Old 08-11-2004, 10:54 PM   #11611
boner's Avatar
a few. might be more than you think. kyosho have a huge group of loyalities in state
boner is offline   Reply With Quote
Old 08-11-2004, 11:09 PM   #11612
Registered User
My 3R coming this week. This is my first nitro car. Hope Kyosho won't let me down.
Aku-Man is offline   Reply With Quote
Old 08-12-2004, 01:06 AM   #11613
compaq888's Avatar
Send a message via AIM to compaq888
Originally posted by RC Dumb
what would the part number do? i'm lost here.
part number 73 in the RRR manual. The RR doesn't have that, and it causes the steering to be a little bit loose, But if you have that part the steering won't be that loose. Because without that part if you tighten the big nut, part 194 then the car won't steer because it's too tight. Part 73 allows for part 194 to be more tight and the less part number 2 will move around, and the car's steering won't be loose. It's hard to explain, I wish I can show it to you. I'm not saying the steering is that loose, I'm saying that it will be less loose and it will improve the car.
compaq888 is offline   Reply With Quote
Old 08-12-2004, 03:51 AM   #11614
I've got one and one brand new in the box for sale
spdmkr is offline   Reply With Quote
Old 08-12-2004, 04:19 AM   #11615
BrainTeased's Avatar
They are comparing RR evo's with RRR's not RR's and RRR's
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-12-2004, 04:49 AM   #11616
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Post
they wont, it's a durable car post some pics after you finish building it i'm planning to get one also
buboy28 is offline   Reply With Quote
Old 08-12-2004, 05:23 AM   #11617
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default faults
Because I own an RR and I know it's faults. In the RRR they improved it and you can clearly see it, would you like me to give you part numbers??????
i have owened the r series since the first car,,
they all had simmelar issues...no good in high tracktion....couldnt get enough camber on the rear due to the rear geometry...the mugen got it right and have stuck with it...ive got the rrr comming real soon and im hoping that they have corrected this...the pics seem to say they have...i own the fw-05r as well..its ok in high traction,,but being a shaft drive, it demonstrates some new things to tackle.....car stepping out on power due to the 'back-lash' from all the driving parts..( think about it)...belts are smoother..
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 08-12-2004, 08:05 AM   #11618
kidDynomite's Avatar
Thanks, Brain! Yes the comparison was based on RR Evo vs. 3R. I haven't looked at the part no.'s yet to compare to see if they are using the same steering (low CG servo layout) parts as the Evo.
I do believe that the 3R will be the better due to evolving the V-One series: lighter, better battery balance and all the extra tuning aids like high & low roll adj, the new adjustable inner pin-pivot points and adj. belt tensioners on the main diff bearings.
I don't have the car yet, but to see all the new stuff in the manual really makes me want it more.
KitRacer, thanks for the updates!
MikeCatts, you're right, belts are smoother.
kidDynomite is offline   Reply With Quote
Old 08-12-2004, 08:19 AM   #11619
compaq888's Avatar
the whole back end of the RR evo is the RR, and some parts in the front.
I gotten some more stuff for the car yesterday, I copied some of Manticore's stuff by looking at the pics and it works.
Also I modified the wing like hell in the back, it got enough screws to pop a wheelie, j/k, but still a lot of screws. I will be saving up for an RRR soon, but I'll wait a little till the prices come down.
Kiddynomite, have you seen my RR pics, they are in the link in my profile, you should check them out.
Old 08-12-2004, 02:16 PM   #11620
c888, did you ever get your alumin hex's for your new wheels?
Yeah, I saw you're RR. Looks good! But did you ever have any problems with your fuel tubing going over the carb like that? When I first got my RR 2yrs back, that was the way I set it up and I couldn't figure out why I kept flaming out. Until my dad (mechanical engineer) came to watch me at the track and noticed my fuel tubing was going up. He said it was causing vapor lock during high temps. Simply said, the air gets trapped at the top of the loop trapping fuel from getting to the engine. I lowered the tube around the head and I finished every race. Just curious.
Old 08-12-2004, 06:31 PM   #11621
drfritz's Avatar
Default Re: faults
mike
thats why I put the mugen rear on the car, really made a BIG difference in the way the car works. I'm the only guy that runs a K car at my track. I can count on one hand the number of races I have not won this season so far. the car is just so easy to drive, I never have to push it hard and still end up winning by a number of laps.
drfritz is offline   Reply With Quote
Old 08-12-2004, 06:41 PM   #11622
forty6's Avatar
Can somebody please list all the parts needed to convert the rear end to Manti's MOne-RR?
forty6 is offline   Reply With Quote
Old 08-12-2004, 07:02 PM   #11623
drfritz's Avatar
I did not feel like having to buy all the mugan stuff so I ended up doing some mods to the mugan rear up rights to make them work with the k cars parts.
1st I ended up taking a high spped dreme and removing some material so the piviot balls would work, after that I had to add some shims to the back of thedrive cups( between the bearing and drive cup) to take up the slop,
2nd you have to remove about a 1/8 inch of the arms, I cut them flush with the shock mounts, if not the rear is to wide. thats it. I found that with the mugan rear, the car likes a little more neg camber than the old up rights did, start out with -2.0. good luck.
Old 08-12-2004, 10:14 PM   #11624
compaq888's Avatar
I didn't convert the back end, just changed some stuff on the car. It's not worth converting the car, it's easier to just get the RRR
Old 08-13-2004, 02:47 AM   #11625
Taylor-Racing's Avatar
Mugen T0229 F/R axle shaft 1
Mugen T0230 F/r drive shaft 1
Mugen T0139 Rear up right 1
Mugen D0105R king pin 2
Mugen J0110 adjust nut 2
3 Racing mtx3-008 wheel adaptor 1
10 x 15 ball bearing 2
6 x 13 ball bearing 2
Taylor-Racing is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
