Old 02-11-2004, 06:42 AM   #10516
Taylor-Racing's Avatar
Default Re: Re: Re: More Speed
Originally posted by tl2111
Gav, get the mugen 29T pinion it fits
Hi Tommy,
He's an ex Mugen man so that's what he might have been referring to.
But I thought the Mugen 2nd. pinions were of different diameter to the Kyosho ones - at least that used to be the situation with the old M1.0 gears.
Taylor-Racing is offline   Reply With Quote
Old 02-11-2004, 10:12 AM   #10517
popsracer's Avatar
Default More Speed
Guys;
1st Pinion/Spur: 18/48
2nd Pinion/Spur: 22/44 (tallest ratio available)
Engine: RB-V12 (stock 3 port)
Track: Revelation Raceway, 200ft straight
The Car is fine with normal diameter tires. When the grip is very high and traction rolling becomes a problem, I must use small diameter tires to keep the car on all 4 wheels in the corners. This reduces my overall roll-out enough to slow the car down by several mph.
By going to the pulley conversion, I should be able to adjust my pinions and spurs to achieve the desired ratio (I hope).
popsracer is offline   Reply With Quote
Old 02-11-2004, 02:50 PM   #10518
ziggy12345's Avatar
Problem is with the tallest gear 22/44, Engine revs around 40,000 and tyres at 63mm you get a top speed of 58.76mph
With the fast pulley set using the lowest gear 20/44 you get 70.28 mph. I think you can get a 19t high gear but this will give you 66.77mph
58.76 with the highest gears to 66.77 with the lowest gearing is too much of a jump
The fast pulley set should only be a 21 or 22 t pulley at the rear as this gives you a continuation of the gearing with a little overlap
Check it on http://www.ziggy12345.plus.com/Cars/V-1-RR%20MPH.xls
ziggy12345 is offline   Reply With Quote
Old 02-11-2004, 03:24 PM   #10519
Kawahara Aluminum Steering Saber
Has anyone used the Aluminum Steering Saber from Kawahara and is it worth getting. Does it improve steering much or is it equal to the plastics ones in the kit. Or is it just durable because its aluminum. What do you guys think?
Thanks,
sc
SC Racing is offline   Reply With Quote
Old 02-11-2004, 07:48 PM   #10520
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Kawahara Aluminum Steering Saber
Thanks,
sc
the alloy steering horn is not for durability issue but for the shake of fast change to different ackerman with only release of 2 screws.
Manticore is offline   Reply With Quote
Old 02-11-2004, 07:49 PM   #10521
Manticore's Avatar
Default Re: Re: Re: Re: More Speed
Originally posted by Taylor-Racing
Hi Tommy,
the kyosho 1.0 pinions have a bit larger diameter over the mugen ones.
Old 02-11-2004, 07:51 PM   #10522
Manticore's Avatar
Originally posted by Data
you might want to get the 15T 1st pinion and the 49T spur from kyosho too, unless you have an engine powerful enough to pull a 6:1 first gear ratio. even with the 15/49, the bottom end still suffer a lot.
sometimes people just forget about how much power output their little engine may deliver.
Old 02-12-2004, 02:56 AM   #10523
Default Re: Re: Re: Re: Re: More Speed
Thanks Manti.
I thought there was a difference. I think my friend used to crank the engine around to achieve a reasonable mesh but I'm not sure I'd risk that with the finer 0.8M gears
Old 02-12-2004, 03:25 AM   #10524
Default Re: More Speed
Originally posted by popsracer
Guys;
Pop's,
Is this on the Reflex with 1.0M gears? If so, do Serpent pinions fit 'cos they have a 23T I believe.
We run on a large track here - the straight is more than 200ft . . . and downhill.
We usually run a 22T in the old gears and use a slightly shorter spur (can't remember which ) and it's been fine - good in fact.
This was with a X/12 Rody and it likes to rev. Our mod. V12 doesn't like to rev as much.
Maybe try some set-up changes that can handle larger tyres or maybe a shorter pipe to gain a few more revs?
. . not much help, really.
Old 02-12-2004, 03:42 AM   #10525
sparksy's Avatar
Trader Rating: 14 (94%+)
Default Re: Re: More Speed
Or you could chuck that 777 paperweight in the bin.
sparksy is offline   Reply With Quote
Old 02-12-2004, 06:29 AM   #10526
The thought crossed my mind, I can tell ya.
Old 02-12-2004, 07:28 PM   #10527
Post Re: Kawahara Aluminum Steering Saber
Manticore, thanks for the info. That makes sense.
Old 02-12-2004, 07:29 PM   #10528
Arrow kyosho Bags
Does anyone know where I can get one of those Kyosho bags from. Its the three box style.
Old 02-12-2004, 08:03 PM   #10529
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default BAGS
HI DUDE.....I HAVE JUST RECIEVED THE RB TEAM BAG.ITS KILLER..I HAVE HAD MOST BRANDS AND THEY HAVE FALLEN APART.I RECOMEND THE RB BACG..IT HOLDS THREE CARS AND JUNK...........AOR TWO CARS AND RADIO WITH ROOM FOR MORE.HAS POUCH FOR SET UP BOARD...AND YOU CAN BUY THE BOXES SEPERATE. NO OTHERS IVE FOUND DO THAT.....THE MAGIC ONE LOOKS COOL AS WELL....................CANT GET IT AT THE RIGHT PRICE IN AUS.....
MIKE
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 02-12-2004, 09:27 PM   #10530
Hey guys,
a friend gave me his negative diff. thinking that i can make use of it. Haven't tried it with my rr yet cuz i want anyones opinion on the actual use of the diff. and what it does.
where is it best used rear or front. if there's anyone who actually experienced using it can help me. thanks in advance
shogun is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
