Old 08-27-2004, 09:27 AM   #11851
compaq888's Avatar
Send a message via AIM to compaq888
Originally posted by Aku-Man
3Racing already making and released some Hop-ups for 3R. Those third-party companies are working fast.
3 Racing Hop-Ups for 3R
are those titanium parts going to hold up, because we know how 3racing parts are fragile
compaq888 is offline   Reply With Quote
Old 08-27-2004, 10:54 AM   #11852
boner's Avatar
Originally posted by elephant
boner, does this means the clutch bell bearing are no longer standard size pairs of 5by10?
thanks.
It uses a 5x10x4 and a 5x8x2.5.
boner is offline   Reply With Quote
Old 08-27-2004, 12:36 PM   #11853
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
not really.
eddiethefish is offline   Reply With Quote
Old 08-27-2004, 03:13 PM   #11854
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Yes, they are.
Racing4Evo is offline   Reply With Quote
Old 08-27-2004, 03:41 PM   #11855
From my experience, it really depends on the item.
cvccsi is offline   Reply With Quote
Old 08-27-2004, 04:22 PM   #11856
compaq888's Avatar
I have 3 racing main shaft, where the 1st and 2nd spurs are mounted on it.
I might have the small pulley shaft from 3 racing, but since i got it for free I am not really sure what manufacturer it is, It's lightweight and free, so that one doesn't matter.
I also got 3racing wheel adapters. For the cvd's i'd get Kyosho, because kyosho products are quality.
So will 3racing's titanium parts hold up?
Old 08-27-2004, 06:29 PM   #11857
thescum's Avatar
Default 3R lower arm binding
there we go, 3r arms doesnt work on evo without any modification. Either you dremel parts of arm or bulkhead to free up the movement. Well another thing to consider is caster of 3R arms on evo bulkhead is completely different. But 3R front knuckle and rear upright is direct replacement for V1R/RR/EVO front knuckle and rear upright..
Heya Boner,
ok a small misunderstanding, i have a evo and now a RRR. The binding was occurring on the 3R lower Arms.
What i did was i dismantled the arm, added some green slime to the hinge pins and buffed the insides of the arms and bulk head.
There was an improvement thereafter, but once i had assembled the front end (steering knuckles and all) the arms were moving under their own weight, with just the right amount of free play.
Thanks for the efforts and for setting me back on track.
i guess i've said this before but i'll say it again, getting to the diffs is so easy now...
Would you have any more tips or potential pitfalls that i should look out for while continuing with assembly.
thescum is offline   Reply With Quote
Old 08-27-2004, 06:47 PM   #11858
boner's Avatar
thescum: we are all learning. glad we can exchange idea and make the car more prefect. Just word of caution, make sure you use the right length of screws when you tighten the front belt tensoner block (page 9, item 21, 22), if you use 3x12mm screw, it will penetrate builkhead and rubbing on the 1way pulley.
For people building the front differential, the front differential case rim will rub on turn buckle of center steering at certain angle. you will need to shave a tad on the item 117 on page 9.
Otherwise go out and burn nitro :-)
Old 08-27-2004, 08:51 PM   #11859
thescum's Avatar
Heya Guys,
upon talking to Boner, i've got something to share...
compiled a setup guide from articles off the web and predominantly off this book, XXX-Main Chassis Setup Guide by Martin Crisp...
Have done my best to minimise errors... let me know if i've missed some....
Old 08-27-2004, 08:53 PM   #11860
thescum's Avatar
sorry guys double post
Old 08-27-2004, 09:24 PM   #11861
boner's Avatar
The file seem to be corrupted. Does other people have problem opening the PDF file?
Old 08-27-2004, 09:39 PM   #11862
thescum's Avatar
Boner, what version of PDF are you using.... this will work with acrobat 5 and above...
You can use this link to download acrobat 6 reader....
http://www.adobe.com/products/acrobat/readstep2.html
Old 08-27-2004, 09:41 PM   #11863
boner's Avatar
acrobat reader 6
Old 08-27-2004, 09:53 PM   #11864
thescum's Avatar
Ok guys click on the pdf attachment as above, have editted that post by re-attaching the pdf.
Turns out that there must have been some uploading errors.... Verified that its working now from a seperate machine.
Old 08-27-2004, 10:16 PM   #11865
boner's Avatar
Thumbs up
working thanks a lot
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
