Old 03-14-2004, 01:21 PM   #10666
B
Default Re: B
Originally posted by Tom G
I knew if was somewhere in Asia. Thanks B!
Now, back to bed....
Hey Tom G,
you are too hooked to RC!
Climbing out of bed in da middle of the night to check RCTech
B is offline   Reply With Quote
Old 03-14-2004, 05:42 PM   #10667
Tom G's Avatar
Cool Waking wounded
Yup! Eat, sleep, wake RC.....makes having to work tolerable! My quote makes more sense now, huh? LOL LOL
Tom G is offline   Reply With Quote
Old 03-14-2004, 07:22 PM   #10668
B
Default Re: Waking wounded
LOL, sounds good to me!
Old 03-14-2004, 09:59 PM   #10669
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Default Re: hey guys
Originally posted by mr.fury
blue Hey guys....could you please let me know asap about the rear silicone oil in the rear.....I'm rebuilding my diff and i just purchased 50,000 silicone oil for the rear in a Reg V-one R.......will that 50,000 put all the power to the ground?...i'm looking for speed....parking lot racer...i wanna run for speed....not for tracks....
Are you Drag racing ? If so get a solid diff and do away with oil.
If ya need to use oil try 60-70,000 gives less diff action
HEYALIGNMENTGUY is offline   Reply With Quote
Old 03-14-2004, 10:05 PM   #10670
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Post active/negative diff
Originally posted by ziggy12345
Dont get the Active diff confused with the Negative diff!!!
sorry but i am confused, what's the difference of the two differential
buboy28 is offline   Reply With Quote
Old 03-14-2004, 10:14 PM   #10671
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: active/negative diff
active diff: external adjustable on diff action hardness. but the machanism is not good and it doesnt hold setting true.
negative diff: a built in clutch (in the diff) to make the diff become solid axle
Manticore is offline   Reply With Quote
Old 03-14-2004, 10:26 PM   #10672
AMGRacer's Avatar
For drag racing/ultimate speed you can do some mods to your V1R..........
1. Remove the middle belt and front belt and front diff and middle layshaft. Reduce rotating mass a HEAP.
2. Remove the rear shocks and replace with turnbuckles. Assists the rear from unloading due to suspension squat. Make sure your car is not tweaked!
3. Buy some 235mm foam donuts in around 25 shore. Get two old foam tires from a touring car and glue them together cutting the centre out of the outer one. Put both inside the donut and glue them to the donut. You should have around 50-55mm of foam surface now. True it down accordingly.
4. Get some slotcar foam tire additive and use this on the foam for instant grip, but messy.
5. Lola bodies or really slammed sedans are good.
6. Set the clutch high and run the bottom end really lean. Dont put much fuel in the tank.
7. Use a solid diff in the rear (the K factory one is very light)
8. Then you start cutting things up and lightening things. I wont even go there
AMGRacer is offline   Reply With Quote
Old 03-15-2004, 12:58 AM   #10673
buboy28's Avatar
Default Re: Re: active/negative diff
ok thanks for the info Manticore
Old 03-15-2004, 01:02 AM   #10674
rjl
rjl's Avatar
[IMG]http://[/IMG]
rjl is offline   Reply With Quote
Old 03-15-2004, 01:16 AM   #10675
ziggy12345's Avatar
Yep right Manticore as I have just found out.
I might go back to the standard diff. At least I know now how stiff it needs to be
ziggy12345 is offline   Reply With Quote
Old 03-15-2004, 02:08 AM   #10676
Taylor-Racing's Avatar
Default Re: Re: hey guys
1. Remove the middle belt . . . .
2. Remove the rear shocks . . . .
3. Buy some 235mm foam donuts . . . .
4. Get some slotcar foam tire additive . . . .
5. Lola bodies or . . . .
6. Set the clutch high . . . .
7. Use a solid diff . . . .
Hmmm . . . . you've obviously done this, then.
Taylor-Racing is offline   Reply With Quote
Old 03-15-2004, 02:26 AM   #10677
We run the negative diff - got it from "rjl" ages ago - he sure needs help in the avatar dept.
. . . anyway, my driver was a bit non-plussed with it, so I put some extra weight (3mm grub screws) in the clutch shoes and it seems to work much better.
Old 03-15-2004, 04:10 AM   #10678
sparksy's Avatar
Trader Rating: 14 (94%+)
Where did you get these tips from AMG?
A tip on lightening things.... you can go too far.... but it looks bloody cool when your car flexes just like the real top fulers. I'm gonna have to get back into RC Drag... You dont have a spare V one I could borrow do you AMG?
sparksy is offline   Reply With Quote
Old 03-15-2004, 05:45 AM   #10679
AMGRacer's Avatar
Default Re: Re: Re: hey guys
I got those tips from your hack ass old RS4 2 You QLD drag racing champ!!
Oh wait I drive a HPI now
Old 03-15-2004, 05:47 AM   #10680
AMGRacer's Avatar
I have done it, but on an old RS4 2. Inspiration for pretty much all the above tips came from the QLD drag racing champ himself..................
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
