Old 08-02-2004, 01:31 AM   #11461
Taylor-Racing's Avatar
Be aware that the stock side belt for the G4 won't fit the overdrive pulley system of the RR, but K-Factory do make one that will fit.
The part number for the overdrive belt is K 1404, if I recall.
Taylor-Racing is offline   Reply With Quote
Old 08-02-2004, 04:32 AM   #11462
esham's Avatar
I had a bad experience with those belt guys.. Mine not last long - it striped/worned the belt gear pitch within 4 Heat!. Maybe i had bad component. Just sharing.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-02-2004, 04:32 AM   #11463
esham's Avatar
Anybody have V1RRR yet?
Old 08-02-2004, 04:38 AM   #11464
Yes, same here. Our side belt only lasted one meeting also before I noticed a couple of missing teeth and a couple more ready to let go.
Also, I wasn't able to notice any better free roll compared to the SP belts, and they last for ages.
Old 08-02-2004, 04:39 AM   #11465
BrainTeased's Avatar
Originally posted by kewdawg
Well... you're on the righ track, but what I said was: with more diff action, you'll have less FORWARD traction (the car will rotate more). Again, this should be adjusted, according to the traction & layout of the given track.
Keep Wrenchin'
Thanks for your much appreciated help
I improved on my lap times/heats and momentum alot at yesterdays club meet. which = more consistancy and control
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-02-2004, 07:44 AM   #11466
kidDynomite's Avatar
Taylor, esham: Thanks for the word on those G4 belts. I was going to try them out if my SP's start tearing on me ... but they haven't.
Bmain: Listen to these guys, hope you didn't get the G4 belts yet. You should find them at Tower.
kidDynomite is offline   Reply With Quote
Old 08-02-2004, 08:37 AM   #11467
Originally posted by compaq888
<SNIP>
the 3 hole vs. 4 hole thing is when i got my bodies for the car they were cut out for a different car, so one of my mounting locations is a big gap because it is a window, so I can only mount it on 3 holes. The car rides good as hell but the back it has no downforce because of no 4th hole so I can't go fast because it spins out.
Yes, everybody told me to get another body, but it is easier said than done, they work and I don't. And it's not because i'm not looking for work, I do look for work, it's just nobody is hiring me. So i'm really on a tight budget.
We've been known to staple a strip of lexan across the rear window to allow for different body posts on a shell that was just too good to throw away.
And, yeah, save your money on the Kawahara flywheel. Your lap times will be much better served with the Evo conversion even if you have to wait a while to get it.
Old 08-02-2004, 07:34 PM   #11468
kiddyno..i'm good thanks.
ok one last question atleast for a while, taylor racing mention about the "wont fit the overdrive pulley system" are you talking about the after market pulleys that gives you the 20% taller gear ratio?.....i'm running the side pullys of 19 and 25 tooth gears would the g4 side belt work with that combo?...
appretiate any helps fellas.
bmain is offline   Reply With Quote
Old 08-02-2004, 07:38 PM   #11469
oh and thanks for the warning about the yellow belts.
Old 08-02-2004, 11:37 PM   #11470
compaq888's Avatar
Send a message via AIM to compaq888
There is no way i can afford the evo conversion, i spent my last dollar on a new radio, having a good radio is more important than upgrading and already good car
also I did something similar to the back window but it doesn't help much.
compaq888 is offline   Reply With Quote
Old 08-02-2004, 11:43 PM   #11471
Bmain, what TR means with the overdrive system is the different side pulley. with the VoneR it had a 1:1 drive ratio with a 27t side pulley. The RR onwards has a 25t side pulley which changes the drive ratio. As a result of a smaller pulley the belt legnth changed by a few mm. Hope this helps.
Dexter is offline   Reply With Quote
Old 08-03-2004, 12:35 AM   #11472
Way to go Dex! B-man, I couldn't have explained it better myself.
Old 08-03-2004, 10:39 AM   #11473
kewdawg's Avatar
Glad I could help. Us Kyosho racers have to stick together.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 08-03-2004, 02:18 PM   #11474
Default Kawahara Micro Clutch
Hey guys, I'm using the Kawahara Micro Centax Clutch and I was wondering if any of you know where to get a spare clutch shoe for it. Or if there's another brand that would fit.
I has a 3D clutch and used shoes from my other Reflex's clutch. So if you know of any other micro clutches, I'd appriciate it if you pointed me in whatever direction.
Old 08-03-2004, 02:57 PM   #11475
Default Carbon Composites for RR-Evo
Has anyone tried the front or rear bulk heads? Are these parts lighter than stock?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
