Old 02-02-2004, 04:08 PM   #10456
sparksy's Avatar
Trader Rating: 14 (94%+)
Originally posted by Bounty Hunter
Well that depends on what body you are using. If you are running a sedan body then yes. However that statement would be untrue if you are using a much higher down force body such as a Lola VDS.
What drugs are you on and where can I get some?
Body shape has absolutly no affect on weight transfer. The physics doesnt change.
Yes the car will have a different spread of tyre to road preasure with a higher downforce body. But That just proves to illustrate how wrong you are.
Why do we all want to use the higher downforce bodies? To get more traction. Using Downforce as a tuning aide is effectively choosing when and where on the track we "add weight" to the car. Higher downforce at the front gives more turn at speed. Higher downforce at the rear helps the rear end stick to the track at the hightr speed. Exactly the same way adding weight to either end of the chassis, without the downside of increrased weight at low speed.
sparksy is offline   Reply With Quote
Old 02-02-2004, 04:13 PM   #10457
AMGRacer's Avatar
I have a downforce question sparksy. I jumped off my roof with a VDS body strapped to my head and I still hit the ground. What did I do wrong?
AMGRacer is offline   Reply With Quote
Old 02-02-2004, 04:34 PM   #10458
sparksy's Avatar
Ahh... common mistake. A rather large misconseption is that a lola body will cure all points of phisics. We must remember that gravity is still unkind to us fat bastards. However, if you strapped it to your arse it might have softened the fall.
Old 02-02-2004, 04:45 PM   #10459
AMGRacer's Avatar
I was hoping that the $10.50 that I taped to my forehead would have raised my CG and increased lift. Did not work. Also all the change fell off when I landed.
Old 02-02-2004, 04:59 PM   #10460
sparksy's Avatar
Next time you could try using your FlyBuys card.
Old 02-02-2004, 05:09 PM   #10461
AMGRacer's Avatar
You so fonny. Hey you know what, the HPI is not too damn bad at all! I will call you later on.............
Old 02-02-2004, 08:52 PM   #10462
Bounty Hunter's Avatar
Originally posted by Taylor-Racing
How does a Lola VDS alter the dynamic weight transfer physics involved?
I dont mean to say that the weight transfer characteristics change with a Lola body. I was trying to add my 2 cents (sometimes its worth nothing), to try and answer the question. In my opinion I believe that extra added weight in the front of the car will give you more momentum on the on set of a turn. The Lola body would facilitate more downforce on the body in general. So if you have your setup right, and this is dependent on a whole bunch of other factors. Now if my analysis is interpreted as more "steering" than so be it. If it is not, then it is for everyone to find out for themselves.
Bounty Hunter is offline   Reply With Quote
Old 02-03-2004, 01:56 AM   #10463
ziggy12345's Avatar
Nice theory so I thought I would test it. Added weight to the front and guess what! More steering!
Theory is one thing but driving is everything!
I should read less and drive more
ziggy12345 is offline   Reply With Quote
Old 02-03-2004, 03:45 AM   #10464
Taylor-Racing's Avatar
Well actually you did say there was a reversal of affect depending on which body was used, but, hey.
I'm not sure where you're going with the momentum thing or what exactly constitutes "the on set of a turn".
My basic point was that increasing weight on the front = more steering, no matter what body you are running.
Certainly, using a Lola body provides more downforce and therefore more grip, but it shouldn't be confused with the weight transfer that will take place independant of that Lola downforce. It's just physics.
. . . and Manti is such a big physics fan.
Taylor-Racing is offline   Reply With Quote
Old 02-03-2004, 03:49 AM   #10465
Geeeeez . . . you were using them HC diaphrams, I trust.
Old 02-03-2004, 03:54 AM   #10466
dtm
dtm's Avatar
Send a message via ICQ to dtm
.................... However, if you strapped it to your arse it might have softened the fall.
With that VDS handle sticking out of the shell.......I think I'd rather have it strapped to my head!!!
dtm is offline   Reply With Quote
Old 02-03-2004, 05:48 PM   #10467
Sorry about that! Sometimes what I type and what I mean end up being two different things!
Old 02-04-2004, 03:54 AM   #10468
Hey, it's cool.
Old 02-04-2004, 04:03 AM   #10469
At the Victorian Titles last week, Michael Cantanzariti had a slight PROBLEM with his EVO . . . . .
Old 02-04-2004, 04:51 AM   #10470
tazman34685's Avatar
Default Things needed to finish
Questions:
1)is the wt of the plastic gears lighter than the hardened alum pulley setup.
2) Floating RR rear body post setup vs the R rear shock set, which is better to work with the evo
3) Lastly who makes/where can I get this new rear sway bar I've seen on the forum "looks like a mugen rear sway bay"
tazman34685 is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
