Old 03-26-2004, 09:20 AM   #10741
Send a message via ICQ to noobatron
Default Re: Re: new v one rr evo
Originally posted by Taylor-Racing
. . . oh yeah, buy an alloy brake stopper.
hehehe gave loves that alloy brake stopper
noobatron is offline   Reply With Quote
Old 03-26-2004, 08:11 PM   #10742
diesel's Avatar
Default Hopups!!
Hey folks, i just bought a brake stopper w/19T pulley, a pair of front universals, alu. front center bulk and front upper arm mounts for a start...they are recommended by my LHS. All from 3racing though..thats what they have there.
I am now thinking of getting a rear body stay, alu. stiffence and the side mount support to strengthen the car...what do you guys think? Also, is there a need to change the pulleys to aluminium ones and what other important parts have i left out? Cheers.
Thanks.
diesel is offline   Reply With Quote
Old 03-27-2004, 01:56 AM   #10743
Never had a problem with the plastic brake stopper myself but i know of a few people who have had them break or melt. For hop ups, i would suggest alu wheel hexs, CARBON Y brace, side brace and a stiffer chassi and top deck but i don't think their imperative.
Diesel, I think most people will agree that the alu pulleys aren't high on the priority list at all and a fair few would probably say it's more of a hinderance .
Dexter is offline   Reply With Quote
Old 03-27-2004, 04:02 AM   #10744
Taylor-Racing's Avatar
Default Re: Re: Re: new v one rr evo
Oh, am I looking a little paranoid.
Yes, we've had a bit of trouble with the placcy brake stopper, though many haven't - cracked ones, broken out pins on another, and one that was completely gone/missing after one heat. Considering the brakes are not heavily used with a one-way, I'm at a loss for an explanation. Even the ally one came loose at the recent Vic. Titles, but that's really the pit man's fault.
Dexter,
We know why you don't have the issue.
diesel,
In my opinion, anything that's alloy and high up, better be paying it's way in improved performance.
I'm with Dexter - forget the alloy pulleys.
Taylor-Racing is offline   Reply With Quote
Old 03-28-2004, 01:37 AM   #10745
Default Re: Re: Re: Re: new v one rr evo
Dexter,
diesel,
I can think of two reasons why, could u please clarify .
Old 03-28-2004, 06:14 PM   #10746
Default V one S Tires?
Hello all,
Just wondering if you think that the HPI Advan belted tires would be a good choice of tires for unprepared and dusty parking lots? I'd like the tires to last a while as this is just a play car for me. Any input or info would be much appreciated!
RCevolution is offline   Reply With Quote
Old 03-28-2004, 06:24 PM   #10747
esham's Avatar
Default Good centex clutch assembly
Hello guys, Is anybody know a guide or web link on how to assemble proper, good centex clutch?. Somebody told me the centex clutch with trust bearing is not pick up. Is this true?. Instead of using the trust bearing they change it with just using shims!
Any comments guys.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 03-28-2004, 09:40 PM   #10748
thefuzzclub's Avatar
Default how do you resolve understeer on tight turns
my set-up:
toe front - 0
toe rear - 2.5
camber front - 2
camber rear - 2.5
caster - spacers all in front
droop front - 0
droop rear - 3
shock oil front/rear- 40 wt
ride height front/rear - 5mm
front springs - black
rear - silver
tires - foams (45)
track - smooth asphalt / medium bite / semi technical
thefuzzclub is offline   Reply With Quote
Old 03-29-2004, 12:21 AM   #10749
Default Re: how do you resolve understeer on tight turns
Originally posted by thefuzzclub
my set-up:
toe front - 0
toe rear - 2.5
camber front - 2
camber rear - 2.5
droop front - 0
droop rear - 3
rear - silver
tires - foams (45)
hi,
i noticed that you have 0 for toe front. Forgive my noobiness if i'm wrong, but doesn't toe out at the front reduce understeer (according to the ackerman steerin priciple)? i have 1.5 degrees toe out at the front and my car is able to stick closer to the inner circle of hair pins. or is it just my driving?
Old 03-29-2004, 02:09 AM   #10750
my set-up:
<SNIP>
Are you getting the understeer on corner entry or exit?
But for somewhere to start, 45's sound rather hard for a medium bite track - try 37's. Next, I'd try either black rear springs or silver fronts.
This should get you in the ballpark,
Old 03-29-2004, 02:11 AM   #10751
Default Re: Re: Re: Re: Re: new v one rr evo
'Cos you don't use brakes . . . . or the engine . . . . or the steering . . . . lots of it, really.
Just joshin' wiv ya.
Old 03-29-2004, 02:28 AM   #10752
Default Re: Good centex clutch assembly
Any comments guys.
esham,
I'm not exactly sure what you getting at with the thrust (trust) bearing thing, but have a look HERE
Old 03-29-2004, 03:10 AM   #10753
esham's Avatar
Default Re: Re: Good centex clutch assembly
esham,
Thanks taylor, from the site what i understand there is no such without thrust bearing for centax system. Probably what the guy said to me is his own experiment.
Old 03-29-2004, 03:25 AM   #10754
Sp Racer's Avatar
You could try reducing some of that caster![
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 03-29-2004, 04:16 PM   #10755
Default Re: Re: how do you resolve understeer on tight turns
hi,
i agree, i'll try 1 deg toe out. thanks.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
