Old 02-19-2004, 09:44 PM   #10546
drfritz's Avatar
Default Re: Re: Evo vs V1
Just got the evo conversion done and I see that it is need of a left side stiffener , will the aluminum kyosho v one r one fit it? if not, what else could I use.
2nd, are the front out drives for a diff the same as the rear diff, if not does any body have a part number for the correct ones.
thanks.
drfritz is offline   Reply With Quote
Old 02-19-2004, 10:30 PM   #10547
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Default Re: Re: Re: Evo vs V1
thanks.
Answer should be yes on both accounts
HEYALIGNMENTGUY is offline   Reply With Quote
Old 02-20-2004, 12:30 AM   #10548
pramac's Avatar
Default Front diff
The front diff out drives are shorter than the rear.
Kyosho part number is VZ118.
pramac is offline   Reply With Quote
Old 02-21-2004, 02:58 PM   #10549
drfritz's Avatar
Default Re: Front diff
Kyosho part number is VZ118. [/B][/QUOTE]
Is there anything else I need?
Old 02-21-2004, 07:12 PM   #10550
drfritz's Avatar
Default Re: Re: Front diff
Any good hop up web sites that any body knows of for the evo.
Old 02-21-2004, 10:20 PM   #10551
pramac's Avatar
You need VZ118 out drives, VZ012 gear set, VZ021 diff gasket, BS107 diff shafts.
Old 02-22-2004, 05:48 PM   #10552
Trader Rating: 49 (100%+)
Default Brand New Kyosho Active Diff
Guys,
I bought the Kyosho active diff for my G4 but have found that it will not fit. So, I am selling it.
It is brand new in the package.
$35 shipped. It is $53 at tower hobbies.
email me at [email protected]
rodneybarrett is offline   Reply With Quote
Old 02-23-2004, 04:31 AM   #10553
yes, 3 racing
and Presicion RC
Finken is offline   Reply With Quote
Old 02-23-2004, 04:41 AM   #10554
Tom G's Avatar
Thumbs up Precision RC
Good site!
Finken, thanks for the link!
Tom G is offline   Reply With Quote
Old 02-23-2004, 08:49 AM   #10555
JJ187RC's Avatar
Default Car Decision
OK, I am looking at getting a new Nitro car. I have had serpent and Mugen in the past, but I a friend has the V One RR Evolution that I am considering. What are the pros and cons of this car.
JJ187RC is offline   Reply With Quote
Old 02-23-2004, 12:30 PM   #10556
Great question. I'm curious as well.
Homer Allman is offline   Reply With Quote
Old 02-23-2004, 02:00 PM   #10557
Tom G's Avatar
Thumbs up V1REvo Ps & Cs
It's pricey and parts aren't the easiest to get, to start off with. I believe it will have the same negatives as its predecesor; braking is twitchy and it's tough on tires.
I have the conversion almost done and should be running it sometime this week.
The lowering of the front servo should make it easier to drive, or recover with some improvement on handling. It will still need a lot of front toe out and rear tow in, just like everyother version.
This is strictly based on the front end's new layout; placing the front servo on its side beneath the upper plate and the lengthing on the suspension arms.
The new gearing should be interesting. I can't see why it would need it. Other than Kyosho thinking the old gearing combination with the R/RR was off or the Evo can handle more.
Heck, it sounds good. I'll let you know what I find out!
Old 02-23-2004, 11:07 PM   #10558
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The Evolution has tons of steering. The most I have ever seen in a car. Twitchy or not depends on which body you are using. The new gearing is supposed to be smoother than the old and provide a lower gear ratio. If you run on a rough surface with a lot of debris it's best to go back to the old gearing because the .08 gears are a lot more fragile.
Racing4Evo is offline   Reply With Quote
Old 02-24-2004, 03:54 AM   #10559
Tom G's Avatar
Thanks for the tip & insight!
Is two degrees out in the front and three in on the rear a good starting point?
^5
Old 02-24-2004, 08:22 AM   #10560
vones's Avatar
^5
yeap..
vones is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
