Old 04-05-2004, 04:18 PM   #10846
boner's Avatar
first i'll check to see if you have your 2nd speed shoe holder (FM361) sceured to the main shaft. then check to see if there are any oil on the 2 speed clutch bell. A rebuild on your 2 speed will fixes your problem
boner is offline   Reply With Quote
Old 04-05-2004, 06:47 PM   #10847
tazman34685's Avatar
Default The hunt for 2nd Gear
Two quick questions: { Thanks for the advice I've inpected and rebuilt , still only running in first}
Question 1) Can the old set-up work with the Evo Gear-Set
Question 2) What is the Max number of turns can be tried
Again Thanks
tazman34685 is offline   Reply With Quote
Old 04-05-2004, 06:54 PM   #10848
Manticore's Avatar
R/C Tech Charter Subscriber
try 3 turns out first. you could have the 2speed engaged too early instead.
Manticore is offline   Reply With Quote
Old 04-05-2004, 07:39 PM   #10849
So the proper setup is 3 turns out, I currently have it set to test at eight (8) turns out...
Old 04-05-2004, 08:14 PM   #10850
Manticore's Avatar
Unhappy
this is way too early !! your 1st gear has never been used.
Old 04-05-2004, 08:33 PM   #10851
carkillaii's Avatar
when is a good time to replace the clutch?
carkillaii is offline   Reply With Quote
Old 04-05-2004, 08:36 PM   #10852
AMGRacer's Avatar
You should never have to full replace it. Nothing except the clutch shoe and thrust bearing should wear if it is tuned and maintained properly. Things I would check:
1. Clutch shoe should not be glazed or overly worn looking. If so replace.
2. Thrust bearing should be smooth and balls should roll freely. If unsure you can replace.
3. Clutchbell bearings should be clean and roll freely. If they are binding or too dirty replace.
The remainder of the parts should last almost forever.
AMGRacer is offline   Reply With Quote
Old 04-05-2004, 09:35 PM   #10853
Manticore's Avatar
one more thing to add on top of what amgracer's comment.
sloppy bearings will jeopardize clutch end play.
Old 04-05-2004, 11:14 PM   #10854
Nitropimp's Avatar
My nightlly question.......Manti- I have a brand NEW V one RR with the Kyosho Neg diff. in the rear. I was going to change over to the Evo with a converion kit but with the RRR coming out, should I wait....? Will the RRR have a conversion for the RR? Or should I just sell the RR??? Aslo is there anywhere I can see how to switch the V one RR to the Mugen rear end (what parts I need?) When is the RRR coming out? Sorry about soo many questions but man I confused.... Is there a V one Manticorrrrre???
Thanks.....
Nitropimp is offline   Reply With Quote
Old 04-06-2004, 12:34 AM   #10855
Manticore's Avatar
Thanks.....
i really dunno cuz i am not kyosho, all of these discussion are based on the pictures shown on kyosho website.
Old 04-06-2004, 01:52 AM   #10856
Manticore's Avatar
Thanks.....
yes i have a manti spec VonrRR EVO !
Old 04-06-2004, 10:02 AM   #10857
kewdawg's Avatar
guys,
can the "M1RR" conversion be avoided by adding shims/washers under the ball stud?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-06-2004, 10:57 AM   #10858
Manticore's Avatar
Originally posted by kewdawg
guys,
the stock rear upright only provides you with 2 camber link angle. the use of mugen upright is to provide more camber link angle with very fine adjustment flexibility.
wait for the RRR and it comes with mugen type or fantom type rear upright.
Old 04-06-2004, 10:20 PM   #10859
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Thanks.....
I have one just like Manti's. I could let you check it out any time you have free time.
HEYALIGNMENTGUY is offline   Reply With Quote
Old 04-06-2004, 10:22 PM   #10860
Oh Hi fellas been a wile since I posted anything on thread.
I bought a Mugen MRX3 and am having a ball with it since the Nats are in my home area this year
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
