Old 03-23-2004, 10:07 PM   #10726
diesel's Avatar
Default Essential Hopups!!!
Hey guys, wat are the essential and 'must get' hopups for a RR Evo? I do not need any 'bling bling' parts here.
There are a few companies making these aftermarket parts for Kyosho like 3-racing and kawahara...which should i go for?
TIA
diesel is offline   Reply With Quote
Old 03-24-2004, 04:45 AM   #10727
Tom G's Avatar
Default Re: Essential Hopups!!!
TIA
Either brand is good, although I personally like the Kawahara stuff myself.
As far as components are concerned, get what is important to you; speed, traction, lightening, toughening, etc., etc., ... you can't go wrong if you improve on what you feel is important.
Tom G is offline   Reply With Quote
Old 03-24-2004, 07:15 AM   #10728
Taylor-Racing's Avatar
TIA
I reckon the 'must get' list is very short.
Alloy brake stopper.
But I reckon the following is worthwhile, and as you can see, most of this stuff is just to get the weight or CG down a bit.
Shimmo Chassis.
Carbon top deck.
Ti main shaft.
Ti middle shaft.
Ti Pivot balls.
AAA receiver pack.
FW-05 flywheel.
Lowered engine mounts.
Alloy left side brace.
Teflon pads.
K-Factory brake disk.
Alloy wheel hex's.
Carbon right side brace.
Alloy screws/nuts for lightly stressed mountings.
Taylor-Racing is offline   Reply With Quote
Old 03-24-2004, 11:38 AM   #10729
drfritz's Avatar
Default Re: Re: Essential Hopups!!!
whats the part number on those pads?
drfritz is offline   Reply With Quote
Old 03-24-2004, 04:28 PM   #10730
thefuzzclub's Avatar
Default locking front diff
after turning both wheels vice versa, it will lock. does this mean it lacks diff oil?
thefuzzclub is offline   Reply With Quote
Old 03-24-2004, 05:52 PM   #10731
jihernandez's Avatar
Default V-One RR Basics
Seems to me that all of the guys here pretty much experienced in the VOne with regards to tuning. It is in this light that I am asking for everyone's help.
I am a newby...a rookie...and I have a V-One RR. I already got some hop-ups - lightened chassis, kawahara shock stays, and other kawahara light metal stuff.
My diffs though are still stock.
What are the basic set-up I should do?
I currently have Rear Toe-in of 1 degree and Front Toe-out of 1 degree. Rear camber of 1 degree. Front camber is 2 degrees. Rear camber rise is 2.5 while Front camber rise is 1.75. Front caster is 9 degrees. Steering throw is 19 degrees.
All silver springs. Front shock oil is 30. Rear shock oil is 20.
With this set-up, I raced for the 1st time. Pros time are 16.something while I had 17.5 secs fastest lap.
I noticed in bumpy portions that the rear of the car bounces and causes me to lose a bit of control. This is because the amount of travel that the rear shocks are allowed is pretty small compared to my TL01. In my TL01 i have soft springs but the travel is greater and gives me a better droop. If I don't control the downstops of my RR, the chassis touches the ground.
Could you guys give me basic tips on how I can improve the handling and stability of my V One RR?
sorry for the long post
jihernandez is offline   Reply With Quote
Old 03-24-2004, 06:06 PM   #10732
Tom G's Avatar
Thumbs up Ihernandez set-up
Wow!
Mine takes 3 toe-in on the rear, 2-toe out on the front and I generally get away with black springs all around. The rest is pretty much about the same.
It's a pretty common set-up but this thing loves front toe out.
I would try a softer spring in the rear or lighter weight oil. See how it handles those bumpy sections and see if you're heading in the right direction. As always, one change at a time and keep a good data book sheet.
^5
Old 03-24-2004, 08:15 PM   #10733
drfritz's Avatar
Default Re: Ihernandez set-up
This is what I start with when ever I go to a new track.
front diff 50,000
front shock oil 50 wieght, trinty green spring
1 deg toe out.
1 neg camber
8 deg caster
sway bar 90 deg
rear diff 30,000
rear shock 40 weight, trinty yellow spring
middle hole on tower.
2.5 deg toe in
1 deg neg camber.
If traction is good and track lay out is flowing, I replace front diff with the one-way, and rear diff with one that has 50,000 in it, this is a good starting point on most tracks, just find tune for track conditions.
90% of set up is tires, and that is something that each track is different on
Old 03-25-2004, 01:09 AM   #10734
Default Re: Re: Re: Essential Hopups!!!
Kyosho Part # 92986
Old 03-25-2004, 01:41 AM   #10735
finchy's Avatar
Hey Gav the most essentatial hop up you need to go faster is wait for it
MUGEN MTX3
only joking Gav but I must say I'm going faster than I ever have with the new car.
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
finchy is offline   Reply With Quote
Old 03-25-2004, 03:23 AM   #10736
MUGEN MTX3
sparksy very nearly talked me into that hop up.
So finchy, you need to bring that MUGEN MTX3 down here? - then we'll see how fast it is.
Just for a little controversy, here's how I rate the top cars:
G4
MTX-3
Serpent 710
V-One RR EVO
HPI R40
FW-O5R
Old 03-25-2004, 03:58 AM   #10737
finchy's Avatar
Well I see the G4 at the top of your list there. I personally haven't seen one in action yet, they are saying it's dominating in Sydney at the moment. But what I will say that the FW-05 I've seen in action does look very good. I would go out a limb and say it looks better than the EVO. As for coming down to Melb. that won't be happening for a coulple of years I think, Got to go back to the USA am see the rest of my family first. And of course buy some more toys when I'm there. You know the saying
A boy can never have enough Toys.
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
Old 03-26-2004, 01:10 AM   #10738
Default new v one rr evo
hi guys,
ive just bought me a new v one rr evo and i was wondering if there are any secrets or tricks to take note of when building the car. this is my first nitro car but have been running elec for a while ive also got a novarossi tubro 5 port to chuck in there.
any help is appreciated.
Gary
KIMCOM RACING Driver #1
RC8B : REEDY 121 : Nitro-X fuel : Spektrum Radios
gkp5569 is offline   Reply With Quote
Old 03-26-2004, 04:22 AM   #10739
Default Re: V-One RR Basics
Originally posted by jihernandez
<SNIP>
Try the box set-up as a place to start. It's pretty good.
Those oils sound rather soft to me.
<SNIP>
Do you mean upstops?
Check the shock lengths to ensure your able to accommodate the droop you need.
Old 03-26-2004, 04:25 AM   #10740
Default Re: new v one rr evo
Originally posted by gkp5569
hi guys,
Gary
There are 358 pages of tips and secrets, here.
Seriously though, the instructions should be fine.
. . . oh yeah, buy an alloy brake stopper.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
