Kyosho VoneR Thread
I checked on the computer and it says my gear ratio is 5.06, because I'm using a 44/22 combo for second gear. It also said my max speed is 52mph, that's weird, the factory got 50-55mph on an OS 3 port motor, while i'm using an RB v12 410
52 is considered fast already, no?
Come on, you're fast already!
be ready to be a pitman, for you'll be asked for.
for HPI it's considered fast, but my car is suppose to hit 55mph+ with the RB v12 410 motor. I read on the instruction that these motors go 35000rpm, but really what's there maximum rpm, because even OS can achieve 35000rpm.
how about the engine that goes more than 40000rpm, is it going to be faster?
Also RC dumb, if i have a motor that is 40000rpm than i will be 8mph faster
Also does anybody know how many rpm does a RB v12 non turbo 410 produces?
why do I have to be a pitman, I drive, somebody else refuels my car, plain and simple.
Re: Carbon Composites for RR-Evo
Originally posted by kidDynomite
Has anyone tried the front or rear bulk heads? Are these parts lighter than stock?
Re: Re: Carbon Composites for RR-Evo
Has anyone tried any of the V-one composite parts, and if so, are they ligher or just stiffer?
well I ran the RR yesterday at the track again. I lowerd my lap time significantly, the lowest i got was 18.2, the pros get an average of mid 17's. And all of them have modified motors or/and they run 30% fuel. I run 20%.
The car handles excellent, and drives good too. My motor still rejects to get temperatures above 200F degrees. I stopped the car yesterday and had the temp measured by Data and it was 136, and that was like 5 seconds after I stopped the motor. My motor just doesn't want to run hot. But we have it lean as hell, when we turn the high speed needle any leaner the motor chokes when i go WOT
data
Just to let everyone know bone stock V1RRR didn't pass ROAR weight test!!! I was short of 0.03LBs, about 3 US quarters to make it pass the weight tech.
The car's handling is amazing!! very easy to drive and very driver friendly. First time driving it was in a race, nothing broken except losing the dog bone that lead to lost the outdrive and out of the bump up
Originally posted by Data
what was the lap time before and after that 18.2 sec. lap? your stop watch finger might had been faster than your eyes. and i think you would get a better picture if you compare average against averag, not fastest against average.
i don't think it was me, must had been the punk fish took the reading for you with his new temp gun (he is learning how to use it, too many buttons for him ) he must had set the unit of measure to C instead of F without knowing it. ask the fish.
data
data
It was you who took the temp because i noticed it that you took it out of your apron pocket, plus your temp gun is original, it's square and white.
I noticed during the race that the fastest drivers only turn a couple of laps the fastest the rest is average, which is about 17's, nobody is perfect.
