Old 09-14-2004, 09:06 AM   #12001
thescum's Avatar
sorry mate, have not tried to build the RRR with a front diff, using the one way instead.... if time permits will try this weekend
thescum is offline   Reply With Quote
Old 09-14-2004, 09:36 AM   #12002
thescum's Avatar
Thanks guys for giving me tips regarding suspension arm binding problem. I m building my 3R using front diff, do you guys put the front pulley to the case together with the pulley rim( the rim that supposed to be glued to the pulley if using front oneway)? I look at it if I put the rim to the pulley, the pulley it self will have a gap at the screw holes. So I build mine without the rim. Now I got another problem, when I put the diff set in the bulkhead, it seems that the diff is not wide enough, there is a lot of lateral play about 2mm. I can see the belt adjuster moves with the bearing. Anybody who has build the diff for the 3R, pls share me your experience.
Damateez,
Upon reading the parts list, was wondering whether you are using the correct diff joints. Take note that the part that comes with the kit is VZ219, i believe you need VZ218. This should be the reason as to why you're having this 2mm lateral slop.
Am looking for VZ204 the rear diff case, as i might have cracked mine.... tried searching for the VZ218 at rc-global, rcmodel.com.hk and rcmart, but to no avail for both parts (though they have 3racing's equivalent for hte rear diff case)....
Anyone else know of any good online willing to ship overseas Japanese rc shops... thanks
Old 09-14-2004, 11:51 AM   #12003
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default new stuff
hi all.
rob. the kawaharra isnt cheap?
no rear up rights..u can use the RRR..rear upright,,
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 09-15-2004, 12:16 AM   #12004
Send a message via AIM to Profoxcg
Default where can I get the RRR?
Does anyone know where I can get on of these kit?
I am in Fla
Profoxcg is offline   Reply With Quote
Old 09-15-2004, 12:41 AM   #12005
Default Re: where can I get the RRR?
there's the guy in CA who sells one on ebay. here's the link.
I am in Fla
RC Dumb is offline   Reply With Quote
Old 09-15-2004, 04:03 AM   #12006
thescum's Avatar
You could try these sites:
http://www.rc-global.com
http://shopping.rcmodel.com.hk
http://www.rcmart.com
they're all quite reliable
Old 09-15-2004, 06:08 AM   #12007
thanks
Old 09-15-2004, 09:48 AM   #12008
dameetz's Avatar
Originally posted by thescum
Damateez,
I solved the slop problem by putting bearing spacer that I have lying around from my FW05. I m using the included front diff casing together with Mugen drive cup as someone suggested here. It fits perfectly. My 3R is almost done but somehow I notice the rear diff leaks. I disassemble it and see nothing is wrong with it, the o ring still ok and still sits at where it should be. It seem that it leaks from the screws that attach the diff cover.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-15-2004, 06:32 PM   #12009
thescum's Avatar
Yah i think i have the same problem, but its probably because i used a hop up hex screw instead of the kit's self-tappering screw... managed to inspect someone else's RRR and it was ok....
He advised me to use some kinda lubricant on the o-ring before installation on the diff casing... am waiting for a new rear diff casing before trying this out....
if anyone thinks this is 180 degrees off, i'd like some advise if so...
thankss
Old 09-15-2004, 08:27 PM   #12010
pau_kacang's Avatar
Try put some silicon gasket maker at the diff before u assamble. it will resolve that liking problem.
pau_kacang is offline   Reply With Quote
Old 09-16-2004, 02:48 AM   #12011
thescum's Avatar
pardon me but what's a "silicon gasket maker"
Old 09-16-2004, 01:12 PM   #12012
Default FRONT BELT/ROLL BAR
Hey...any of you V-One R/RR owners have a brand new OR SLIGHTLY used front "210" belt and same for the "roll bar/handle" i could buy from you?.....My belt poped and my roll bar was cracked in a recent.."RC and full scale" accident....gieco car insurance wouldn't accept my rc so i have to come out of pocket..lol...but if someone has those 2 parts please email me back ASAP!!!!!!..just trying to save money....
mr.fury is offline   Reply With Quote
Old 09-16-2004, 01:49 PM   #12013
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
It's silicone RTV sealant. You find it under Permatex at the auto parts store. The stuff goes by so many names. I'm sure you're familiar with the stuff.
Racing4Evo is offline   Reply With Quote
Old 09-16-2004, 03:24 PM   #12014
Default MUGEN versus 3R
can someone give me a comparison as far as handling and durability? also setup and working on the car.
Ive been wanted a kyosho car for sooooo long... and I am really considering the 3R
what are some of its flaws and strong points. please.
Old 09-16-2004, 09:00 PM   #12015
thescum's Avatar
Thanks Racing4Evo, will try that
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
