Old 05-18-2004, 06:49 AM   #11146
Taylor-Racing's Avatar
Originally posted by V1R racer
Hi
Does anybody know when the V-1-RRR will be on sale and will the 3D clutch fit my RB x12 serpent style crank.
Yep, the clutch will fit the X/12 Serpent crank.
Taylor-Racing is offline   Reply With Quote
Old 05-18-2004, 12:48 PM   #11147
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally posted by Taylor-Racing
Yes, the 14mm height 05R mounts will fit the EVO, but in lowering the engine, the pinions are then unable to engage the spurs. I'd considered elongating the holes in the chassis, but it would be rather too much. Some mounts with offset holes might work.
I expect the RRR would have the engine mount holes in the chassis about 3mm further back.
I installed the FW-05R engine mounts and 33mmm flywheel with no impact to the gear mesh. The only modification I had to do was grind down some of the chassis on the uppper side of the flywheel opening so that the clutch bell wouldn't rub against it. In fact a lot of people around here are doing this with their Evolutions.
Racing4Evo is offline   Reply With Quote
Old 05-18-2004, 01:09 PM   #11148
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default lower engine
hi guys, ive been lowering the engine since the first v-one -r.
try 16mm mounts and a 31mm fly wheel. ( you need a lathe and mill).......its great.
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 05-18-2004, 01:11 PM   #11149
mikecatts's Avatar
Default mistake
sorry guys..its too early..4.30am here....try 12mm engine mounts and 31mm flywheel
Old 05-18-2004, 08:31 PM   #11150
Oasis's Avatar
Trader Rating: 36 (100%+)
Is the VoneRR a good car to race? I might be trading for one but I would like to have a car that can be competitive,and find parts for it.Thanks for any help/input.
Oasis is offline   Reply With Quote
Old 05-18-2004, 10:19 PM   #11151
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Yes it is a good car to race. Some of the Ol timers can attest to this. I have had mine for 3 years
HEYALIGNMENTGUY is offline   Reply With Quote
Old 05-19-2004, 03:01 AM   #11152
if you cant win with this car then you wont win with anything else it is still a very competitive car in all but a worlds quality drivers hands and even they would kick arse with it
KIMCOM RACING Driver #1
RC8B : REEDY 121 : Nitro-X fuel : Spektrum Radios
gkp5569 is offline   Reply With Quote
Old 05-19-2004, 05:30 AM   #11153
That's interesting. I was also using 14mm engine mounts (I think the FW's are 14mm) and the 33mm flywheel.
But I couldn't get the engine back nearly far enough to have the gears mesh properly. We're using the Shimo chassis and while I haven't compared the engine mounting holes to the standard chassis, I would expect them to be in the same place. Maybe I should check this again.
Yes, we also had to do a bit of a dremel job to clear the clutch bell.
Old 05-23-2004, 02:11 PM   #11154
Hi fellow Evo racers. I have a huge problem with my Evo. Today at a race, hight temp 25 degrees, very good tracktion, i keept tracktion rolling, in most turns. i am using 50wt oil and org. springs in front, 40 shore tires, and anti roll bar at it stiffest. In rear 30wt/silver springs.
Problem is, i feel that i need much traction to hold the speed thru the corners, where Mugen and G4`s are passing much faster.
My car oversteers huge into corners and understeer out, maybe i should change my driving style??
Finken is offline   Reply With Quote
Old 05-23-2004, 03:56 PM   #11155
mikecatts's Avatar
Default traction rolling
hi guys.... to stop the car traction rolling. we found that you have to drill another hole on the rear shocker tower as low as you can..( see pic) make sure the shocker is on the top hole and the camber link is on the lower inside and highest outside......4mm ride height, and make sure you srub the outer edges of your tyres rounded.....
Old 05-23-2004, 03:59 PM   #11156
mikecatts's Avatar
Default pic 2
heres another pic i hope it helps
mike
Old 05-23-2004, 04:08 PM   #11157
But isnt the problem in the front of the car?? Its the front hooking that makes the car tracktion roll? isnt it?
Old 05-23-2004, 04:43 PM   #11158
mikecatts's Avatar
we tried every thing on high traction tracks to stop it traction rolling....this worked....we also use the upgrade front tower. ( i made my own).to raise the front shockers....the rear makes a much better improvement as it allows the rear to have a greater camber angle in the corner,,hence no traction roll....if you just want to turn flat stick in the corner...no car will do what you want.............................................. ..............
Old 05-23-2004, 05:52 PM   #11159
what springs are you using, and oil?
Is it faster to brake before corner, and full speed out, and make the car having more on power steering than off?
Old 05-23-2004, 10:23 PM   #11160
Have you tried stiffer springs like the GOLD ones or maybe thicker oil #60 or even 45 shore tire, Another thing I have tried is change the Caster angle. Also try changing the front roll center
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
