Old 01-26-2004, 11:23 PM   #10381
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by HEYALIGNMENTGUY
Can you name something that is not cheap, to make car better for ones likeing
hey a lign men T guy !
you get what you paid !
Manticore is offline   Reply With Quote
Old 01-26-2004, 11:25 PM   #10382
One more silly question,
Is there anything such as a rear ball diff for the Evo?
I hate it when i need to change my rear diff oil,sucks
CyrilJ88 is offline   Reply With Quote
Old 01-27-2004, 01:41 AM   #10383
ziggy12345's Avatar
Fast pulley set here http://www.3racing.com.hk/3racing/index.jsp
KV-036
ziggy12345 is offline   Reply With Quote
Old 01-27-2004, 03:08 AM   #10384
Taylor-Racing's Avatar
Don't know of a ball diff.
It's pretty cheap to buy the parts and build a spare diff, though.
Taylor-Racing is offline   Reply With Quote
Old 01-27-2004, 06:43 AM   #10385
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
K-factory has it for G4 but also fits V1 Evo
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 01-27-2004, 09:28 PM   #10386
Send a message via ICQ to rbgti
Solid rear and front one way
I've never used any of them...can someone tell me what kind of handling changes will occur if I switch to a solid rear axle and a front one way?
I've read that the transfer of energy to the ground is much better (less energy lost due to the internal gears of a diff), but there is the problem of the inside rear wheel spinning too fast during a turn....
What can I expect? What kind of a driving style is required and is it harder to drive? What kinds of suspension set up changes are required..?
I see all the 1/8scale cars are set up like this, and I like the thought of not worrying about diff oil rebuilding diffs all the time.
So if anyone can enlighten me before I make the purchases for this type of set up.
Much appreciate.
rbgti is offline   Reply With Quote
Old 01-27-2004, 09:36 PM   #10387
Manticore's Avatar
Default Re: Solid rear and front one way
Much appreciate.
1/. very good straight line stablility
2/. very good on throttle steering. car understeer on slow speed corner if you let go throttle.
3/. you can use hard brake with the rear solid axle even with a front oneway.
4/. very efficient on power transmission.
5/. lighter drive tran.
6/. you need a body with great rear down force to compliment the setup. i.e. Lola
7/. best to run this setup on a medium to high traction track
8/. rear tire wear pretty fast on rear solid axle comparing to rear diff.
9/. shorter run time as you have more on-throttle time.
10/. yes, you need to change your driving style to make you fast.
11/. it is kinda give and take if you to decide what to use on a race day. diff or solid rear axle but racers here stick with rear diff to save pit time and obtain better tire wear.
12/. no doubt it is very fun to drive with this setup.
Old 01-27-2004, 10:03 PM   #10388
thefuzzclub's Avatar
Default pinion n spur gears
my pinions got sharpened and I replaced with new ones. Do I also need to change my spur gears? They still look ok but just to ask if replacement of these parts should always be at the same time for proper gear mesh.
thefuzzclub is offline   Reply With Quote
Old 01-27-2004, 10:05 PM   #10389
Manticore's Avatar
Default Re: pinion n spur gears
i never bother to replace the plastic spur unless it is pretty worn or looks old.
Old 01-27-2004, 10:07 PM   #10390
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
man ti core !
I know
I am only into this hobby for the $$$ or better yet to spend the $$$
HEYALIGNMENTGUY is offline   Reply With Quote
Old 01-27-2004, 10:11 PM   #10391
Manticore's Avatar
man ti core !
I know
how do you like your charge sway bar set so far my "guy" ?
Old 01-27-2004, 10:14 PM   #10392
with cold weather and dusty tracks, had to take it off. No rear traction even with 32shore tires but got real good at drifting
Old 01-27-2004, 10:14 PM   #10393
wow that was a quick response, thank you, just the stuff i was curious about.
cheers!
now just to find a local shop that carries the stuff, that won't rip me off
Old 01-27-2004, 10:15 PM   #10394
Default Re: Re: pinion n spur gears
Manticore,
Hello! Thanks for your reply. You've been very helpful to this thread.
Old 01-27-2004, 10:16 PM   #10395
Manti: I found the novarossi NS12 but no one has them with a turbo button.
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
