Old 08-30-2004, 05:47 AM   #11896
rjl
rjl's Avatar
The front axles rotate faster than the rear, you then make the front smaller so both front and rear tyes roll the same distance per engine revolution, if the front tyres travel a greater distance than the rear, then the car is overdriven.
I'm sure there is a rollout formula posted somewhere.
rjl is offline   Reply With Quote
Old 08-30-2004, 05:56 AM   #11897
BrainTeased's Avatar
Thanks rob *has a better understanding of why some cars use overdrive in their driveline setup now.*
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-30-2004, 07:37 AM   #11898
GUINT1's Avatar
Default RRR
Hello boner
You have a PM.
GUINT1 is offline   Reply With Quote
Old 08-30-2004, 09:21 AM   #11899
compaq888's Avatar
Send a message via AIM to compaq888
I have 25t pulley on right now, is equalized or is it overdriven?
I also have a 27t pulley but it's not on the car.
compaq888 is offline   Reply With Quote
Old 08-30-2004, 02:32 PM   #11900
Tom G's Avatar
I got the formula somewhere around here...gimme soem time and I'l shoot it over to ya or just post it.
Say 8/9pm Central time.
^5
Tom G is offline   Reply With Quote
Old 08-30-2004, 02:35 PM   #11901
compaq888's Avatar
^5
take your time, i'm out the hobby for a while.
Old 08-30-2004, 02:44 PM   #11902
Tom G's Avatar
Thumbs up Rollout Calculations; drive, overdrive, gear, etc., etc., ...
Here's the link to an article [figured it was faster and anyone can save/rint the article out, about 4 pages with a cheat-style chart with everything you need].
http://www.radiocontrolzone.com/cars/fastmath.asp
Old 08-30-2004, 02:46 PM   #11903
kidDynomite's Avatar
Tom, Got the "stuff" today. Thanks a bunch. I left you + feedback as well. And my RR project in now complete ... well almost. I still need brake pads, a few more outside wheel bearings, and pins for the hexes. But otherwise, she's looking pretty good.
Hey C888, why you out, bud?
kidDynomite is offline   Reply With Quote
Old 08-30-2004, 04:27 PM   #11904
compaq888's Avatar
money. Money let's you get track time and money gets you to the track(transportation).
Old 08-30-2004, 05:13 PM   #11905
Tom G's Avatar
Good deal, glad you got it!
^5
Old 08-30-2004, 06:09 PM   #11906
thescum's Avatar
Hi guys,
with regards to the slop on the top a-arms of the RRR, and to borrow the Boner's idea of shimming to get rid of the slop, i know i had said that i wanted to shim the front and back by 0.2mm.
But when i looked at the RRR data sheet, realised that we should only shim the front to get the stock settings.
Upon measuring the slop again, i had about 0.5 mm worth of slop.
So am happy to report for the RRR users who want very negligible slop, use a 0.5mm washer at the front of the arm, to attain "proper" stock castor settings.
thescum is offline   Reply With Quote
Old 08-30-2004, 06:53 PM   #11907
Work. Hard work gets you tracktime and a nice ride for going to the track. Aren't you off to college soon?
I stopped the hobby for college and four years after that. Once you make your way to success, your next kit or engine is as easy as, "I feel like pizza tonight!".
Or you could try to find yourself a sugar mama.
Trust me, once you get to college, become a lady's man ... that will get your mind of racing for a while.
We'll still be here, we'll be a lot faster than you, but we'll still be here.
Old 08-30-2004, 08:36 PM   #11908
Tom G's Avatar
Originally posted by B4
In the standard RR/EVO setup it is actually a 4mm split. If you run the 26 tooth front pulley it is a 2mm split. The V-One-R used no split as it had a 27 tooth pulley.
If you get the 26 tooth pulley from Kyosho it has a chart to tell you the splits for each pulley size and the characteristics of each size.
While on the topic of ratios and drive trains, I looked at my "bible" looking for the split. It is 4.5mm smaller tires in front to make a 1:1 ratio on the RR kit.
That .5mm may attempt to make up the rear-tire wear factor difference or it may truly be a 1:1 ratio equalization. Sorry for the bum scoop confirmation [I won't feel .5mm difference when I plow around that corner ].
^5
Old 08-31-2004, 05:26 AM   #11909
Default Re: Rollout Calculations; drive, overdrive, gear, etc., etc., ...
^5 's Tom !
Old 08-31-2004, 05:52 AM   #11910
ziggy12345's Avatar
http://www.ziggy12345.plus.com/Cars/V-1-RR%20MPH.xls
Drive calculator
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
