Old 03-15-2004, 07:28 PM   #10696
check out the S710 Thread,cool pics of the car with SSG hop ups.
CyrilJ88 is offline   Reply With Quote
Old 03-15-2004, 07:29 PM   #10697
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by CyrilJ88
thanks guys,
one more question(hope so):
Which brand makes the lowest engine mounting for the Evo?
If I lower my engine,do I need to get the Kawahara micro clutch?
you can use the clutch set and engine mount for FW05R but your clutch bell will get into the main chassis if you dont make clearence on the main chassis.
Manticore is offline   Reply With Quote
Old 03-15-2004, 07:45 PM   #10698
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default pics
here is another..1/10 lola
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 03-15-2004, 08:30 PM   #10699
Manticore's Avatar
Cool Re: pics
mike
lovely !!!!
Old 03-15-2004, 08:43 PM   #10700
mikecatts's Avatar
Default on e
1/10 chysler
Old 03-15-2004, 08:44 PM   #10701
mikecatts's Avatar
Default 1/10 dodge
1/10 dodge
Old 03-15-2004, 08:47 PM   #10702
mikecatts's Avatar
Default 235's
the old 235 days
Old 03-15-2004, 08:50 PM   #10703
mikecatts's Avatar
Default 1/10 chyrsler
1/10 chrysler
Old 03-15-2004, 09:16 PM   #10704
Manticore's Avatar
JEALOUZ !
Old 03-16-2004, 09:29 AM   #10705
popsracer's Avatar
Default engine mount for FW05
Manticore;
Is the hole spacing the same as the V1?
I tried the Mugen mounts, but the hole spacing was different and the flywheel was no longer centered in the chassis cutout.
There is another 1/8" to go lower if I can find the right mounts.
Thanks,
popsracer is offline   Reply With Quote
Old 03-16-2004, 09:33 AM   #10706
Manticore's Avatar
Default Re: engine mount for FW05
Originally posted by popsracer
Manticore;
Thanks,
yes, my friend is using fw05R clutch/engine mount on his EVO !
Old 03-16-2004, 11:15 AM   #10707
apmk's Avatar
Wink
Hi Maticore, i wud like to use the FW05R engine mount on my EVO.
However, i'm using Mugen clutch(4D), and I understand that I need a smaller flywheel, do you know the diameter of the flywheel required & is there any brand out there that i can apply here? Thank.
apmk is offline   Reply With Quote
Old 03-16-2004, 11:51 AM   #10708
Manticore;
Thanks,
I'm using NTC3 Non Pull Start engine mount. This is the lowest engine mount I can find. I need to trim the chassis (both the openings for the flywheel and engine mount screws) abit. The problem is that the side belt is rubbing the manifold, and the pipe is rubbing the ground when corning.....
Anyway, rear grip has been improved by using 35wt shock oil + stock springs(rear suspension), setting more rear droop, removing the rear sway bar, and setting front anti-roll bar to 90 degree.
Want to test this car again today...
P.S. I'm using HPI R40 flywheel, clutch weights, and clutch shoe. Others are Kyosho's.
wangcc61 is offline   Reply With Quote
Old 03-16-2004, 12:00 PM   #10709
ziggy12345's Avatar
Hey thats my setup for max rear grip!! LOL... took me a while to figure it out though
Topcad shocks work well with red springs. Sato Seiki 37 shore tyres with 26mm front and 28mm rear
ziggy12345 is offline   Reply With Quote
Old 03-16-2004, 01:04 PM   #10710
mikecatts's Avatar
Default low motor
the clutch fly wheel is 33mm and the engine mounts are 14mm...the kawaharra lite v-0ne mounts are the correct height....
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
