Old 08-25-2004, 10:38 PM   #11806
compaq888's Avatar
Send a message via AIM to compaq888
Default Re: RRR
Originally posted by GUINT1
Hey Boner
I ran my RRR today at the air field, and oooHHHHHH mannn
this car is no joke
Also youre right i think that the car does like the setting that you gave me. Powered by my old 3 port JP. There were a few guys at the track and they all came over to check out the car,wanting
to know what was running buy them.
I just want to say to all the KYOSHO touring car guys you must
drive this car.
Boner you have a PM.
it is so tempting to get the RRR
But first I'll wait till they stop making the parts for the RR, I don't want to have 2 cars, it would be a waste of money.
So what is the max speed of the RRR? mine is like 52-57mph depending on how my foams wear out. BTW, i have RR, for those that don't know.
compaq888 is offline   Reply With Quote
Old 08-25-2004, 10:39 PM   #11807
boner's Avatar
Front:
0 or -0.5 camber
0.5 toe in
sway bay softest (flat)
shock position stock setting (black spring)
ride height 5.5mm (59 mm diameter tire, 40 shore)
front diff: 1way
Rear:
-2 to -2.5 camber
2 toe in
shock position stock setting (gold spring)
stock sway bar (black bar)
ride height 6mm (61mm diameter tire, 37 or 40 shore)
rear diff: 30,000wt diff oil
boner is offline   Reply With Quote
Old 08-25-2004, 10:53 PM   #11808
Send a message via AIM to Profoxcg
Im am very interested in this car, sounds like kyosho made something really good.
how would you guys compare it to a MTx prospec?
also, do you have any pics anyone?
Also, how would you compare it to an FW-05R?
Last, does anyone have the 4 cycle engine ? where can I get it , and does it fit the same as a .12 engine?
I am sorry for all the Q's
Profoxcg is offline   Reply With Quote
Old 08-25-2004, 11:54 PM   #11809
Registered User
What servo and throttle horn do guys used on RRR? The kit did not come with them.
Aku-Man is offline   Reply With Quote
Old 08-26-2004, 12:03 AM   #11810
kidDynomite's Avatar
Originally posted by boner
the bulk head, arms on 3R are composite. You can tell the difference of materials when you build 3R. To think of it 80% or 90% of 3R seem like composite plastics. The only Plastics that are composite are servo saver, ball cups, body post, front bumper.
Thanks, Boner! There you have it, bonified testiment that the 3R is harder (new material), lighter (less material) and not to mention, lower ... and that = faster down the straights and in the apexes.
I just looked at my new composite parts for the Evo. It is a lighter shade and the material is very hard. There is also a weight difference. It would probably only make a major difference if you changed all the parts available to composites. The composites cost about double the stock. So if you haven't got them already, save your change for the 3R.
Originally posted by GUINT1 I just want to say to all the KYOSHO touring car guys you must drive this car.
I'm jealous, G1. Though I'm glad Boner hooked you up.
Originally posted by thescum what the potential problems with the kit that you've heard. Would like to know as i'm in the process of building the kit now.
To the rest,
have a problem with the lower front arm, it seems to bind, not enough free play.... followed the instructions to a T (i hope) and even buffed the exta fleshings off the lower front A-arms....
Hi scum! I just heard that the 3R rear uprights were not working to well on the RR/Evo/05R because of limited or binding up/down movement. I wouldn't worry about it. I'm waiting to see what cvccsi has to say... he's working on it now.
Is the binding you're experiencing with the front steering knuckles off or on?
I did notice that my composite parts had some flashings too. The nylon parts hardly ever had anything to slice off.
kidDynomite is offline   Reply With Quote
Old 08-26-2004, 12:10 AM   #11811
Hey KidDynomite..
Got images of the 3R rear upright posted in the FW05R thread.. check it out.
cvccsi is offline   Reply With Quote
Old 08-26-2004, 12:25 AM   #11812
boner's Avatar
You use what's included with your servo or purchase servo horns make for your servo.
Old 08-26-2004, 12:30 AM   #11813
Registered User
But they are too soft.
Old 08-26-2004, 12:32 AM   #11814
Originally posted by Profoxcg Im am very interested in this car, sounds like kyosho made something really good.
1) how would you guys compare it to a MTx prospec?
2) also, do you have any pics anyone?
3) Also, how would you compare it to an FW-05R?
4) Last, does anyone have the 4 cycle engine ? where can I get it , and does it fit the same as a .12 engine?
No worries about the Q's ... that's what this forums all about.
I took the liberty to # your Q's for people to answer.
1) No one at my track has either the 3R or MTX3. But it should be quite a battle.
2) Scroll back on this thread a few pages and you'll see some of the guys 3Rs.
3) The 05R smoked the Evo in the corners using a front diff. Evo had a one-way. I personally love having both cars. Haven't done much to the 05R. Don't really need to. But my Evo when through some major surgery in the last yr. So I'm extremely happy with it's performance now. Spool, Atkins diet, SP belts ... it's still my project car.
4) 4 cycle engine: I've only seen it on the Kyosho site. But I here it blows everything away in the turns. But gets caught on the straights. And BTW ... it will fit.
http://www.kyosho.co.jp/web/top-j.html
Old 08-26-2004, 12:36 AM   #11815
boner's Avatar
I did notice that my composite parts had some flashings too. The nylon parts hardly ever had anything to slice off. [/B]
i suspect the blinding isusse is cause by pivot ball retainer. with this new hub, the retainer tend to get out of thread very easy. I spend tons of time to make sure retainer is tightend trued not crooked. Another issuse is pivot ball, when you tighten it make sure it's straight into the arm it's very easy to threaded it crooked too.
Old 08-26-2004, 12:44 AM   #11816
boner's Avatar
aku: which company servo are you using? i know there are alloy servo horns for futaba and airtronic servos. But plastic servo horn will be a plus because they flex on impact which "give" another layer of protection to servo gears.
Old 08-26-2004, 12:50 AM   #11817
Boner, Thanks for sharing that. I think it'll help everyone who's planning on doing it.
Old 08-26-2004, 12:51 AM   #11818
Registered User
I use Ko. I found some nylon horns, but the spec only said for air/fut/jr
Old 08-26-2004, 12:52 AM   #11819
Boner, did you check out cvccsi's pix on the FW05R thread? Pretty slick.
Old 08-26-2004, 12:55 AM   #11820
boner's Avatar
aku: give the plastic horn a try. they should work fine or more than enough strength on 1/10.
I have shave my horn to very thin and it still holds up of nitro abusing.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
