Old 08-26-2004, 12:58 AM   #11821
boner's Avatar
Originally posted by kidDynomite
Boner, did you check out cvccsi's pix on the FW05R thread? Pretty slick.
I had it on my evo when i assemble my 3R, that's why I know it work :-) FW05R uses same upright and knuckle as Evo/V1R that's how I conclude it will work there too.
boner is offline   Reply With Quote
Old 08-26-2004, 12:58 AM   #11822
Registered User
The manual said 18~20mm. I know they all can work, but which is better length?
Aku-Man is offline   Reply With Quote
Old 08-26-2004, 12:59 AM   #11823
Registered User
I need some caster clips. where can I get it?
Old 08-26-2004, 01:09 AM   #11824
boner's Avatar
aku: 3R or evo? If it's for Evo throttle horn length I use 14, if i follow the instruction the horn is riding inside the fuel tank. So you better did a line up check before you do any cutting or drilling on the horn.
Another thing you need to be careful on 3R is steering servo horn, on my car, ball of ball cup actually rub the CF on upper deck, I'll to space out the horn with an o ring.
20mm hole will give more throw than 18mm hole but that doesn't matter much since now a day radio have epa, you can compensate with it. I'll go with 18mm or less for more precise movement.
you can use caster clip from mtx3 or v1r or evo. If not you have to buy a part tree. The kit should include enough clips you need, unless you lost one. For 3R you need VZ206 - front arm, For evo VZ101- front arm, or you can get V1R/RR front arm VZ003.
I have few of them if you need them let me know. VZ003 and VZ101 come with 1mm and 2mm clips while VZ206 come with 1mm clips only.
Old 08-26-2004, 01:14 AM   #11825
Registered User
Thanks boner, I got 3R.
Old 08-26-2004, 01:17 AM   #11826
kidDynomite's Avatar
[QUOTE]Originally posted by boner
[B]aku: 3R or evo?
Boner, I believe it's for his 3R.
Did Kyosho give you servo spacers for specific brand servos? The spacers go between the servo and the mount.
I know the Evo steering servo had them. Maybe you can use those for spacers so and your servo horn is more secure.
kidDynomite is offline   Reply With Quote
Old 08-26-2004, 01:49 AM   #11827
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default v1RRR parts fit with my v1r?
is the rear upright from RRR will fit to my RR rear suspension?
what is the part number of the upright,the upper linkage that sits atop the rear upright? will the front knuckle arm from RRR fits on my RR?
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 08-26-2004, 02:55 AM   #11828
thescum's Avatar
Thanks for the input guys,
the binding's existent without the steering knuckles installed.
anyways, was just wondering whether this was normal, coz my RR and then evo were quite free. Anyways the new design's quite a change from the previous versions.
If i dare say this one's gonna be joy to stip.... To get to the diffs are especially a joy...
thescum is offline   Reply With Quote
Old 08-26-2004, 05:13 AM   #11829
Send a message via AIM to Profoxcg
Thanks for answering my Q's !!
BTW Jr horns will fit KO,
Profoxcg is offline   Reply With Quote
Old 08-26-2004, 06:05 AM   #11830
compaq888's Avatar
Send a message via AIM to compaq888
don't JR horns fit hitec too?
compaq888 is offline   Reply With Quote
Old 08-26-2004, 06:34 AM   #11831
no jr horns dont fit hitec
KIMCOM RACING Driver #1
RC8B : REEDY 121 : Nitro-X fuel : Spektrum Radios
gkp5569 is offline   Reply With Quote
Old 08-26-2004, 07:06 AM   #11832
boner's Avatar
Just to make things clear, did you use 3R arms since you saying blinding exist without steering knuckles?
I tried just 3R front knuckle and rear upright on EVO and have no blinding problem.
Old 08-26-2004, 03:39 PM   #11833
compaq888's Avatar
I went to a hobby shop and a guy brought in his RRR, he needed some parts to make the car run. It looked cool as hell, I told him that i would only go to the RRR if they stop making parts for my RR. The car looked a lot wider than mine, and I got to check out how everything was in it, and how easy the diff comes out. Truly an exceptional car.
Old 08-26-2004, 06:15 PM   #11834
thescum's Avatar
Default 3R lower arm binding
Yes Boner am using the 3R arms... There's little freeplay, although when i flip the bulk head on its head, both arms do come down, but again these are not as free as my Evo's.
Old 08-26-2004, 06:49 PM   #11835
I need belts for my RRR, ASAP. Anyone know of where I can find here in US? Thanks
spdmkr is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
