Kyosho VoneR Thread
#91
Re: my new v1r diffs
Originally posted by BIG NASTY
How much run time would you guys suggest before a break in rebuild for the diffs?
#92
The stock diffs. I haven't started any upgrades yet. I figured I would run it until I have problems then upgrade the problem area. I know some of you guys have had this car a lot longer than I have though so I figured I could ask for tips and suggestions. I'm not good enough to be above advise from others.
#93
You dont need to break in the stock diff !!
#94
Regional Moderator
One way front diff is sweet!
#95
#97
Originally posted by nitro dave
do you think universals/cvd would be a good upgrade or just a waste?
also, what about sway bars, who uses them?
I have never used sway bars on my V1R. Since I have bought them long times ago, I will try it out later this week.
#99
ernest...in your avatar, is that a V1R with the Kawahara Lola?
#101
which sway bar should i run in front/rear - soft,medium or hard?
your driving style and your setup
if u want more steering , put on the rear with the hard bar and u see u have alot of steering...
correct me if i am wrong
#102
Jack is correct. rear for more steering but less rear traction, front for more rear traction but less steering...im gonna get the GRP version which has both and ill let you know how both do..
#103
oh, and the harder the bar, the more it gives, like say you put the stiffest bar in rear, it will give you more steering than the medium, etc..
#105
Regional Moderator
WOW Very nice track!
