Old 09-11-2004, 10:55 AM   #11971
dameetz's Avatar
Just got my long awaited 3R today from my LHS. My LHS has 2 version package of it. 5 of the kits item no 408 come with front black medium spring and rear gold hard spring, the other one item no 407 comes with soft silver spring front and rear black med spring. Both version has diffent set up sheet as well. I bought item 407, Is the any difference that I don't know (apart from springs) between this 2 version package?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-11-2004, 06:25 PM   #11972
dameetz's Avatar
Default Cambet set
What does it mean by setting the camber at 0G and 1G? Usually i set mine on the set up station, does it mean that it is on 1G position?
Old 09-11-2004, 06:56 PM   #11973
rjl
rjl's Avatar
Default Re: Cambet set
OG is with the droop fully extended and 1G is with the weight of the car on the suspension at your selected ride hight. These two will be different and also depend on the camber link mounting position.
rjl is offline   Reply With Quote
Old 09-11-2004, 10:04 PM   #11974
Data's Avatar
Originally posted by compaq888
if the car doesn't slow down fast enough they are suppose to catch it by the rollbar
i really want to see how it is done.
Data is offline   Reply With Quote
Old 09-11-2004, 10:19 PM   #11975
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
I know, I know.... Your engine is faster than mine. Your first gear could easily outrun my Rody on the 2nd gear on the straight away already. shhh... don't let me lose face more than I have to.
you do realize eddie that if I take off my brakes I will be even more faster. You have a hard time keeping up with me even when I drive only in 1st gear around the track.
eddiethefish is offline   Reply With Quote
Old 09-12-2004, 02:55 AM   #11976
compaq888's Avatar
Send a message via AIM to compaq888
you do know that this is just friendly sarcasm. I may be fast on the track but I'm not turning 16 and 17 second laps like you.
compaq888 is offline   Reply With Quote
Old 09-12-2004, 02:56 AM   #11977
compaq888's Avatar
I don't have any experience in that, I don't pit for anyone.
Old 09-12-2004, 07:37 PM   #11978
I did my first testing day with my new rrr. Man I love this car! It is so much better than my FW-05r it isnt even a comparison..... It is so lively and quick to turn. stable and easy to access diffs and pullies. The stock car is great! I thought id share cause I was very impressed for a first day out and learning to drive a new car.
rcosmax is offline   Reply With Quote
Old 09-12-2004, 08:05 PM   #11979
pau_kacang's Avatar
MY Last EVO Setting
Front
Camber - 2
Toe in - 0 ( Tight Track ) 0.5/1 (Big Track)
Droop - 0
Diff Oil - 100,000
Caster - Normal
Spring - Black/Silver
Rear
Camber - 3
Drop - 4
Spring - Black
Diff Oil - 10,000
Toe In - 2.5
Try modified ur bracke pad using motorcycle brake pad n change ur disk brake with K-Factory disc brake. nice combination brake n good performance.
pau_kacang is offline   Reply With Quote
Old 09-12-2004, 08:07 PM   #11980
Send a message via AIM to Profoxcg
In what ways? can you please share? bc I am trying to get either on of them
Profoxcg is offline   Reply With Quote
Old 09-12-2004, 09:42 PM   #11981
Profoxcg: The fw-05 had a turn in push that i could never get rid of no matter what i did. It also had rear camber issues that could be fixxed to have more grip with muegen rear hubs and rr links. The brake was poor and the 2 pin design on the brake holder is ineffective. it wears out brake holes very quickly and causes driveshaft wobble. I tried 3 different alloy brake holders and 2 different alloy gearbox cases and it allways was back to the same tricks almost immediately. That being said it was tough as nails and could take major crashes that would have destroyed other cars. It was very easy to work on and the shafts were quick to change out.
the RRR is quick and lively to drive, it dives into corners and is so agile I had to really smooth out my driving style. The belts and diffs are easy to get to and change the gearing is great and it seems well planted. tires wear much more evenly. The car is underweight so if you are racing you will have to add about 3 quarters to make roar. (nice to finally be adding weight than trying to remove it!) The car is tough and has easy setting adjustments. It is great out of the box. The only things that you may want to add are universals to the front and a hop up brake.
same price: no contest the RRR.
hope that helps (my opinion though)
Old 09-12-2004, 09:54 PM   #11982
great thanks !
wow sounds like the Fw05R sucks
btw, does the RRR have .8 module gears?
Old 09-12-2004, 11:32 PM   #11983
Nah the fw05 doesnt suck it just took alot of effort to get it to perform the way i thought it should. The rrr is ready to go.
I am keeping the fw05 as a backup. It is a warrior and has driven through a couple of other mugens and snakes.
I think they talked about ratios and gears a couple of pages back. Look back and you should be able to find out about gearing.
Old 09-12-2004, 11:51 PM   #11984
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Fuel Tank
Anyone here has problems with the RRR fuel tank? There were 3 RRRs at my local track and everyone one of the fuel tank started to leak next to the front screw hole after a few runs.
jeffreylin is offline   Reply With Quote
Old 09-13-2004, 02:08 AM   #11985
DotCom's Avatar
Originally posted by pau_kacang
MY Last EVO Setting
Front
Camber - 2
Droop - 0
Diff Oil - 100,000
Caster - Normal
Rear
Camber - 3
Drop - 4
Spring - Black
Diff Oil - 10,000
Toe In - 2.5
Hi l have just got my evo runing your setup is very diffrent whay dont you run a one-way this is what l ran last time out my local track.
Front
Camber - 2
Toe out - 3
Droop - 2
Diff One way
Caster - Normal
Spring - Black
Rear
Camber - 3
Drop - 6
Spring - Black
Diff Oil - 300,000
Toe In - 3
Gone Scuba Diving
May be back later
DotCom is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
