Old 04-23-2004, 10:29 PM   #10966
carkillaii's Avatar
Does anyone know any new info about the RRR
carkillaii is offline   Reply With Quote
Old 04-24-2004, 12:51 AM   #10967
Nitropimp's Avatar
Carkillaii- http://www.kyosho.co.jp/main-j.html you need to Altavista to translate it.
This is cool-http://www.kyosho.co.jp/main-e.html
Nitropimp is offline   Reply With Quote
Old 04-24-2004, 03:21 AM   #10968
carkillaii's Avatar
thnx nitro
Old 04-24-2004, 11:03 AM   #10969
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default world cup
what car did they use? v1s 2 or the fwo5s?
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 04-24-2004, 03:28 PM   #10970
Nitropimp's Avatar
AMG- you got another PM.
thanks
Old 04-24-2004, 06:57 PM   #10971
Trader Rating: 17 (100%+)
Well guys, first time out today and the car still runs like a champ even as the original v one r. The car was very fast in the infield and down the straight, but I feel like I am way behind in time on this car even though I can still win with this car. It was still chilly and windy today so traction was hard to come by. Do you guys think it would be worth buying a new car versus upgrading?
429racer is offline   Reply With Quote
Old 04-24-2004, 07:17 PM   #10972
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
I also took my V one RR out for it's maiden voyage today, and I was very impressed. The gold springs hooked up pretty well at my track. I had a few mechanical failures throughout the day. I got there at about 9:15, ran it a few laps, then, my reciever pack wire got cut, and the car took off, smack into the wall. I was very, very upset. I luckily had enough parts to fix it, then ran it. 3rd qualifer, I hit the wall and seared off the hole in one of my front wheels. Main, I ripped the pipe coupler, so I decided to save my P/S rather than finished the race. My 2 speed was grabbing 2nd gear a little too late, and not always in the same rpm range. I'm having a lot of trouble getting that screw that holds the 2 speed assembly together, the guy must have torqued it to like 100000000 ft/lbs! Anyone have any suggestions? Running nitro gets you so dirty! I'm taking a shower.
Thanks for the help in advance.
Rob Hochberg is offline   Reply With Quote
Old 04-24-2004, 08:04 PM   #10973
Well if you are hitting your second gear a little late, it sounds to me that you need to loosen up your clutch adjustment screws maybe an 1/8 of a turn if not a little less. I found that I had to clean the two speed often to get it to shift consistently.
Old 04-24-2004, 09:41 PM   #10974
Sometimes it would shift where I wanted it, and sometimes it wouldn't. What exactly do I clean? The 2nd gear bell? I loved hearing it shift and downshift, it was awesome. I appreciate your answers.
Old 04-24-2004, 09:46 PM   #10975
Clean the outside of the clutch where it grabs onto the two speed housing. After time of running, fine dirt or dust will build up between them. You might check the springs in there to see if they are worn.
Old 04-25-2004, 07:12 AM   #10976
Taylor-Racing's Avatar
For inconsistant gear changing, you might want to take off the clutch shoes and clean inside them where the rollers run. It tends to gather some crud in there after some time.
Taylor-Racing is offline   Reply With Quote
Old 04-25-2004, 08:32 PM   #10977
Default Diff action
Hey guys, need your help if possible.
I run an evo on tight tracks here in the philippines. I was wondering what suggestions you guys have with regard to the diff oil that I should use front and rear.
I need for the car to be quick in turns and, again if possible, quick coming out of a turn. Thanks a lot
JPRacing is offline   Reply With Quote
Old 04-25-2004, 10:27 PM   #10978
drfritz's Avatar
Default Re: Diff action
I to run on a very tight track, This is what I ran in the Vonerr last year 30,000 front and 30,000 in the rear.
drfritz is offline   Reply With Quote
Old 04-26-2004, 10:34 AM   #10979
Regional Moderator
disaster999's Avatar
im kinda new to nitro, first time actually racing nitro, my brother is kind enough to lend me his voner to race with. i have a question tho. the side belt seem to be dragging the whole drivetrain. if i take it off, and leave the front and rear on, its pretty smooth. also, the oneway bearing inside the 2 speed is really gritty. i cleaned it out with everything i have, but non of them seem to work. my question is what kind of side belts do you guys use to free up the drive train, and what could i do to clean the oneway bearing without telling me to buy a new one
disaster999 is online now   Reply With Quote
Old 04-26-2004, 01:52 PM   #10980
boner's Avatar
D999: did you check for any thing dragging? your car doesn't have that much drag before you convert into evo. maybe you need to clean your bearing. or a new set of bearing :-)
boner is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
