Kyosho VoneR Thread
Originally posted by Dexter
Depends what Tamyia threadlock, never have used it on my engine becuase i always thought it was quite mild, the reason u used it on the alloy stuff. I have always used Threadlock 222 with good success but I feel that the most important thing is that u get screws which u can get some good purchase on.
. . . like when you keep having to move the engine 'cos the 0.8M pinions wear too fast.
It's also OK to use on the plastics for that odd pesky screw that keeps coming loose.
How does it like the heat though? Neway shouldn't u be down in Geelong .
I have a question that anybody familiar with a active diff can answer. A friend gave me an active diff that he cannot use cuz according to him it did not show any difference with the performance of his V1RR. Does anybody know how to use it? where it is better placed in front or rear? any tips on the installation? Any help will be highly appreciated.
Active diff
I have a diff installed in the rear and the more I run, the more use I see out of it.
You can customize it according to the tracks layout to benefit your particular drving style. You can completely lock it up if that's what you want of have it as lose as a goose.
Only track time will tell you whether to tighten or loosen it. I run mine pretty tight ot rather locked up.
I have one in the front end of the same car, more for bling than practicality, since I have it locked up tight [used the one way on my current racer, since I retired the car with the active diffs and only run it fro demos and fun].
I wish I could explain it to make sense but go to the experienced guys at the track and they should give a good start point. And as Darryl Waltrip says "sperience will teach you". If you want to start in the middle you can feel/see it for yourself. Remember, puting the power onto the track is your goal in cornering.
Good luck!
Good luck!
ive heard rumours that the front one way can be adj with shims to adj how much the diff stepsout any help is grateful
Shimmy the front!
Haven't thought about it till now but I guess it'll work.
I'd make sure the lock out bearings don't miss too much of that shaft or I would imagine they would fail from the play.
^5
^5
I just got the active diff and was going to ask how to set it up and what it does! Looks like thats answered then!
I'll try it out and see if I can spot a difference
Cheers
Cheers
gearing
guys,,,i seem to hear allyhis talkabout gears and speed......u can use the mtx3 clutch bell...i use 22/59 28/55.....its fast..i use a jpns3...power tu push...its important to get th clutch right....red shoe.hard spring....4 throw...1.4 gap.....................try it..thres a mugen 29 point 8 as well......
Ok I can't see how this active diff works other than it being a limited slip diff. If you tighten the 2 screws down it's the same as having heavy oil in the diff. I thought it supposed to be free at low revs and tighten up under power? It certainly doesnt do that
Cheers
Cheers
Sounds like the active diff is kinda like a ball diff that is externally adjustable to simulate different wt oils. What you are looking for is the negative diff which acts like a regular diff at low speeds but turns into a solid at high speeds.
OH crap i bought the wrong thing! I wanted the negative diff. Anybody got one for sale?
Cheers
Cheers
Re: Re: More Speed (continued......)
Originally posted by dameetz
Check K factory, they made 23T 1.0 mod, its actually meant for mugen but it will fit Evo clutch bell as well. I m using it with both my MTX and Evo.
where can I get the low friction belt set g=for the evo? I have 27t on the front pully of the middle belt
Cheers
Cheers
Trader Rating: 27 (100%+)
Hey i drive a mugen mtx-3 and like the layout on the vonerr evo . hows the gearing on the car. i heard its not great because of the limited spur gears. by the way do any of you guys have pics of the the car? thanks.
Re: Re: Re: More Speed (continued......)
Originally posted by ziggy12345
Is that the K1334 gear?
