Old 01-27-2004, 10:16 PM   #10396
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by HEYALIGNMENTGUY
with cold weather and dusty tracks, had to take it off. No rear traction even with 32shore tires but got real good at drifting
besure you know how to drift ! but i am sure you know how to drive ! because you are no initial D
Manticore is offline   Reply With Quote
Old 01-27-2004, 10:18 PM   #10397
Manticore's Avatar
Default Re: Re: Re: pinion n spur gears
Originally posted by thefuzzclub
Manticore,
Hello! Thanks for your reply. You've been very helpful to this thread.
that's ok, but i do BS and anti-alphabet most of the time !
Old 01-27-2004, 10:18 PM   #10398
Manticore's Avatar
Manti: I found the novarossi NS12 but no one has them with a turbo button.
mr. lam told me that the NS12 has a turbo combustion chamber on it.
Old 01-27-2004, 10:31 PM   #10399
Manticore's Avatar
i am referring to a NS12 S3
Old 01-27-2004, 11:09 PM   #10400
B
Default Re: Solid rear and front one way
Originally posted by rbgti
I've never used any of them...can someone tell me what kind of handling changes will occur if I switch to a solid rear axle and a front one way?
I've read that the transfer of energy to the ground is much better (less energy lost due to the internal gears of a diff), but there is the problem of the inside rear wheel spinning too fast during a turn....
What can I expect? What kind of a driving style is required and is it harder to drive? What kinds of suspension set up changes are required..?
I see all the 1/8scale cars are set up like this, and I like the thought of not worrying about diff oil rebuilding diffs all the time.
So if anyone can enlighten me before I make the purchases for this type of set up.
Much appreciate.
May I ask, where do you usually run in Vancouver?
B is offline   Reply With Quote
Old 01-27-2004, 11:10 PM   #10401
B
wow that was a quick response, thank you, just the stuff i was curious about.
cheers!
now just to find a local shop that carries the stuff, that won't rip me off
Good luck here!
Old 01-28-2004, 12:32 AM   #10402
Manticore's Avatar
according to "Fire" here, there is one particular shop in your area taht rips people off badly. you might want to check with "Fire" for more information and not get your hand burned.
Old 01-28-2004, 04:33 AM   #10403
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: Re: pinion n spur gears
i never bother to replace the plastic spur unless it is pretty worn or looks old.
I can testify to that....and his pinnion gears are so worn...I would have junked them ages ago!!!
dtm is offline   Reply With Quote
Old 01-28-2004, 04:34 AM   #10404
dtm
dtm's Avatar
My NS12 S3 came with turbo button......
Old 01-28-2004, 05:19 AM   #10405
Taylor-Racing's Avatar
Speaking of pinions . . .
We ran in the Victorian Titles last weekend. Started off with new 0.8M pinions, and at the end of the meeting they are very worn. The track was well used from early last week with all the entrants practicing, so there wasn't much dust around. Total track time was roughly 2.5 hours.
I noticed this also a couple of months ago at another meeting. This track had quite some dust on it at the beginning of the meet and after four heats the (not new) pinions had to be changed.
I'm wondering if the so called efficiency of these 0.8M pinions is worth it.
Anyone else notice this?
Taylor-Racing is offline   Reply With Quote
Old 01-28-2004, 05:52 AM   #10406
dtm
dtm's Avatar
Yes...0.8 pitch is very efficient at clearing money out of your pockets!!!! I have not noticed any really difference between the old pitch and 0.8 in terms of efficiency on the car.....more gearing options yes...but efficiency- very questionable.
Old 01-28-2004, 06:31 AM   #10407
Manticore's Avatar
you need to testify some of the good side of my car too !
Old 01-28-2004, 06:34 AM   #10408
Manticore's Avatar
it might not be noticible at our track. It will be more efficient at a bigger track like ACO as you may have a larger split of gears/ratio between 1st and 2nd gear without making the 2speed feels sluggish. It is definitely not efficient from economical point of view.
Old 01-28-2004, 07:45 AM   #10409
dtm
dtm's Avatar
Default Re: Re: Re: Re: pinion n spur gears
Oh yes.....I can testify that this guy has had brain bypass surgery when it comes to buying options..............
Old 01-28-2004, 07:47 AM   #10410
Manticore's Avatar
Default Re: Re: Re: Re: Re: pinion n spur gears
who said buy and see?
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
