Old 05-29-2004, 09:00 AM   #11176
diesel's Avatar
Hey mike, are those mugen rear uprights your using?
diesel is offline   Reply With Quote
Old 05-29-2004, 09:17 AM   #11177
rice's Avatar
question?
dude did you trying using finer pitch on spur 1st and 2nd gear?
like mugen gears.
rice is offline   Reply With Quote
Old 05-31-2004, 12:12 PM   #11178
compaq888's Avatar
Send a message via AIM to compaq888
I finally got a RR!
can you guys post pics of your RR, not Evo, but just the RR. I want to see what you guys do to it
compaq888 is offline   Reply With Quote
Old 05-31-2004, 12:18 PM   #11179
Originally posted by Finken
i have a problem with understeer out of corners, into corners its great. front:
Black springs,50 wt oil, stiffest bar settings 0 droop
Rear:silver springs, 30 wt oil, kit sway bar 4 m droop
Try this
Front:
Silver sway bar
60 wt shock oil
1 deg toe out
Rear:
No sway bay
70 or 80 wt shock oil (see w/c works better for your car)
2 mm droop
2 deg toe in
Dannoq1 is offline   Reply With Quote
Old 05-31-2004, 04:08 PM   #11180
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default for sale
hi guys..i need some cash... take a look.
FOR SALE
Kyosho 1/10 V-One-RR Evolution. This is the genuin kit. not the upgrade kit.
Brand new, never ran. this is an exspensive car to replace..
.im selling as im desperate for cash....
Gen Kyosho graphite radio tray #vzw051.
kawaharra active diff
'5 star' rear alu. camber link set
Gen Kyosho front and rear titanium layshafts. #vz025 & #vz026
Gen Kyosho brake holder.
Alumin. gear holder.
'K Factory" brake disc.
'3 Racing' chassis with graphite battery holder.
'3 Racing' left chassis stiferner.
'3 Racing' right chassis stiferner.
light weight 750 nmh battery pack.
Gen kyoshp alumin gears. 25.26.27....
'Shimo' front one way and out drives..
'Kawaharra' 1st gear carrier.
'K Factory' carbon rear top brace.
titanium front one way gear.Gen Kyosho alumin. drive hex's
"3 Racing' .2 roll plate.
K Factory front hinge pin holder.
Kawaharra graphite front shock tower.
Kawaharra graphite rear shock tower. plus varius different rear towers
Alumin. rear 'GT' mount.
All Titanium screws and purplu alumin washers.
Lowered engine mounts and matching fly wheel.....
Novarossi 'JP NS3 Worlds'......as new, very fast....
$800.00 aus.....plus frieght......
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 05-31-2004, 04:09 PM   #11181
mikecatts's Avatar
Default v one parts
FOE SALE
KYOSHO V- One-rr Evolution spares and upgrades.
2 x Gen Kyosho alumin. difss. complete 1 with k factory hard blue gear.....$ 70.00
1 x Gen Kyosho LSD diff complete..........$100.00
1 x Gen Kyosho adjustable slipper diffcomplete .....$70.00
2 x GenKyosho front one ways new...$15.00
1 x go fast gear kit never used, in packets...complete (15 toth spur49 tooh pinnion, 66t rear belt,
side belt,2 x 24 tooth pulleys....$70.00
Gen Shimo front one way plus out drives...$60.00
Team Kyosho '26' tooth front pulley...2.5 split..$20
Complete gear box, including Gen kyosho titanium lay shaft,
titanium 19 tooth gear.
alu gear holder.
titanium brake holder.
K Factory brake disc.
gears, one way, second gear box..$120.
Gen Kyosho parts.. still in gen kyosho packaging..
part numbers are:2 x vz 106 front swing shaft $$10.00 each
1 vzw013 middle belt 378 t...$10.00
1 x vzw 020-1 diff caser seals.pkt 4..$$6.00
1 x vz015 diff joint..$8.002 x vz098 rear body post..$4.00each.
set titanium rear dog bones..for vone r $20.00
1 x vz113-61 fispur gear..$8.00
3 x vz113-60 first spur gear..$8.00 each.
1 x vz114-55 2nd spur gear...$ 10.00
1 x vz114-56 2nd spur gear...$10.00.
1 x vz004 rear susp arm set...$10.00
1 x vz101 front susp. arm set...$10.00
1 x vz009 diff gear set..( no main diff gear)...$10.00
1 x vz103 small parts set..$6.00
1 x vz102 servo saver holder....$7.00
1 x vzw050 SP main chassis new.....$60.00.
9:12 PM 5/31/04
Old 06-02-2004, 03:49 AM   #11182
BrainTeased's Avatar
HEy guys
My mate just brought a Evo conversion kit for his RR but he seems to have trouble putting in servos and a front RR open diff and brake and throttle linkages and some other minor problems as well.
I was just curious as if its a conversion kit im sure it shouldnt be to much of a hassle. Has anyone done a Conversion from a RR to a RR evo had any problems while building/converting the car?
All comments appreciated thanks.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-02-2004, 01:27 PM   #11183
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
If he tried to put the RR diff in it then of course he's going to run into problems. The bulkheads are narrower on the Evolution. i don't know about the conversion kit but my Evolution kit came with a frount diff case.
What problems is he having with the servos and linkages? What kind are they?
Racing4Evo is offline   Reply With Quote
Old 06-02-2004, 02:05 PM   #11184
hi all, i have an evo and was wondering if i can use the 1.0 pinion and spurr from the rr and would it be a direct fit? appretiate your help, thanks.
elephant is offline   Reply With Quote
Old 06-02-2004, 06:26 PM   #11185
drfritz's Avatar
drfritz is offline   Reply With Quote
Old 06-02-2004, 06:31 PM   #11186
drfritz's Avatar
Originally posted by BrainTeased
HEy guys
did the converson on a reflex, the throttle/ brake horn has to be trimed on the throttle side, needs different front diff out drives, conversion comes with diff case.
Old 06-03-2004, 12:26 AM   #11187
thefuzzclub's Avatar
Default RR EVO GEARING
what gearing (spur and pinion combo) can you recomend in a small technical track? thanks
thefuzzclub is offline   Reply With Quote
Old 06-03-2004, 12:46 AM   #11188
boner's Avatar
Stock gearing or the try 20/25 on the pinion.
boner is offline   Reply With Quote
Old 06-03-2004, 12:52 AM   #11189
It's fine as long as you use the same pitch pinion and spur gears. You can use the old stuff.
Old 06-03-2004, 04:46 AM   #11190
Thanks for the reply guys
ummm i havent exactly seen the problem he is having as he has told me through email. He just said that the servos wont fit in and they are Standard Servos from the XS3 radio he just got. i told him 100% they should fit. and with the throttle and brake linkages he said something about the upper deck handle is in the way. I told him to just bend the linkages abit (make a slight curve) for it to fit. im waitin from a response back from him.
drfritz: thanks for reply
So if conversion comes with diff cases can he take out the gears from the RR diff and shove it in the new evo diff casing and then just get outdrives for it? doesnt front one ways use outdrives too?
Anyone else done a conversion from a RR into RR evo? had any probs?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
