Old 07-29-2004, 11:33 PM   #11431
compaq888's Avatar
Send a message via AIM to compaq888
cool
compaq888 is offline   Reply With Quote
Old 07-30-2004, 12:33 AM   #11432
compaq888's Avatar
Ok, I checked and the ride height for the front is 5mm, and the back is 5.5mm
The toe out is horrible in the front where both wheels turn outward. In the back the toe in is just right. I also need to adjust camber and caster.
Old 07-30-2004, 06:00 AM   #11433
kewdawg's Avatar
Default Re: Turn Your One-Way into a Locked Spool
Originally posted by kidDynomite
Try this one. The last one was too hard to read.
Thanks, well done!
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-30-2004, 06:15 AM   #11434
kewdawg's Avatar
Default Re: NTC3 Tank Mod on Evo
heres a better shot of the bottom layout.
Can you brighten-up these pics or shoot them with more light aimed at the area in question? I can't see the mod work at all.
Quinn Moon
Old 07-30-2004, 10:29 AM   #11435
BrainTeased's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: running one-way
Originally posted by kewdawg
Sounds like your too thick/heavy in the rear(Remember: the more traction, the track has - The thicker the diff oil should be). Try 7,000 wt. or 5,000 wt. diff oil.
Thanks once again Kewdawg! makes sense now that the other guy at the track told me to use 5,000 in the rear to get more traction as my track hasnt got much traction. somewhere i also read that the thinner the oil the more diff action. how does this effect traction may i ask please?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-30-2004, 11:45 AM   #11436
kidDynomite's Avatar
Default NTC3 Tank Mod on Evo
KD, Here's another illustration of how I set up the tank and battery tray. You could also customize a graphite or plastic tray for a battery holder. Let me know if this helps.
kidDynomite is offline   Reply With Quote
Old 07-30-2004, 12:42 PM   #11437
Tom G's Avatar
Kid TNT [sorry, couldn't resist] you have very good mods and the illustrations are superb.
Got me thinking about pulling out the dremel and mitre box!
Very well done.
A ^5 and a []0 'o beer
Tom G
Tom G is offline   Reply With Quote
Old 07-30-2004, 01:00 PM   #11438
Thanks T, my real name is actually Tom T, hence TNT.
I'm glad you like the mods.
I've actually been using this tank set up for about a year now. Lowering the throttle servo to about .02mm above the bottom chassis helps too. I just put on a Kawahara micro clutch that gets the engine to about .01mm from the chassis also. And with the spool ... the rear never kicks out. And on throttle, it turns like a charm.
Here's another more simple mod, cut open the upper deck (circled in yellow). It saves on belt wear and tear. If can, I also mitred the bottom chassis where the front belt runs along. About 1.2mm. I haven't replaced a belt for the longest time.
Good luck, bud! Let me know if you have any tricks to share.
Old 07-30-2004, 01:54 PM   #11439
kewdawg's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: running one-way
Brain..., you'll find the answer on pages 380 and 381. You already asked me this question! Dude, you gotta start reading back a few pages, every now and then.
Quinn Moon
Old 07-30-2004, 01:58 PM   #11440
kewdawg's Avatar
Thanks for the diagrams. Nice work!
Quinn Moon
Old 07-30-2004, 02:09 PM   #11441
Anytime, kewdawg!
Old 07-30-2004, 04:57 PM   #11442
compaq888's Avatar
kid, I sent you a PM about your pipe.
Old 07-31-2004, 03:51 AM   #11443
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: running one-way
lol yea i know i was just trying to re-confirm my thinking! as you said the thinner the oil the more diff action and you said this results in less traction! since my track has less traction you advised thinner diff oil. And it works!!! i love the new diff oil in it i have so much confidence in it! and im running 40 rears now and the tire wear is much better compared to 37's... i just wanna learn why is 5,000 diff oil in the rear = less traction yet on a low bite track it has more traction... confusing hey?
And thanks for your help and support lately! i've 90% learnt all i need to know about diff oil the 10% left over is full schematic reasons
Cheers
Old 07-31-2004, 04:00 AM   #11444
compaq888's Avatar
does my car weigh right? I weighed mine with everything installed and an empty gas tank and it weighs 1698grams, which is about 3.7 lbs.
Old 07-31-2004, 05:53 AM   #11445
c888, that sounds about right.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
