Old 04-26-2004, 05:21 PM   #10981
drfritz's Avatar
Originally posted by disaster999
im kinda new to nitro, first time actually racing nitro, my brother is kind enough to lend me his voner to race with. i have a question tho. the side belt seem to be dragging the whole drivetrain. if i take it off, and leave the front and rear on, its pretty smooth. also, the oneway bearing inside the 2 speed is really gritty. i cleaned it out with everything i have, but non of them seem to work. my question is what kind of side belts do you guys use to free up the drive train, and what could i do to clean the oneway bearing without telling me to buy a new one
Try soaking the belts in wd40 over night. MR johnson speaks of this in last months car action. and yes I have tryed it and it works, car rolls like shaft car.
drfritz is offline   Reply With Quote
Old 04-26-2004, 05:29 PM   #10982
AMGRacer's Avatar
Originally posted by mrckymrk
Hey AMG, I noticed that the rear was quite loose when using the mugen rear hubs. How much camber do you recommed and is it suppose to be this way? I did feel that it takes a little getting use to but I think it is faster around corners.
This may be. The Mugen hubs induce more camber change through the corner. Basically you need to run much lesser camber. I can get away with 2-3 in the rear usually. A lot of static camber along with a lot of camber change will make the rear loose for sure.
AMGRacer is offline   Reply With Quote
Old 04-26-2004, 06:38 PM   #10983
Default Re: Re: Diff action
Originally posted by drfritz
I to run on a very tight track, This is what I ran in the Vonerr last year 30,000 front and 30,000 in the rear.
wont the same diff oil on both front and rear make the car push on power?
JPRacing is offline   Reply With Quote
Old 04-26-2004, 08:02 PM   #10984
drfritz's Avatar
Default Re: Re: Re: Diff action
The car felt very neutral with those weights in the car.
Old 04-26-2004, 11:05 PM   #10985
Nitropimp's Avatar
Man I hate to sell my RR but it's time to move on. I got a great deal on another MTX-3.
AMG- thanks for all your help on the RR.
Rob- good luck on your RR. Hope you get it dialed in.
Well anyone interested in a nice "RR" here it is.
http://cgi.ebay.com/ws/eBayISAPI.dll...ESSE%3AIT&rd=1
Nitropimp is offline   Reply With Quote
Old 04-27-2004, 01:09 AM   #10986
Taylor-Racing's Avatar
disaster999,
You might change the belts to the SP ones - they make quite an improvement to the free roll.
Cleaning and lubing one-ways seems to prodce variable results. Some say to clean the one-way bearing with a degreaser, carb cleaner or motor spray - anything you can squirt in there under pressure, I'd guess, and then lube with Serpent one-way lube - never tried it personally.
Since the bearing is pretty well protected from dirt, I'd be suspicious that the grittiness is the bearing being past it's use by date.
You've covered the obvious answer on the one-way bearing. They aren't that expensive.
Taylor-Racing is offline   Reply With Quote
Old 04-27-2004, 01:20 AM   #10987
ziggy12345's Avatar
When i converted my RR to Evo the side belt was really tight. I changed to the low friction belts from Kawahara and it freed up the drive train no end
ziggy12345 is offline   Reply With Quote
Old 04-27-2004, 02:03 AM   #10988
esham's Avatar
But carefull in using Low friction belt from Kfactory - G4 which suit V1RR. I did have bad experience with the that belt pitch worn out very quickly. The original kyosho belt seem still the best choice..for me. Probably the low friction belt from Kawahara is strong and smooth.. never try that..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-27-2004, 02:47 AM   #10989
Similar experence here, esham.
We tried the K-Factory/G4 side belt. I found it difficult to see any real difference in "freeness" from the SP belts, but that might just be me.
We installed all new belts for the Vic. Titles and at the end of the event I noticed two/three places with missing teeth. The front and rear belts were Kyosho SP's.
This was on a permanent track where stones aren't usually an issue. Nevertheless, I guess we could have been unlucky.
Old 04-27-2004, 10:55 AM   #10990
You are so right Esham. That happened to me in a race and I was really mad at those k-factory belts. Don't get me wrong...I love k-factory. As a matter of fact, all my cars have all the k-factory parts. I am just shocked that they put out a crappy belt.
Old 04-27-2004, 01:30 PM   #10991
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Sorry to see you go the other way, but thank you for all the help you've given me on the RR.
Rob Hochberg is offline   Reply With Quote
Old 04-27-2004, 11:06 PM   #10992
diesel's Avatar
Hey guys, is an LSD = a TCD? Do you use an LSD in the front or rear? Any links and brands of LSD to recommend? Pls enlighten..Thanks lots.
diesel is offline   Reply With Quote
Old 04-28-2004, 09:10 AM   #10993
Yes the LSD = a TCD.
The TCD is from Kyosho - don't think there's an alternative brand available.
You could use it in the rear or front diff, but I'd expect most would use it in the rear with a one-way up front.
We use the Kawahara Negative diff - haven't used the TCD at all, so hopefully someone will chime in here.
Old 04-28-2004, 10:31 AM   #10994
diesel's Avatar
Yo Taylor, thanks for the prompt reply. Can you direct me to a good online hobbyshop that sells the kawahara neg diff? Cheers.
Old 04-28-2004, 10:46 AM   #10995
You might try Harmony in HK.
There's no on-line shop as such. Just send an e-mail to Mr Lam.
[email protected]
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
