Old 05-13-2004, 07:37 PM   #11116
B
Originally posted by Nitropimp
B those pics are awesome!! Thanks. Did you see any Yokomo stuff on the www? Man that engine looks HOT. Is that a Kyosho Engine? Also wouldn't you think that they would have put a one piece pipe?? Maybe they like the 2 piece performance better? My only complaint is I don't have one yet
That would be everyone's complaint no?
That is a Sirio EVO2 Engine I believe (correct me if I'm wrong guys). Unfortunately, I did not see any Yokomo nitro touring cars on the website. I do not have a link to the site at the moment, but if you browse the EP thread, you can find it under the new kyosho EP thread.
B is offline   Reply With Quote
Old 05-13-2004, 10:29 PM   #11117
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Post
B nice pics man, i was planning to get the g-4 evo but after seing those shot of yours i changed my mind and will be waiting for the RRR to arrived here in our LHS one question though, have seen two chassis in the pix, is the other the optional chassis
buboy28 is offline   Reply With Quote
Old 05-13-2004, 10:46 PM   #11118
B
The other chassis is the old chassis for the EVO. The picture just shows a comparison between the old and the new.
by the way buboy28, u got PM
Old 05-14-2004, 01:33 AM   #11119
buboy28's Avatar
B, received your pm thanks for the info by the way any news how much the RRR is going to cost
Old 05-14-2004, 02:26 AM   #11120
esham's Avatar
found them
B I believe this style of laying servo look familiar . Is it ..like G4 design. OOOO Man... i have itchi hand now.. Just got FW05R and now..RRR. Can't stop dream to have it...
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 05-14-2004, 03:29 AM   #11121
compaq888's Avatar
Send a message via AIM to compaq888
*drool* the new RRR is really nice. It looks like the plastic pieces are smaller/lighter. I just hope it's not a pro kit
compaq888 is offline   Reply With Quote
Old 05-14-2004, 03:44 AM   #11122
BrainTeased's Avatar
Default centax clutch
Hey guys how you all doing?
Was just wondering how to adjust the centax clutches on the VoneRR's? is it by tighting the donut thing that holds the big spring on to the crankshaft? or is it done with an allen car in that little hole above the bellhousing? :?
Thanks in advance guys :!:
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 05-14-2004, 04:08 AM   #11123
esham's Avatar
Default Re: centax clutch
Please refer to the link Brain... It matter of correct shiming. The "donut" holding the spring is to tune the engagement of the clutch. What you have to confirm check is the clutch gap and the end play gap and check if you use the correct length of the allen screw...
refer below attachment
Mytsn serpent
Old 05-14-2004, 04:17 AM   #11124
esham's Avatar
Brain,
The end screw should around 3x12 or 3X15 base on your engine as stated in the manual. If it too long you will have too loose centax assembly.
The spring adjuster or cap "donut" as you call it should be use to adjust the torque clutch engagement. The basic - you tighten it to get late clutch engagement and more torque (more pick up) but you loose it if you want it less torque less pick up. Theory base low traction you have to loose it and high grip traction track you can tighten it to get more pick up (acceleration).
One thing to carefull base on my beginner experience, if you tighten the spring until make the engine to "noisy" before it engage or at top of the limit means you tighten it too far. ( Not good for you engine..) So loosen it abit until you can get clutch engagement just perfect and still you can have ability to punch the throttle abit more till top speed...
Old 05-14-2004, 04:18 AM   #11125
Sow&Steady's Avatar
The only complaint I have would be that it seem like that only the type of receiver battery (a heavy kind) can be used. If AAA receiver batteries are used , the weight will be reduced.
However, due to limited spaces, it may not have been possible without raising the tank even higher or hurting the left/right balance.
O well, otherwise the car looks killer.
I would agree with the tank ...
Also I wished manufacturers would make available low CG heatsinks! They would be perfect for the RRR or the G4.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-14-2004, 04:29 AM   #11126
Originally posted by esham
Brain,
Thank you very much for that Esham! yea i was looking to adjust my clutch so it would engage later!
Also what is that allen screw in that little hole in the clutchbell used for?
Old 05-14-2004, 04:31 AM   #11127
Taylor-Racing's Avatar
B you know it's all good. I agree with you 100%. Like I said it this was posted in the TM WWW forum. I think the "RRR" wheel screws are the same as the G4 too. So there you have it the tires and screws exact copies of the G4.
Just as long as they don't copy the steering system, eh.
Taylor-Racing is offline   Reply With Quote
Old 05-14-2004, 04:43 AM   #11128
Thanks for the great pic's, B.
The car looks good though the throttle servo is a little exposed.
I particularly like the little tray on top of the receiver - somewhere to put those G4 wheel nuts while contemplating what tyres to use.
Old 05-14-2004, 08:09 AM   #11129
apmk's Avatar
Its for external adjustment of the clutch.
apmk is offline   Reply With Quote
Old 05-14-2004, 11:08 AM   #11130
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default shizouka hobby show
is there a website that posts lots of pics of cars displayed on the hobby show? any brand?
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
