Old 01-31-2004, 05:41 AM   #10441
Default over drive belts
the over drive belts are the ones that are labeled "Special" (Kyosho Special Belts 210, 192, or 375 teeth) on the tag, correct.
Thanks for the info,
SC
SC Racing is offline   Reply With Quote
Old 01-31-2004, 07:13 AM   #10442
mmm.
i just can't adjust my two-speed now,what is wrong with it?
the thread of the 2speed shoe is stripped(the hole for adjusting the 2nd gear)!is there anything I could do to repair it?
CyrilJ88 is offline   Reply With Quote
Old 01-31-2004, 04:26 PM   #10443
B
B is offline   Reply With Quote
Old 01-31-2004, 04:27 PM   #10444
carkillaii's Avatar
It just time to get a new 2speed
carkillaii is offline   Reply With Quote
Old 02-01-2004, 04:34 AM   #10445
Taylor-Racing's Avatar
Default Re: over drive belts
SC
VZW012 SPECIAL FRONT BELT (210) RR
VZW014 SPECIAL REAR BELT (192) RR
VZW016 SPECIAL MIDDLE BELT (375)RR . . . . for O/D
VZ070 DRIVE BELT 378 V ONE R . . . . for non-O/D
Taylor-Racing is offline   Reply With Quote
Old 02-01-2004, 06:16 AM   #10446
Had our first race meeting of the '04 season today.
The boy won it with a lead of three or four laps, but the competition was mostly light.
Also had to rebuild that troublesome front shock . . . AGAIN.
I found the diaphram to have a large crack - just in the middle, not right through to the side.
I've been unhappy with these new hard diaphrams for a while now, and they've made shock rebuilding difficult, I reckon.
JordanC kindly provided a new set of the older V-One R soft diaphrams and the shocks have never felt better.
Old 02-01-2004, 06:46 AM   #10447
Thanks for clarifing that for me Taylor-Racing. I couldn't remember the difference between the 375 and 378.
thanks,
sc
Old 02-01-2004, 09:46 PM   #10448
Bounty Hunter's Avatar
Originally posted by sparksy
So let me get this straight....
Adding weight to the front gives less steering? The extra pressure on the front tires and the resulting increase of friction where the rubber meets the road (traction) causes less steering?
So if thats correct, if I add more weight to the rear of my car, the increased traction to the rear would make it turn better?
I dont think so.....
Well that depends on what body you are using. If you are running a sedan body then yes. However that statement would be untrue if you are using a much higher down force body such as a Lola VDS.
Bounty Hunter is offline   Reply With Quote
Old 02-02-2004, 04:38 AM   #10449
How does a Lola VDS alter the dynamic weight transfer physics involved?
Old 02-02-2004, 04:45 AM   #10450
Manticore's Avatar
R/C Tech Charter Subscriber
what are you talking about TR ?
but i want to know about the physic BH !
Manticore is offline   Reply With Quote
Old 02-02-2004, 04:54 AM   #10451
I just want to know how a VDS body reverses the basic principal.
Tell me what you think of the new EVO shock diaphrams?
Old 02-02-2004, 05:07 AM   #10452
Manticore's Avatar
they are great !! the old black bladders are making me boring !
Old 02-02-2004, 05:21 AM   #10453
Well, I dunno then. I thought I might have been cranking them down too hard.
When I took out the HC diaphrams, there was a crack in one and the other three had "dimples" and were somewhat wonky around the perimeter.
Old 02-02-2004, 06:00 AM   #10454
Manticore's Avatar
if you want to avoid those dimples, try to shorten the overall shock length.
Old 02-02-2004, 03:40 PM   #10455
AMGRacer's Avatar
Agree. This is a problem with the EVO now due to the requirements to unscrew the rear shocks a heap. At full compression the nut on top of the shaft will hit the bladder and deform it. Even the front shock does hit.
The new high compression bladders I liked. Adds a lot of extra rebound, but they did dimple up bigtime.
AMGRacer is offline   Reply With Quote
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
