any of you guys noticed that the pinion gears wears down quite fast or is it just me??????Is there any other makes for the pinion gear that can be used?
vones is offline
Old 09-18-2004, 10:03 PM
  #12023
Racing4Evo's Avatar
Mugen pinions along with the required clutch bell. They still wear but at least better than the Kyosho ones.
Racing4Evo is offline
Old 09-19-2004, 09:25 AM
  #12024
dameetz's Avatar
Try K factory hard pinion gears. Its very long lasting. I use 'em in my FW and Evo.
dameetz is offline
Old 09-19-2004, 02:20 PM
  #12025
carkillaii's Avatar
Can anyone tell me if the Kfactory G4 ball diff fit the 3R?
carkillaii is offline
Old 09-19-2004, 03:33 PM
  #12026
Racing4Evo's Avatar
You only need to hand tighten the pinion gears. The direction of engine rotation will tighten the gears. You should only worry about taking off. For that there is the Mugen pinion removal tool. About $30
Everyone here should switch to the FW-05R
Old 09-20-2004, 08:15 AM
  #12027
lirpa's Avatar
Default Advice needed
WHy is it a few people who races 1/10 touring cars seldom uses OS engines like the OS TR. What they usually fit in a Serpent710, R40 or an MTX-3 is a Novarossi, Sirio or an RB engine. Is the OS TR engine really outperformed by its Italian counterpart in all aspects? or is it just they prefer newly released engines? Im currently trying to bring life to a Kyoho V1RR and an OS TR engine to power it. With this, will my car be able to give a fight with the big guys in terms of speed and handling? Of course driving skills is a different story.. thanks...........
lirpa is offline
Old 09-20-2004, 08:44 AM
  #12028
Tom G's Avatar
OS engines are easy to tune and pretty consistent. However, I choose other engines for the additional power and the difference seen/felt going through the power bands.
OS engines are good engines to learn with and race novice to sportsman classes.
^5
Tom G is offline
Old 09-20-2004, 11:33 AM
  #12029
I believe it may fit the RR/Evo, but the new 3R rear diff pulley is more centered on the diff housing.
Old 09-20-2004, 12:58 PM
  #12030
Default re: advice needed
lirpa:
If u just race the car in regular club races, focus on car maintainence, tire choice, chassis setup and driving fast without hitting. OS or Nova Rossi will do just as well. When you race at the professional league such as national event or world event, engine choice becomes a very important factor.
I have seen an offroad champion driving a RTR NTC3 and beat all those NTC3 and 710 with Nova Rossi engines in a medium size track. He used the stock engine that came with the RTR kit, and tuned the engine to deliver maximum performance.
raceblast is offline
