Old 02-08-2004, 02:27 PM   #10501
ziggy12345's Avatar
Nearly finished the Evo conversion but a couple of slight prblems
The middle belt is tighter than it was on the RR. I am sure the 19t pully was on the side and the 18 at the front right?
Anygody got any picks of the servo saver? Mines interfering with the chasis
Cheers
ziggy12345 is offline   Reply With Quote
Old 02-08-2004, 04:10 PM   #10502
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default evo hints
hi there...the 18 tooth goes on the front middle belt...the 19 is on the out swide gear box lay shaft.....the belt isa bit tight but its ok....didi you wind up the collar .5 mm from chassis.....i shimmed the front one way over to the left to clear the servo saver.......mines ok....you must be doing something wrong.
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 02-09-2004, 05:16 AM   #10503
ziggy12345's Avatar
OK thanks for that. I'll see how it runs when I get it going
Cheers
Old 02-09-2004, 01:13 PM   #10504
ziggy12345's Avatar
I dont seem to have as much turning circle as the RR. I havent tried it on the track yet but the lock is a lot less
Has anybody noticed any problems with limited steering?
Cheers
Old 02-09-2004, 01:50 PM   #10505
mikecatts's Avatar
Default turning
hi there.....you have 3 accerman blocks in the kit......if your not happy use another.i find #12 is the best. the car is better than the rr
mike
Old 02-10-2004, 09:39 AM   #10506
popsracer's Avatar
Default More Speed
Guys;
Using cut down tires to combat traction rolling, I now find that I am running out of gear on our straight.
What has everyone been doing to get a taller overall gear ratio for running on very large tracks?
Thanks,
popsracer is offline   Reply With Quote
Old 02-10-2004, 09:49 AM   #10507
I am using a 24 tooth convertion. I got it form Rcmodel in HK. the kit come with 2 alum. pulley shorter side belt and long rear belt. I hope this help to get more speed.
laorc is offline   Reply With Quote
Old 02-10-2004, 10:13 AM   #10508
InitialD's Avatar
The 24T conversion comes from 3 Racing. It changes the internal drive ratio from stock 2.53 to 2.0.
Old 02-10-2004, 10:16 AM   #10509
popsracer's Avatar
Guys;
Found the conversion and just ordered one.
Thanks,
Old 02-10-2004, 05:23 PM   #10510
blixelX's Avatar
Default Front One Way
I am using front one way on my car... when I make an emergency brake, the car will stop and make a U turn ( always turn to right and side), the steering is still straight... Is this normal or is my car setting?
blixelX is offline   Reply With Quote
Old 02-10-2004, 05:30 PM   #10511
AMGRacer's Avatar
Default Re: Front One Way
You are right on both counts, it is normal and it is your cars settings. You need to have removed all of your tweak from your car. Also you need to reduce the braking power of your car from the transmitter until it no longer spins.
AMGRacer is offline   Reply With Quote
Old 02-11-2004, 12:25 AM   #10512
finchy's Avatar
popsracer I use the tallest 0.8 module gearing availble (22 1st & 27 2nd). I find this is fine at my club track which is quite large. the fast ratio gear set you speak of from 3 racing is ok, but I ditched after a few test session as I didn't think it's as good as it should have been. That's my opion anyway.
finchy is offline   Reply With Quote
Old 02-11-2004, 01:29 AM   #10513
Data's Avatar
Originally posted by popsracer
Guys;
Thanks,
you might want to get the 15T 1st pinion and the 49T spur from kyosho too, unless you have an engine powerful enough to pull a 6:1 first gear ratio. even with the 15/49, the bottom end still suffer a lot.
Data is offline   Reply With Quote
Old 02-11-2004, 06:12 AM   #10514
Taylor-Racing's Avatar
Default Re: More Speed
Guys;
Thanks,
Pops,
What's the longest straight your trying to conquer?
What engine?
Most of the comments I've heard locally and on here say the 3Racing conversion is rather too tall.
One of the local guys told me he has some after market pinions coming that are taller than the 27T.
Taylor-Racing is offline   Reply With Quote
Old 02-11-2004, 06:17 AM   #10515
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default Re: Re: More Speed
Originally posted by Taylor-Racing
Pops,
What engine?
Gav, get the mugen 29T pinion it fits
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
