Old 08-13-2004, 07:09 AM   #11626
compaq888's Avatar
Send a message via AIM to compaq888
Originally posted by kidDynomite
c888, did you ever get your alumin hex's for your new wheels?
Yeah, I saw you're RR. Looks good! But did you ever have any problems with your fuel tubing going over the carb like that? When I first got my RR 2yrs back, that was the way I set it up and I couldn't figure out why I kept flaming out. Until my dad (mechanical engineer) came to watch me at the track and noticed my fuel tubing was going up. He said it was causing vapor lock during high temps. Simply said, the air gets trapped at the top of the loop trapping fuel from getting to the engine. I lowered the tube around the head and I finished every race. Just curious.
No, I don't have any problems as of yet. The only problems I have so far is the money situation and the bodies with 3 holes and traction at the track. Data and AH10 adjusted the throttle linkages, fuel line placement and centrax clutch before I even drove the car.
compaq888 is offline   Reply With Quote
Old 08-13-2004, 08:40 AM   #11627
i've got money problem, too! but, not money on my r/c, i spend it wisely.
RC Dumb is offline   Reply With Quote
Old 08-13-2004, 09:13 AM   #11628
compaq888's Avatar
I spend my money wisely, but for RC it's a definate loss of money.
Old 08-13-2004, 09:57 AM   #11629
kidDynomite's Avatar
Taylor_Thanks for the parts list!
kidDynomite is offline   Reply With Quote
Old 08-13-2004, 10:28 AM   #11630
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
For me, every penny spent is worth the thrill and the joy r/c has to offer.
eddiethefish is offline   Reply With Quote
Old 08-13-2004, 10:32 AM   #11631
Data's Avatar
never touched the fuel line on your car, only the centax and the linkage. i don't think i want to touch your car again, don't want to get blame becasue i tried to help.
data
Data is offline   Reply With Quote
Old 08-13-2004, 01:44 PM   #11632
GUINT1's Avatar
Default RRR Set Up Sheet
Hey Guys
Does anyone have the RRR Data sheet/set up sheet in english.
Im trying to put togetther my kit, and i cant seem to make out
which suspension bushing to use
Can someone help me with this???
GUINT1 is offline   Reply With Quote
Old 08-13-2004, 02:44 PM   #11633
boner's Avatar
I use B block - slight off set to the center, and position it up (shaft sit higher to the top aside of the block).
Gunit1 did you get your kit from RC Champ?
boner is offline   Reply With Quote
Old 08-13-2004, 03:19 PM   #11634
Registered User
Are you on page 9? It does said "refer to the setting data sheet about the setting". I don't see any too?
Aku-Man is offline   Reply With Quote
Old 08-13-2004, 03:27 PM   #11635
forty6's Avatar
Originally posted by Taylor-Racing
Mugen T0229 F/R axle shaft 1
Mugen T0230 F/r drive shaft 1
Mugen T0139 Rear up right 1
Mugen D0105R king pin 2
Mugen J0110 adjust nut 2
3 Racing mtx3-008 wheel adaptor 1
10 x 15 ball bearing 2
6 x 13 ball bearing 2
Thx T-R!!
forty6 is offline   Reply With Quote
Old 08-13-2004, 04:06 PM   #11636
boner's Avatar
There is a loose sheet include with the manual on setting up the car and stock setup of the 3R. Sadly everything is in japanese on it. If you need me to scan the setup sheet let me know.
Old 08-13-2004, 04:19 PM   #11637
Default Re: RRR Set Up Sheet
Originally posted by GUINT1
Hey Guys
You.....and you got one too!!!
Anyways, I'm using "B" both sides of the car...but you have to turn it up...there's like two choices - A & B, right? You can set the hole up top or bottom. Found that on the setting sheet....and GREAT the weather sucks can't ran it tomorrow or sunday!
adlawoo is offline   Reply With Quote
Old 08-13-2004, 04:29 PM   #11638
boner's Avatar
now that's rude putting fw05r on top of the 3R
My 3R and Evo. I wish kyosho use the body pin to hold the fuel tanks like R40, for easy removal and cleaning.
Old 08-13-2004, 05:27 PM   #11639
GUINT1's Avatar
Default Setting Up RRR
Hello: Boner and Adlawoo
No boner i didnt get the car from RC Champ.
But i will be needing parts from There.
Adlawoo. Us kyosho boys must stick togetther and put
A Beeeeetttttttting on those mugen boys i cant wait.
Its hard for me to see the off sets in each part.
They all look the same
Also yes boner scan the set up and post it here,because
i Think others are going through the same thing.
That would help us a lot.
Old 08-13-2004, 09:25 PM   #11640
compaq888's Avatar
data
I'm not blaming anything on you, both you and Anthony worked on my car, and you guys did a good job, the car works good, what's to blame?
I get picked on most of my life and now people say i'm an ahole.
I'm not coming to the track tommorow, I worned out my welcome
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
