Old 08-13-2004, 10:09 PM   #11641
boner's Avatar
V1RRR setup sheet
boner is offline   Reply With Quote
Old 08-14-2004, 08:27 AM   #11642
GUINT1's Avatar
Default V One RRR
In the car kit you get 2 trees with 8 of these little peices on each of them. Now on anyone of these trees. the first 4 at the top looks the same to me. The bottom 4 looks as if each one of them have a bit of a offset. Now. If this is correct. How am i suppose to know which one is (A) OR (B).
Now back to the top 4. If they are all the same were do i put them In front of the bulkhead or at the back of the bulkhead.
GUINT1 is offline   Reply With Quote
Old 08-14-2004, 09:23 AM   #11643
kidDynomite's Avatar
Default Spring Ratings
Boner! on your Evo you have the light blue springs, do you know what they rate at? What kind of track surface was that set up for?
Actually, does anyone have a list of the Kyosho spring ratings? Thanks!
kidDynomite is offline   Reply With Quote
Old 08-14-2004, 12:42 PM   #11644
boner's Avatar
Guint1: if you look at blocks, one of the block have half of rear shaved or the top one - that is block A. You are correct Kyosho give 4 of each on each part tree. As to where to put them, you need to put them in the front and back mounting point of the front upper arm shaft and the rear lower arm shaft. So you need total of 8 blocks.
Well unscentifically, the light blue spring feel slightly harder than the stock black spring but I recall reading somewhere someone said light blue spring is softer than black spring. So it's your pick on what to believe.
My track is tight and small, parking lot surface, slightly bumpy. I have 50WT oil all around, front and rear diff. The car seem to be more steady with light blue spring in the front and black spring in the rear. with rear light blue, rear end like to break loose too easily.
Old 08-14-2004, 01:43 PM   #11645
GUINT1's Avatar
Default Set up RRR
Hi Boner
Are you telling me to put the shaved blocks (A) in the front and rear of each bulk head.
Now when it comes to the rear of the car put the same blocks (A) from the other tree, put 2 on each side of the rear bulk head.
Also if this is all correct which way should the blocks face, with the shaved part up or faced down.
Old 08-14-2004, 02:02 PM   #11646
boner's Avatar
guint1: I haven't tried block A so I don't know how well it will work with 3R. I tried block B with shaved part facing up and it's work really well.
Old 08-14-2004, 06:16 PM   #11647
dougday's Avatar
Originally posted by boner
V1RRR setup sheet
Does anyone have the setup sheet in english
dougday is offline   Reply With Quote
Old 08-14-2004, 10:15 PM   #11648
GUINT1's Avatar
Default v 1 set up rrrIs
Boner: is part number 68 the 4 (B) peices????
Old 08-14-2004, 11:51 PM   #11649
Registered User
OFNA Starter Box
Is this starter box good to use with 3R?
Aku-Man is offline   Reply With Quote
Old 08-15-2004, 01:07 AM   #11650
boner's Avatar
Guint1: good call that's block B
Aku: that's a good starter box. Looks like it's able to start any 1/8th engine with it too.
Old 08-15-2004, 01:27 AM   #11651
Registered User
I was consider Trinity X5, but this starter box can also do the glow plug.
Thanks boner, Just want to make sure I get the right stuff. New to nitro.
Old 08-15-2004, 01:29 AM   #11652
Registered User
Do 1400mah, 1200mah, 1000mah, and 800mah receiver battery pack make big differences in weight on nitro car?
Old 08-15-2004, 02:12 AM   #11653
Aku-Man if i were you i would get AAA cells, they weigh far less and take up less room than the Sub C cells. I think the max mah for a AAA cell is about 850. AAA's weigh about half of what the Sub C cells do but you do sacrafice some run time.
Dexter is offline   Reply With Quote
Old 08-15-2004, 03:52 AM   #11654
Tom G's Avatar
Good Lord! Sub Cs as Rx bateries? You must run some looooong heats!
Tom G is offline   Reply With Quote
Old 08-15-2004, 04:17 AM   #11655
GUINT1's Avatar
Default RRR
In the book its says (67) is the A. top half is missing
(68) is the B. whole peice is there with a slit.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
