Old 01-19-2004, 06:36 PM   #10351
AMGRacer's Avatar
Default Re: Traction Rolling
Originally posted by popsracer
Guys;
Yes this is at Revelation raceway.
Front: 2 deg Camber, 2mm droop.
Rear: 3 deg Camber, 4mm droop.
Body: Original Stratus with the wing in the middle hole.
ziggy12345: You've GOT to be kidding!
Thanks,
Try 2mm and 6-7mm droop. Worked for me.
Also try increasing camber even if it does not wear properly.
TRUE THE TIRES DOWN!
AMGRacer is offline   Reply With Quote
Old 01-20-2004, 02:10 AM   #10352
ziggy12345's Avatar
No! It will definatly cure the problem!
Ok heres a more technical answer...
AMG was correct. A stiff suspention setup will make the problem worse.
Traction roll is induced when the CG (centre of gravity) is high and the roll centre is low. The roll centre is the point that the car rolls around and dependant on the geometry of the suspention parts.
The bigger the gap between the two, the bigger the roll moment. Reducing the CG is the best way to combat traction roll but the most difficult. You can increase your roll centre by increasing the angle of the upper suspention link.
Modern RC cars have a low CG at the front and high at the back giving a stable car but this will give excess front grip on the outside wheel into a corner increasing traction roll problems.
Soft suspetion at the front with the stiffest roll bar and soft at the back with no roll bar will likely help
ziggy12345 is offline   Reply With Quote
Old 01-20-2004, 11:07 AM   #10353
popsracer's Avatar
Default Traction Rolling
Guys;
I've got some stuff ordered and if it arrives by Thursday, I'm going out to practice and try some set-up changes.
Thanks,
popsracer is offline   Reply With Quote
Old 01-21-2004, 07:31 PM   #10354
thefuzzclub's Avatar
Default 2 questions
sway bars
what is the use of this? what type of track should i use this?
drive belts
when racing, what belt usually breaks? front? middle or rear?
thefuzzclub is offline   Reply With Quote
Old 01-22-2004, 01:21 AM   #10355
ziggy12345's Avatar
I ask the same question as removing them really improves grip.
Old 01-22-2004, 02:08 AM   #10356
ziggy12345's Avatar
Where can i get a box to hold the reciever for the Evo?
I have seen cars with these on the side.
Cheers
Old 01-22-2004, 02:16 AM   #10357
Manticore's Avatar
R/C Tech Charter Subscriber
Cheers
that's the kfactory receiver box.
Manticore is offline   Reply With Quote
Old 01-22-2004, 02:24 AM   #10358
AMGRacer's Avatar
I dont think the kfactory box will fit the EVO without mods.
I think the Mugen MTX3 cover does fit however.
Old 01-22-2004, 02:37 AM   #10359
ziggy12345's Avatar
Have you got a link?
Cheers
Old 01-22-2004, 03:10 AM   #10360
B4
B4's Avatar
Cheers
This is the Mugen part you require for the radio on the EVO.
"Mugen Seiki (#T0303) Radio Mount Parts For MTX3"
I got mine from Lam at Harmony Model Co. Drop him an email and let him know what country you want it sent to and he will give you the price including EMS shipping.
B4 is offline   Reply With Quote
Old 01-22-2004, 04:27 AM   #10361
Manticore's Avatar
the mugen one is a "holder", the kfactory one is a "box"
Old 01-22-2004, 05:05 AM   #10362
ziggy12345's Avatar
I need the box as its always crappy weather here in the UK. Have you got a part No
Cheers
Old 01-22-2004, 06:08 AM   #10363
Cheers
ziggy 12345, you can try the one from Team Magic that come in two colour choices, black or purple. The Trinity receiver box can also be used but both types need some cutting and drilling.
Cilla is offline   Reply With Quote
Old 01-23-2004, 03:30 AM   #10364
Manticore's Avatar
Cheers
here
Old 01-23-2004, 06:09 AM   #10365
ziggy12345's Avatar
Thanks. That should do the trick!
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
